My Knife Making Thread - Page 8
Page 8 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 141 to 160 of 204
  1. #141
    Kimberley
    Default Re: My Knife Making Thread
    Hobby... for now
    Pajero Gen2 1996 2.8TDi LWB
  2. #142
    Gaborone, Botswana
    How do you do your logos? Etching?
    EDIT: Ok, I see in an earlier post it is etching. The question now is how do you get the small detail on your mask. Laser cut?
    Kobus
    Nissan
  3. #143
    Kimberley
    I will post the link to the etching process.
    The stencil i made using. Ms word nd power point.
    The pic is from clip art
  4. #144
    Kimberley
    The process from KMTS website
  5. #145
    Kimberley
    Busy with the sheath. Intials embossed
  6. #146
    Kimberley
    Elbow injury kept me away from work. There was the small mountain I needed to transverse with a bicycle.
    Eventually finished the sheath
  7. #147
    Kimberley
    Stated a new project
    Template cut out
  8. #148
    Kimberley
    Shaping complete
  9. #149
    Kimberley
    Which of the two blade profiles do you prefer
  10. #150
    Personally I prefer the straighter back, and also I'm not a fan of a finger groove.
    But it does add visual interest.
  11. #151
    Kimberley
    Initial grind. Looking better left right almost symmetrical.
    Flaws are little less
ID:	525241   Click image for larger version.
  12. #152
    Kimberley
    Heat treated the blades
ID:	526152   Click image for larger version.
  13. #153
    Kimberley
    Check almost no scale formed the one has slightly more than the other. Cus i allowed 5 minutes between the two
    Big mistake. Forgot to drill the holes. This is gonna be a mission
  14. #154
    Kimberley
    Temper in oven at 200 degrees for two hrs
  15. #155
    Kimberley
    As the gas gets low. Place it in a bucket of water to improve the flow. I read this somewhere nd it works
  16. #156
    durban
    Ha Ha thats funny. Im so happy to see other people also make mistakes. I make many mistakes, I am just not honest enough to tell about them. If you dont have edm how are you going to drill those holes?
    Could you not re anneal the blades .?Could you perhaps try to just anneal the handle side of the blades with gas to bring the hardness down and if you can drop the hardness a bit then use a masonry drill. I have had success using cheap masonry bits but have sharpened them on a green wheel.Thats if you dont have cobalt drill bits.
  17. #157
    Kimberley
    440C is a air harding steel. Im not sure what will work. Trying annealing might be the answer, just don't know how the steel will react
  18. #158
    Dec 2014
    There was a company up in Joburg area that used to come down to Cape Town for exhibitions that used to sell drill bits that looked like masonry bits but they could drill through a file and a sheet of glass in succession.
    Dragon Bits was their name, but the name of the company is long forgotten.
    Cheers,
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  19. #159
    Kimberley
    What a struggle. Holes drilled and only one bit destroyed. The surface hardens in air. Tried to let it cool slowly but the skin harden nonetheless
    Note to self...drill holes first thing
    After some thought. I might have heated the blades too much. I hope that i won't need this knowledge again
  20. #160
    Kimberley
    Pics don't show the detail. Not 100% happy. First attempt at free hand.
