My Knife Making Thread - Page 2
Page 2 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 21 to 40 of 193
  1. #21
    Kimberley
    Thanked: 53
    Default Re: My Knife Making Thread
    Forge coming along
    Pajero Gen2 1996 2.8TDi LWB
  2. The Following User Says Thank You to hogbeast For This Useful Post:
  3. #22
    Kimberley
    Thanked: 53
    Completed the heat treat box
    Insulation next
  4. #23
    Thanked: 36
    Very very Nice... and cost effective.
    Nato
    '13 Nissan Navara 2.5TDCI DC 4X4
    Ex '08 Nissan Hardbody 3.0 TD 4x4
  5. #24
    Kimberley
    Thanked: 53
    First test burn. Still needs fine tuning
  6. #25
    Kimberley
    Thanked: 53
    All done. Ready to start my carvery set.
    so it turns out there are a few things not 100% with the forge. hope to correct this weekend
    1. heat coming out the front. need to weld on a heat screen
    2. number one burner not 100%. need to correct. redo the sleeve to straighten the jet
    3. need to block off the collars to prevent heat from the bottom
ID:	495203   Click image for larger version.
  7. #26
    Kimberley
    Thanked: 53
    Now we can get done to the business of knife making
  8. #27
    Kimberley
    Thanked: 53
    Nice and hot
  9. #28
    durban
    Thanked: 771
    Looks good . How long does it take to heat that bar.? How hot do you think it gets.
  10. #29
    Kimberley
    Thanked: 53
    Estimated around 5 min.
    I measured 1100. Since i am looking for 1070 i did not look for max. I think it should reach 1300
  11. #30
    Kimberley
    Thanked: 53
    Progress at last
  12. #31
    Kimberley
    Thanked: 53
    The knife
  13. The Following User Says Thank You to hogbeast For This Useful Post:
  14. #32
    Kimberley
    Thanked: 53
    Taking shape
  15. #33
    Kimberley
    Thanked: 53
    Bolster taking shape
  16. #34
    Kimberley
    Thanked: 53
    Bolsters
  17. #35
    Kimberley
    Thanked: 53
    Heat treat of a few blades. Testing the forge. Could maintain even steady temp. Just worried about high carbon steels that require 816 degrees
ID:	496832   Click image for larger version.
ID:	496833   Click image for larger version.
  18. #36
    durban
    Thanked: 771
    I think there are very few metals that would need to go higher than 1080c. I dont know what happens if you go higher than is needed on steel, does it change for the worse. I usually do the magnet test but for some steels it needs to soak for a while.
  19. #37
    Kimberley
    Thanked: 53
    i research the steel i have and find the recommendations for that steel. they talk about grain growth the high than specified temp the steel is heated resulting in poor performance
    most stainless is around 1050- 1080
    carbon steel around 820
    from my understanding all will need a soak to transform the steel to the core
  20. #38
    Kimberley
    Thanked: 53
    Initial grind done
  21. #39
    Kimberley
    Thanked: 53
    What wood to use
    Suidwes doring
    Prosopis
    Or mesquite
  22. #40
    Thanked: 269
    Prosopis, maar die ligter kleur, die donkerder kleur gaan nie mooi grein wys op so n klein oppervlak nie.
    Neil
