Page 20 of 20 FirstFirst ... 10 11 12 13 14 15 16 17 18 19 20
Results 381 to 394 of 394
  1. #381
    Thanked: 1935
    Default Re: My Knife Making Thread
    Mainly the angle changes wrt the application of the blade. Kitchen knives is normally sharpened to 20. I sharpen my upper class pocket knives the same. Normally pocket and outdoor knives are sharpened to 25. Carpet knives to 30, so I would recon that its also good enough for machetes. I used a Lansky standard set for many years but its a bit short for the larger kitchen knives. So I purchased a Ken Onion Edition Worksharp Tool and Knife sharpener.
    A lot of different sharpening methods would be effective. I guess that your oil stone might be having a lower grit (rougher) than P1000 sanding paper. P1000 is actually a good grit size for finishing a blade. I am still looking forward to inputs from other members.
  2. The Following User Says Thank You to Spiceman For This Useful Post:
  3. #382
    Thanked: 1837
    Peter, there are really only a couple of important factors to sharpening smooth-bladed knives:
    The first and most important is to keep the angle of the cutting edge consistent (and commensurate with the job the knife is expected to perform).
    Conseptually, the steeper the angle, the more robust the edge will be, but also the less sharp. So a machete will typically be sharpened to a blunter angle than a knife intended for cutting up ripe tomatoes.
    Practically, I suspect this is where you are going wrong. Keeping the angle consistent on a stone or water paper is quite difficult and requires lots of practice. This is why there are so many types of sharpeners intended to help guide the user to keeping a consistent angle, like the Lansky, the Warthog etc.
    The next is to sharpen the knife evenly on both sides, and if using an oilstone, to use the complete length of the stone. If one doesn't, it will become concave, making it practically impossible to keep the angle consistent.
    Lastly, it is beneficial to use graded sharpening devices as you are already doing, but 1000grit is far too fine to start off with. That's almost fine enough to finish up with.
    Couple of small tricks:
    At the start of the process, you can apply some pressure to the blade and also run it backwards and forwards. Toward the end of the process and on each grade, apply as little pressure as possible and work only forward. Don't drag the knife backwards. Also, at each stage, work untill you feel a "beard". Remove it in the next step.
    As for serrated blades, I have yet to find a method that works without gradually removing the serrations. I view serrated blades as throw-away items and avoid them as far as practical.
  4. The Following 4 Users Say Thank You to Peter Connan For This Useful Post:
  5. #383
    Sep 2017
    Richardsbay
    Thanked: 318
    What Peter said...
    Oil stones can eat a blade in the an effort to achieve a keen edge for the reasons mentioned.
    Warthogs are brilliant for their precision and ease of use, Lansky's are a bit more 'technical'.
    Personally I prefer my Lansky.
    You can tailor the angles of the edge to its intended purpose with very little loss.
  6. The Following 2 Users Say Thank You to Bospatrollie2 For This Useful Post:
  7. #384
    Kimberley
    Thanked: 212
    I personally use the Lansky to sharpen the knife the first time. Establish the edge. After that I use the warthog to maintain the edge. After a while I need to go back to the Lansky.
    A rough 600 grit will create a cutting edge microscopic serrated edge. The ultra fine stone on the Lansky is around a 1000 grit creating a smooth edge. For kitchen work it will last longer.
    The other thing most forget is leather stropping. For me this makes a huge difference
    The sharping steel is also very useful for straightening the edge
    Pajero Gen2 1996 2.8TDi LWB
  8. The Following 2 Users Say Thank You to hogbeast For This Useful Post:
  9. #385
    Thanked: 382
    Peter covered most of the points, great post.
    Out of interest also Google/youtube Convex knife edge, I would recommend this edge for working knives and pangas
    George Moustakis
    Disco 4 XS
  10. The Following User Says Thank You to wildhunter For This Useful Post:
  11. #386
    Sep 2017
    Richardsbay
    Thanked: 318
    Quote Originally Posted by Bospatrollie2 View Post
    What Peter said...
    Now if only them 'wimmin' would stop using the granite cutting board....
  12. The Following 2 Users Say Thank You to Bospatrollie2 For This Useful Post:
  13. #387
    Sep 2019
    Pretoria East
    Thanked: 1891
    Get her a nice bamboo one. That's my favourite. It's less creepy than wood. Not too pricey at the big PicNPay
  14. #388
    My Leatherman Surge needs sharpening for the first time. Who closeby can help my please, except for sending it down to the Cape?
  15. #389
    Thanked: 1935
    Quote Originally Posted by Bulletjie-3 View Post
    I am willing to help you. I have seen how the operators of Leatherman stalls go about sharpening knives and have never trust them and never will. I am in Mountain View. Your welcome to visit.
  16. #390
    Kimberley
    Thanked: 212
    Hunting season is drawing to a close... For myself at least. I have time to complete one project and start another.
    These two are ready for heat treat
  17. The Following User Says Thank You to hogbeast For This Useful Post:
  18. #391
    Kimberley
    Thanked: 212
    Just some pictures of what I have done recently
    A lovely handle
    Busy with the final shaping
    The board for a slicer
ID:	629000   Click image for larger version.
ID:	629001   Click image for larger version.
ID:	629002   Click image for larger version.
  19. The Following 8 Users Say Thank You to hogbeast For This Useful Post:
  20. #392
    Kimberley
    Thanked: 212
    Gluing up scales
ID:	629488   Click image for larger version.
ID:	629489   Click image for larger version.
ID:	629490   Click image for larger version.
ID:	629491   Click image for larger version.
ID:	629492   Click image for larger version.
  21. The Following 7 Users Say Thank You to hogbeast For This Useful Post:
  22. #393
    Kimberley
    Thanked: 212
    Using biscuits help alignment
ID:	629941   Click image for larger version.
  23. The Following 2 Users Say Thank You to hogbeast For This Useful Post:
  24. #394
    Thanked: 1935
    Quote Originally Posted by hogbeast View Post
    Gluing up scales
    Do you have photos of the finished product.
