Page 11 of 21 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 ... LastLast
Results 201 to 220 of 403
  1. #201
    Thanked: 387
    Default Re: My Knife Making Thread
    Quote Originally Posted by hogbeast View Post
    Yessss
    I got all the LEDS working as I intended.
    12V green Led on after the fuse thus a dead led means blown fuse
    SSR- red led on when triggered.i know my system is working
    Blue LED on when the soak period is complete together with a audible buzzer. Thus i don't need to watch the oven like a hawk checking time.
    Ammeter is supplied by 220V thus my 220v indicator.
    Is that solid state relay the one from micro robotics? If it is be warned, I know of more than one that melted with very little current going through it.
    Neil
  2. #202
    Kimberley
    Thanked: 239
    Quote Originally Posted by neoT View Post
    I am not sure where I bought it from. Most came from Botshop
    I ran a bar heater via the ssr during testing. I will keep a close eye on that one
    Pajero Gen2 1996 2.8TDi LWB
  3. #203
    Kimberley
    Thanked: 239
    So frustrating. The PID was working fine now I find that something is coursing the MAX13855 to be unstable give errors.
    I was going to start final testing before building it in a box. Now I must sort out this new problem
    Edit
    After some testing it seems the power supply is causing the problem. I will connect the LM2596 adjustable buck pack to hopefully fix the problem
  4. #204
    Kimberley
    Thanked: 239
    I ended using a old computer supply connected to the LM2596. System is stable and reading correctly. I tweaked the timing. So the soak time is 10min per stage. Some how the LEDs are not working. I'm going to leave it out for the final product. Testing going fine up to now
    Lcd display, 12v fan and ammeter will indicate any power issues thus LEDs are redundant
    edit
    After I solved the problem the power supply created I could revisit my LED idea. it is actually a good idea and I connected the LEDS,
    just nice to see at a glance the SSR firing and also very important to note that the cycle is complete.
    next step is to build the PID controller in a box and start on the oven itself
  5. #205
    Kimberley
    Thanked: 239
    At last time to work on the project. Busy with the box all cut out and ready to put together
  6. #206
    Kimberley
    Thanked: 239
    Making progress. Then load shedding 😭
    Box completed. Sides screw on to enable. Easy access for future software updates or repairs
ID:	558345   Click image for larger version.
ID:	558242   Click image for larger version.
  7. #207
    Kimberley
    Thanked: 239
    Order for the isolation bricks and element was placed. Hopefully the project will gain momentum
  8. #208
    Kimberley
    Thanked: 239
    The element arrived. 3 to 4mm thick. Actually much thicker than I expected.
ID:	559054   Click image for larger version.
  9. #209
    Gaborone, Botswana
    Thanked: 1805
    I'm following this build.
    Kobus
  10. #210
    Kimberley
    Thanked: 239
    Started to assemble the control.
    Edit
    Wiring 90% complete
    LEDs installed
ID:	559175   Click image for larger version.
ID:	559228   Click image for larger version.
  11. The Following 2 Users Say Thank You to hogbeast For This Useful Post:
  12. #211
    Kimberley
    Thanked: 239
    Wiring completed. I had some issues but managed to sort it out
  13. The Following 3 Users Say Thank You to hogbeast For This Useful Post:
  14. #212
    Nov 2017
    Thanked: 296
    Looking good.
  15. The Following User Says Thank You to HobieDave For This Useful Post:
  16. #213
    Kimberley
    Thanked: 239
    First of the final tests to make sure that the operation is right. Discovered a program issue. Will sort that out
  17. The Following User Says Thank You to hogbeast For This Useful Post:
  18. #214
    Kimberley
    Thanked: 239
    I can declare the controller complete. The final settings will be loaded with commissioning of the oven
  19. The Following 2 Users Say Thank You to hogbeast For This Useful Post:
  20. #215
    Kimberley
    Thanked: 239
    I tested the robustness of the design. I blew up the controller to test how easy it is to repair.
    Parts cost R500 about.
    OK not really done it intentionally but replacement parts easily available. Also made some improvements
  21. The Following User Says Thank You to hogbeast For This Useful Post:
  22. #216
    Kimberley
    Thanked: 239
    I repaired the controller. Was very easy. The mod will make repairs much easier. That is hoping for no slip ups.
    As seen on the Pic every thing plugs in.
    Upload the code and off you go
  23. The Following 3 Users Say Thank You to hogbeast For This Useful Post:
  24. #217
    Kimberley
    Thanked: 239
    I started with the oven build. Refractory cement to bond the walls, roof and floor. Baking in the son to cure the cement.
  25. The Following User Says Thank You to hogbeast For This Useful Post:
  26. #218
    Kimberley
    Thanked: 239
    Testing done for today. I'm happy with the results. I need to put in a few more staples. I can complete the build
ID:	562912   Click image for larger version.
  27. The Following User Says Thank You to hogbeast For This Useful Post:
  28. #219
    Kimberley
    Thanked: 239
    The project is progressing nicely
ID:	563247   Click image for larger version.
  29. The Following 3 Users Say Thank You to hogbeast For This Useful Post:
  30. #220
    Oct 2017
    Vereeniging
    Thanked: 264
    You are a genius my friend. People like you bring progress to the world through the creations from your brain and hands.
  31. The Following User Says Thank You to EtienneB For This Useful Post:
