My Knife Making Thread - Page 10
Page 10 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10
Results 181 to 193 of 193
  1. #181
    Kimberley
    Thanked: 53
    Default Re: My Knife Making Thread
    The skinner is finished. Much happier with this knife.
    Pajero Gen2 1996 2.8TDi LWB
  2. #182
    Kimberley
    Thanked: 53
    Quote Originally Posted by hogbeast View Post
    Not happy with the results.
    Positive is that i can personalize the blade and the sheath. Someone will get a knife for free.
    This one was relegated to a workshop knife
  3. #183
    Kimberley
    Thanked: 53
    Some more blades to complete
  4. #184
    durban
    Thanked: 817
    How do you cut the blanks.?What metal is that.
  5. #185
    Nov 2011
    Thanked: 796
    This looks like a very good idea for reasonable material easily available -always an old blade or two about in a woodwork shop
    -some nice large cleavers can be cut from large diameter blades- if you search the web for pics.
    How to cut....
    - mini-grinder? water-jet? bandsaw? laser-cut? SWAMBO's fierce cutting stare?
ID:	530283   Click image for larger version.
    - Charles Bukowski
  6. #186
    Kimberley
    Thanked: 53
    Grinds done. I released where the issue is with the grind lines not 100%. Applied a fix. Will test the effectiveness of the fix.
  7. #187
    Kimberley
    Thanked: 53
    Small grinder and smooth with flappy disks then finish off on belt grinder
    440C stainless steel
  8. #188
    Kimberley
    Thanked: 53
    Quote Originally Posted by Patrick L View Post
    How to cut....
    A grinder should cut it. Good idea for practicing and developing your skill. I like to know what steel it is and then try and apply the correct heat treat.
  9. #189
    durban
    Thanked: 817
    You need to make yourself a mini bandsaw .It must be difficult to get a straight line on a longish blade. Are you eyeballing it or do you use a jig.?
    Is there any difference in how stainless is hardened. ?
  10. #190
    Kimberley
    Thanked: 53
    440C is a air hardened steel. I use the compressor to force air while clamped in an old book press. others are oil hardened. The temp and soak times are different between different steels.
    The biggest difference between stainless and carbon steel is the temperature. Around 816 degrees vs 1040 to 1080 for stainless
    I use the belt grinder to refine the profile of the blade. Then eyeball it to see the balance, shape of the blade
    I Google papers on the steel. The students research different methods to achieve certain results. That is where i read that 1040 for 440C was producing better toughness
  11. #191
    durban
    Thanked: 817
    I bought this beat up 4x6 bandsaw for about R700 It would be perfect for what you do. I see they often have beat up ones at the same auction house.
    https://www.4x4community.co.za/forum...36#post3947536
  12. #192
    Kimberley
    Thanked: 53
    I would love to get one. The scroll saw does not work for hard thicker wood. No metal. So lots of limitations.
  13. #193
    Kimberley
    Thanked: 53
    Two completed by JS Custom Knives
