Dual Battery set up. - Page 6
Page 6 of 6 FirstFirst 1 2 3 4 5 6
Results 101 to 112 of 112
  1. #101
    Thanked: 62
    Default Re: Dual Battery set up.
    Nice to mount in the engine compartment if they handle heat better than Ctek?
    I like the amps/volt meter.
    Cheaper than Ctek?
    I thought they were made in Aussie?
    Intervolt is an Aus product. National Luna is SA
    Gavin
  2. #102
    Thanked: 28
    Hi all
    There is a very good article in the latest SA 4x4 Magazine on Battery set up and why we have issues. As the OP it describes exactly why I had the issues I did. Also pretty much the answers I got from the Form Members in the know.
    Regards Gavin
    2015 Discovery 4 30 SDV6 SE
    2007 Defender 90 Puma 2.4
    Metalian Off Road Trailer
    Previous
    2010 Discovery 4 30 TDV6 SE
    Discovery 3 V6 S
    Discovery 2 TD5
    Defender 90 TDI
    Defender 110 V8 Hard Top
    Jurgens Xplorer
  3. #103
    Nov 2008
    Ellisras
    Thanked: 136
    Quote Originally Posted by gavpike View Post
    .......While you're about it, check out the new National Luna DC-DC charger. Really good - locally manufactured and supported as well.
    National Luna DC-DC charger ?
    Cannot find a link to such a NL product, can you help ?
    2000 Patrol GU 4.2D(onkey) @ 800 000 km
  4. #104
    Jan 2018
    Thanked: 19
    https://www.outdoorwarehouse.co.za/p...ry-manager-kit
    You can also buy the solenoid separately for R999.
  5. #105
    Thanked: 62
    Pm sent.
    Gavin
  6. #106
    Thanked: 62
    Pm sent.
    Attached their user manual.
    Gavin
  7. #107
    Feb 2013
    Thanked: 199
    Has anyone used the WRND DC-DC charger. Any views on this?
    Land Rover Defender Puma
    Previous ride: Defender 90 tD5
  8. #108
    Aug 2016
    port elizabeth
    Thanked: 41
    Quote Originally Posted by Ellie2 View Post
    what size cables do u guys run from front to back??
  9. #109
    Springs
    Thanked: 23
    Looks very impressive. Will have to prove it's efficiency and reliability though!
  10. #110
    Thanked: 62
    Quote Originally Posted by Kobus Jacobs View Post
    Given their performance and backup on everything else they do, I'd use it without blinking.
    Gavin
  11. #111
    Nov 2008
    Ellisras
    Thanked: 136
    Thanks, Interesting
    Bet you it is an import with a LN sticker...
    I would like to know what that costs
  12. #112
    Jul 2010
    Thanked: 8
    I use the WRND and have no issues with it. However I think they can improve their connections. They have short wires sticking out at the bottom which you either join or use a strip connector. I prefer direct coupling without joints. Mine works from solar and dual battery.
    2015 Mitsubishi triton 2.5 4x4
