2.4 GD6 hilux (2017-18) cruise control - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 54 of 54
    Dec 2018
    Default Re: 2.4 GD6 hilux (2017-18) cruise control
    Got mine done at Lynnwood Toyota as well thanks to this post ,paid R2300
    The other Toyota dealer didn't even know ,they still gave my old crazy prices like R8000
  2. #42
    Sep 2011
    Brackenfell
    Quote Originally Posted by Razeen View Post
    Just some feedback, got the cruise control fitted. I had to explain to them where ti putthe wires. Everything working as it should. Just some pics of plugs and where the wires must go
    Hi Razeen
    Where did you get the pins to insert into the empty holes in the two plugs?
    I got as far as the final stage when pin 2 goes to earth and pin 1 goes to pin 26 on the top plug of ECU....but have no idea where to buy the actual pins...
    I'm located in Brackenfell
    Thx
    Deon
  3. #43
    Sep 2018
    Has anyone done this in the Western Cape?
    Update:
    Quote from McCarthy Toyota Tableview - R4700...
    Quote from Imperial Toyota Cape Gate - R3700...
    Quote from Barloworld Toyota Tygervaley - R1900...
    The trick it seems is that you should not ask for "How much to install cruise control on my Hilux?". You should rather ask:
    How much for
    - T08463234011 (stalk),
    - T08463348020 (wire),
    - T09015950199 (screw),
    - T0451860K140C0 (cover),
    - and installation?
  4. #44
    Cape Town,South Africa
    Quote Originally Posted by Deon vE View Post
    Hi Razeen
    Thx
    Deon
    Hi Deon
    Sorry i never replied to the queation. Had teouble with my login. You can use the oins they use in the back of the radio plugs. Otherwise you can order the wires from Toyota. If you did it already all good. If you still need help you can give me a call. I might have the part number for the wires. 0829nine20752
    Razeen Baboo
    Toyota Hilux 2.4 GD-6 4x4 2016
    Audi A4 1.8T 2007
    1997 Isuzu KB 280DT 4X4
    Domino Intercooler
    63mm exhaust
    EGT Turbologix
    Hi-Lift Jack
    Turbo Timer
    Garmin GPS
    I never met a man lying on his death bed, that said he spent too little time at work.
  5. #45
    Quote Originally Posted by Blinkfan View Post
    Update:
    How much for
    - and installation?
    Yes i did it. Had the wiring done by radio autosonic bellville. Because they had to wire the rear camera. So i thought they might as well do the cruise control wires. I fitted the stalk myself.
    Razeen Baboo
    Audi A4 1.8T 2007
    Domino Intercooler
    63mm exhaust
    EGT Turbologix
    Hi-Lift Jack
    Turbo Timer
    Garmin GPS
  6. #46
    All the parts are roughly R1300 excluding the wires that is about R70 each
    Razeen Baboo
    Audi A4 1.8T 2007
    Domino Intercooler
    63mm exhaust
    EGT Turbologix
    Hi-Lift Jack
    Turbo Timer
    Garmin GPS
  7. The Following User Says Thank You to Razeen For This Useful Post:
  8. #47
    Jul 2019
    Lightbulb Re: 2.4 GD6 hilux (2017-18) cruise control
    Hi All this is my first post on the Forum...
    I Bought a 2.4 SRX (My First Bakkie) new in July 2019 - The only issue I had with it was that there was no option to fit cruise control as an accessory.
    I did some research on the net and found the following:
    The 2.4 Hilux can definitely be retrofitted with cruise control! I have it fitted on my vehicle and it works 100%, even the dash light comes on as with the 2.8 Hilux and Fortuners. In my opinion, the 2.4 Hilux should have come with it from the factory as all provisions were made for it!
    The parts are all plug and play, and no wires need to be cut or modifications are required.
    The parts you will need for the Fitment are as follows: (Prices Shown July 2019 excl vat)
    TO8463348020 - Wire Cruise Switch R 135.85
    TO9015950199 - Screw x 2 R 22.60
    TO451860K14OCO - Cover, Steering Wheel R 129.24
    TO8463234011 - Switch, Speed Control Main R 873.16
    Labour R 962.00
    I had it fit to the vehicle at the dealership I bought it, before taking delivery. All warranty's etc are still in place as it was done at Toyota with OEM parts.
    The cruise control fits in the existing steering wheel, on the lower right side at the back (You will see provision has been made for it, as there is a removable cover)
    If the bakkie was not under warranty, I would have simply fitted it myself and saved R 962.00
    The bakkie is definitely a pleasure to drive on long roads, and in 6th gear it goes like a train!
    I love it, and honestly cant imagine the bakkie without cruise control! - As stated it should have been a Factory accessory option.
    But for those of use who knows, it can be done, pleasure awaits....
  9. #48
    Krugersdorp
    Thanked: 373
    Did anyone recently fitted cruise control to a 2.4 SRX? This would be in Johannesburg.
    The quote I got for the Cruise Control is R6800 (Excl VAT).
    This sounds a bit high?
    Regards,
    Bush Lapa Miskruier 586
    Youtube Channel: https://www.youtube.com/channel/UCFS..._as=subscriber
  10. #49
    Jul 2009
    Thanked: 873
    Quote Originally Posted by Bogaards View Post
    Regards,
    They ripping you off. See post #47 above yours. Alternately, contact Lynwood Toyota in Pretoria. They will do it for under R2500 labour included within 2 hours.
    Toyota Fortuner 2.8 GD-6 4x4 Auto
  11. #50
    Jul 2009
    Thanked: 873
    Quote Originally Posted by Wazzbeer View Post
    Quote Originally Posted by PrieskaNC View Post
    Labour R 962.00
    You should read the whole thread to get the full benefit of the members assistance. You could have been spared a post if you had.
  12. #51
    Krugersdorp
    Thanked: 373
    Quote Originally Posted by Caracal View Post
    Thanks, Lynwood is just a bit out of my way. Therefore hoping someone can do it in JHB.
  13. #52
    Springs
    Thanked: 9
    Hi All, thought i would add to the thread...
    Parts R1,134.75
    Labour R250
    Time 30 mins
    I sourced the parts at Pat Hinde Toyota Boksburg through Ettienne Gomes. Installation was done at Fitment Zone Benoni ask for Charlie (the owner)
    2018 Toyota Hilux 2.4GD-6 D/C 4x4 A/T
  14. The Following User Says Thank You to Birra For This Useful Post:
  15. #53
    Feb 2020
    Bellville
    Thumbs up Re: 2.4 GD6 hilux (2017-18) cruise control
    Helo Razeen, can you maybe give your contact details please. I tried to contact you earlier but seemed to have no response.
    JG
    071 333 4271
  16. #54
    Hi
    See you found my number in the post, no problem helping you out, wherever I can
    Razeen Baboo
    Audi A4 1.8T 2007
    Domino Intercooler
    63mm exhaust
    EGT Turbologix
    Hi-Lift Jack
    Turbo Timer
    Garmin GPS
