Results 1 to 20 of 89
    Thanked: 20097
    Default Tata SFA conversion
    I'm thinking about an SFA conversion on my 4x2................
    Mosselbaai
    Thanked: 2278
    Default Re: Tata SFA conversion
    Excellent, go for it, will probably be one of a kind.
    Jean
    Old Wheeler
    200 Cruiser (Softroadertjie 2.0)
    P38 Range Rover (Softroadertjie 3.0)
    Ford Everest LTD
    Langs die rivier, op n berg
    Thanked: 6233
    Mosselbaai
    Thanked: 2278
    I reckon that one is quicker than Jelo’s
    Jean
    Old Wheeler
    Ford Everest LTD
    Thanked: 20097
    EXACTLY the look I'm hoping for.
    Thanked: 20097
    Quote Originally Posted by Jeanvn View Post
    I found a LONG downhill last week and clocked 142........really chuffed I was.
    Here is the Tata gearbox and T-case combo:
    So RHS front drop, will work with at least 3 different versions of solid front axle.
    Just North of Dwarskersbos
    Thanked: 1208
    Will it be able to carry the weight of a Patrol diff
    Thanked: 20097
    yep
    chassis is very robust
    rear axle is a Dana copy
    Thanked: 1208
    Gear ratio?
    Mar 2016
    Thanked: 6018
    Those Tata chassis are strong.
    Pity about the rest
    André Opperman
    Thanked: 1208
    yep
    Hopefully a stronger copy.
    Thanked: 20097
    Quote Originally Posted by Oppies3800 View Post
    Pity about the rest
    dude my Xenon is made of plate steel, over 240,000km on it, engine is good, gearbox is good, original clutch, no rust, the only expensive bit is the Delphi fuel filter @ R800, the rest is cheap
    I've been under the lorry and the front IFS looks like it was made for a 2 ton truck
    Thanked: 20097
    nothing wrong with a Dana 60
    Thanked: 6233
    Wow. Lucky jy. D60 onder jou tata. Impressed...
    Thanked: 20097
    Gear ratio?
    dunno yet, will have to investigate
    EDIT:
    REAR AXLE
    Type Salisbury Rear Axle with Semi-Floating Axle Shafts & Limited slip
    differential
    Ratio 3.36 (37/11)
    Mosselbaai
    Thanked: 2278
    EDIT:
    REAR AXLE
    differential
    Ratio 3.36 (37/11)
    You will have to do ratios if you go for bigger tires.
    And you HAVE to go for bigger tires.
    Jean
    Old Wheeler
    Ford Everest LTD
    Thanked: 6233
    Dan kan hy net so wel hilux 4.88 diffs in sit. Voor en agter offset is reg
    Thanked: 20097
    no I don't, but based on Patrol diff ratios (4.11 and 4.625 and 4.8), I would need to. And I'm not sure where to get a CW&P for that diff.
    So I'll stick to a Defender or D1 front axle at first. Axle with radius arms is cheap, under R3k. Will need to install coil towers but there is plenty of space. The sump is already profiled for a front diff: Tata in their wisdom created the 4x2 off the 4x4 base and just omitted the transfer case and used front hubs without side shaft drive hubs, everything else is exactly the same as the 4x4.
    I can get various ratios for the Land Rover axle in Heavy Duty format. About R4k per axle.
    3.54:1 as standard Land Rover is close enough of a match for off-road use.
    I'll stick with 30" or 31". T-case is 1:2.48.
    If I want to go to 33", I'll need a 4.11 CW&P, but then I think there will be issues with the wheel arches.
    At the moment the engine is understressed and actually quite choked. There is plenty of space for a bigger IC, and I'm running a standard 50mm exhaust. EGR is also not blanked yet.
    Thanked: 20097
    ek sit nie daai goeters onder my tata nie
    Thanked: 20097
    But just to humour reenen, I went and looked for Hilux axles:
    R7k a shot
    That's for the leaf spring stuff without leaf springs, drag links, front leaf mounts, rear leaf mounts, shackles etc
    I can buy Discovery front axles with radius arms, panhards and steering stuff all day long for R3.5-R4k.
    All I need is 2 x radius arm chassis brackets, a panhard rod chassis bracket, and two shock / coil towers with coil buckets.
