Page 5 of 5 FirstFirst 1 2 3 4 5
Results 81 to 89 of 89
  1. #81
    Thanked: 20097
    Default Re: Tata SFA conversion
    Updating this as I am using this as a central knowledge repository.
    Radius arm chassis side mounts are between 871mm and 882mm apart depending on whether you look at a D1/RRC chassis or a Defender chassis.
    This means my radius arm mounts need to be outside of the chassis rail but no further apart than 882mm to avoid putting tension on the bushes.
    The Tata chassis, measured 820mm backwards from the center of the front hubs, is 815mm apart.
    The hole in the radius arm chassis brackets are not flush with the chassis, the center of the hole is around 50mm from the chassis mount face.
    That means that center of hole to center of hole across the chassis would be maximum 915mm.
    I will need to MAYBE trim 15mm from each bracket to make it sit flusher with the chassis. Shouldn't be an issue.
    The mounting points for these brackets on the Tata chassis are just behind the gearbox crossmember, so no issues with the load deforming the chassis rails as the crossmember serves as a structural support.
    Another issue eliminated.
  2. #82
    Langs die rivier, op n berg
    Thanked: 6233
    Ons gaan nou in die lock down 2 merc sfa convertions doen
    Een net so op disco onderstel
    Die ander een, soos jy wil, met disco radius arms, onder Mercedes in. Maar ons gaan met safari voor as gaan. So moet dit nog maak pas.
    Wel, eintlik alles maak pas.... ons moet nog begin...
  3. #83
    Jun 2016
    Randfontein
    Thanked: 11879
    Lyk my jy kan enige part op enige ander kar werk.
    Jy is die ou wat dit sal regkry om n unimog onderstel onder n Mini in te bou.
    Old Wheeler
    2023 Mahindra S10 d/c 4x4 sponsored by Mahindra JHB South
    2010 Isuzu KB250 dteq d/c
    2023 Suzuki Ciaz (Swambos platkar)
  4. #84
    Thanked: 20097
    Hy Gaan een onder n safari sit
  5. #85
    Thanked: 6233
    Default Tata SFA conversion
    Unimog is onder safari in. My ander unimog sal ek maar unimog hou.
    Die merc vorder
  6. #86
    Thanked: 6233
    Iemand het dit gedoen
  7. The Following User Says Thank You to Reenen For This Useful Post:
  8. #87
    Oct 2006
    Thanked: 511
    that's a hilux front diff
  9. #88
    Thanked: 6233
    And rear. And engine
  10. #89
    Oct 2006
    Thanked: 511
