Easy way to blacken threaded rod?
Results 1 to 6 of 6
    [REMOVED]
    Thanked: 262
    Default Easy way to blacken threaded rod?
    Is there and easy way to blacken galvanized threaded rod ?
    I read up on Black Oxide using a special solution use in Cold blackening, you just drip it in and then take it out after a few mins.
    But I dont want it to rub off when touching it.
    Can it be done with electrolysis?
    Sep 2010
    Sasolburg
    Thanked: 114
    Default Re: Easy way to blacken threaded rod?
    Have it e-coated
    Sep 2010
    Sasolburg
    Thanked: 114
    Visit Kare Sheetmetal in Hermanstad.
    Their coroson protecion shop will help.
    durban
    Thanked: 1112
    The easiest way to blacken steel is to heat it and dip it in dirty engine oil. But if its galvanized I dont know.
    Thanked: 14158
    First acid etch the galvanising then use Plungers method: red hot into engine oil.
    Alternatively acid and then rust preventer like Russist which cures black.
    Or else the following:
    Zinc[edit]
    Black oxide for zinc is also known by the trade name Ebonol Z.[14] Another product is Ultra-Blak 460,[15] which blackens zinc-plated and galvanized surfaces without using any chrome and zinc die-casts.
    Thanked: 250
    Quote Originally Posted by Flee View Post
    I agree. Kare will e-coat it for next-to-nothing.
    2013 Tata Xenon 3.0 Dicor D/C
    2006 Honda Civic EXi FN2
