Metal Cuting Services
Results 1 to 20 of 25
    [REMOVED]
    Thanked: 262
    Default Metal Cuting Services
    Do you know of someone that will be able to cut 6MM Alumenium ?
    I need the below to be cut, I have the DXF available.
    Attachment 485895
    I tried contacting many local services that I found using google. Unfortunately only 2 of them got back to me and after submitting the drawings, Its just promises after promises to no re-sponse.
    I don't want any favors and I'm willing to pay what ever the going rate is to have this done., In future I might need to cut more but and dont want to hassle people..
    I think it has to be done on a HiDef Plasma cutter or Water Jet. As far as I understand alumenium gives Lazer a hard time and 6MM is quite thick for a Lazer cutter ?
    [OT] - Why is it that Lazer cant cut Alu as well as plasma and Water jet when it can cut mild steel just as well as other types of cutters ?
    Thanked: 14242
    Default Re: Metal Cuting Services
    Talk to Jacques Taljaard at Warriorworx, he has a contact in pretoria west
    [email protected]
    Phone: 074 208 0342
    [REMOVED]
    Thanked: 262
    Thanks Jelo.
    Their name rings a bell I think they made me Pipe doors for my jeep very long ago.
    Will give them a try.
    Mar 2007
    Thanked: 118
    You could also try Eezi Laser in Koedoespoort.
    I have used them ,they do good work and their lazer can cut up to 20 mm
    Alana Hamilton
    061 530 5289
    49 Gemsbok Street
    Unit 8
    Koedoespoort Industrial
    0186
    Gerhardt Olivier
    GWM H5 2.4
    Gwm 2.2 d/cab
    Always carry a knife, in case there is biltong or you need to stab someone in the throat.
    [REMOVED]
    Thanked: 262
    Thank you.
    I made use of Jelo's Contact's contact :-)
    If i dont come right I will contact them.,
    Thanked: 888
    Quote Originally Posted by SBSP View Post
    Attachment 485895
    that looks suspiciously like a PC case side panel...
    [REMOVED]
    Thanked: 262
    Its a Prusa i3 MK2 Printer frame.
  8. The Following User Says Thank You to SBSP For This Useful Post:
    JJB
    Thanked: 1291
    Attachment 485895
    6mm Ali is no problem for a laser.
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
    Thanked: 940
    Why dont you get it 3D printed? Not possible?
    Toyota Fortuner 2.8 GD-6 4x4 Auto
  11. The Following User Says Thank You to Caracal For This Useful Post:
    Thanked: 524
    If you bring the material to me I will cut it in my mill/router.
    I'm in Silvertondale.
  13. #11
    Jan 2015
    Vredenburg
    Thanked: 943
    Quote Originally Posted by Caracal View Post
    You cannot 3D print aluminium or metal as such. There are powder printers that you can bake the printed parts and get something similar to metal, but it's not that effective yet.
    Also you will pay R10 000 for the part if not more.
    This is the backbone structure of the Prusa I3 printer and if this is not done properly you will have months of agony and pain and hell on earth.
  14. #12
    Hillcrest, Malaysia
    Thanked: 6519
    The problem with a Laser in thick materials and precision cutting, as in 4mm dia holes is that the Laser cuts give a “slope” to all cuts due to Laser focus problems.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
  15. #13
    Jan 2015
    Vredenburg
    Thanked: 943
    What I also noticed when I had the X-Arm cut for my Ormerod, the localised heat generated from cutting holes in close proximity caused the part to warp so badly that they had to re-cut the part in marine grade Aluminium and only etch the hole position so that I had to drill them myself.
    For a part like this milling is really the best option followed only by waterjet cutting.
  16. #14
    Thanked: 85
    We had our prusa parts laser cut absolutely no problems.
    2011 Suzuki Jimny, Rocksliders (Bluerocket), Underbody protection (Stofpad), Roofrack (African Outback)
    Drawer System (self)
  17. #15
    May 2016
    Thanked: 64
    As has been said, laser cuts aluminium with ease and will be the cheapest by a long way compared with laser or CNC milling. Only problem is the holes you have. Having holes smaller in diametre than the thickness of the plate is always a problem. You may have to get them to scribe the hole centres and then you just drill the holes after receiving the part.
    Nissan Navara K/Cab 2010 4x4 2.5DCi
  18. #16
    Thanked: 1291
    Yes, on the small holes you just etch a centre mar and then drill it afterwards. The rule is that you do not cut holes with a small diameter than plate thickness.
  19. #17
    Nov 2016
    Thanked: 71
    Ek het ook deur hierdie oefening gegaan laasjaar. Ek het n hele klomp emails uitgestuur, en die enigste plek by wie ek terugvoer binne 2 dae gekry het was tubecon laser in Rosslyn. Hulle het baie goeie werk gedoen vir my.
    Rede hoekom die ouens nie Alu met n laser wil sny nie is as gevolg van sogenaamde flash back. Die ou van Roadque het my verduidelik dat alu baie meer geneig is om n flash te maak en jou laser op te neuk, wat dan n R200k oefening is om reg temaak. Dis baie makliker om dit the water jet en die kans op skade is baie minder.
  20. #18
    [REMOVED]
    Thanked: 262
    Thanks for all the replies.
    Maybe a stupid question. Will they be able to scribe the holes as is on the DXF file ? or do I need to indicate which parts need to be scribed ? Or will their machines have a setting to automatically do this ?
    I dont actually care what is used to cut it as long as its accurate.
    I have a drill press and dont have a problem drilling the holes myself.
  21. #19
    Jan 2015
    Vredenburg
    Thanked: 943
    They will basically engrave the hole with a lower power setting so just burning the position in and not full power cut.
  22. #20
    Thanked: 1291
    Rather ask them to engrave (etch) a centre mark in the from of a cross. Easier to centre punch that way.
  23. The Following User Says Thank You to Uys For This Useful Post:
