TD5 oil question
Results 1 to 17 of 17
    Oct 2014
    JHB
    Thanked: 20
    Default TD5 oil question
    My Td5 D90 is in-between service intervals but has been working hard lately so I'd like to do an oil + filters change.
    I would normally take it in to my indie but since it's just oil I'll do it myself.
    Is 10W40 the the correct oil?
    Fully synthetic or semi-synthetic?
    Going into winter now, is 10W40 fine for cold morning starts or will 5W40 be better? (I have read previous posts in this regard but am concerned about a noisy engine)
    Would appreciate some guidance
    Feb 2012
    Thanked: 13
    Default Re: TD5 oil question
    I use Shell Helix HX8 Synthetic 5W-40
    X5 3.0d
    D3 V8 SE
    Lotus 7
    Thanked: 431
    Find out what your indie uses and stick to that. I think it is better to stick to a certain type of oil and not alternate the whole time.
    Personally, I use Fuchs 5W40 synthetic. I supply my own oil for services.
    2004 Defender 110 Td5
    Feb 2012
    Thanked: 13
    Quote Originally Posted by Sawdust View Post
    +1 on stick with certain type
    +1, I supply or service myself
    X5 3.0d
    D3 V8 SE
    Lotus 7
    Thanked: 217
    Liqui Moly 15w-40
    2004 Defender TD5
    1992 Defender 3.5V8
    PROJECT OVERHAUL http://4x4community.co.za/forum/show...oject+overhaul
    Oct 2015
    Romania/Hungary
    Thanked: 137
    The best choice is to use a fully synthetic oil as to meet the temperature chart and choose one which is specified as suitable for EUI/PD engines... and those are mostly 5W40
    2000 Discovery Td5 ES manual, tuned
    Hawkeye v.6, Nanocom EVO,
    VDM UCANDAS, oscilloscope
    i DON'T ANSWER TO TECHNICAL QUESTIONS IN PM'S
    ALL MY ADVICES ARE BASED ON MY OWN EXPERIENCE AND MY WAY OF UNDERSTANDING THE DESCRIPTION AND OPERATION OF SYSTEMS... I'M NOT A LAND ROVER SPECIALIST JUST AN ADDICTED ENTHUSIAST
    Melkbosstrand
    Thanked: 427
    Quote Originally Posted by johannes14 View Post
    Liqui Moly 15w-40
    Lots of reports of the TD5 being louder after a cold start on 15W40 compared to 10W40
    Rob
    Series IIA 88" pickup
    Disco 2 ES TD5
    Disco 1 ES 300TDi
    Subaru impreza WRX
    Porsche Boxster S
    Shamrock Cobra 350
    Buell XB12R
    Oct 2015
    Romania/Hungary
    Thanked: 137
    15W40 is not even in the temp chart for the Td5... IMO it's completely unproper for it
  9. The Following User Says Thank You to sierrafery For This Useful Post:
    May 2010
    Greenstone
    Thanked: 351
    In your opinion and Land Rover but hey we have clever guys on here.
    My Td5 has never had anything other than 5w30 under warranty and Edge 5w40 from 100k and going strong at 205k now.
    Stick to what the person who designed the engine says.
    Discovery Sport 2.0i D
    Defender 90 LE Puma 2.2TDCI
    Defender 110 DC Td5 (life partners)
    Discovery 1 200 Tdi Auto
  11. The Following User Says Thank You to Byron For This Useful Post:
    Thanked: 217
    Quote Originally Posted by Hagu13 View Post
    Mine never had a problem yet How cold does it really get down in Melkbos strand
    Quote Originally Posted by sierrafery View Post
    I think you are comparing Europe temp to our temp down here !! It barely goes to minus 10 degrees , IF you are lucky
    Come visit during the winter , you will be surprised
    Nearly forgot , mine has got 260 000km on the clock . Bought from my son at 140 000 km
    2004 Defender TD5
    1992 Defender 3.5V8
  13. #11
    Oct 2015
    Romania/Hungary
    Thanked: 137
    I'm not comparing regions, that temp chart covers all the world cos 5W30/40 are good from below -30 to above +40 and the thickness of the oil will not help when the engine is hot anyway, it's mainly for cold start...IMO if the engine is noisy it must be fixed mechanically not filled with thin grease
  14. #12
    May 2010
    Greenstone
    Thanked: 351
    15W40 is the wrong oil for a Td5 but each to their own.
    As mentioned most of the wear is on start up so thicker more equals more wear.
    I based my decision on 5W40 on what Land Rover said,who built and tested the engine. What research or testing did you do to reach the conclusion that 15w40 is the one to go for?
  15. The Following User Says Thank You to Byron For This Useful Post:
  16. #13
    Thanked: 1204
    Don't only look at the grade, look at API as well, most of these fully synthetic oils are API C.F., this is 2002 standards, the latest standard is CJ-4, which is better suited to diesel engines. Ideally you'd want a 5-10w40 with a API CJ rating...I don't think they are available in SA. Delo does have a product that meets these specs 5w-40, synthetic, API CJ-4.
  17. #14
    Oct 2015
    Romania/Hungary
    Thanked: 137
    I dont know about that API thing but there are oils on which is specified that they are designed for PD/unit injector engines and that's what the Td5 is so IMO if it's something like this https://www.opieoils.co.uk/p-147529-...ngine-oil.aspx it's the best, see it's description... i've checked some oils with similar specs and all were API-SN/CF or SN/SM/CF
  18. #15
    Thanked: 217
    Quote Originally Posted by Byron View Post
    If it is wrong , it is wrong .
    No , I did not do any testing ! Just using it for a few years and done more than 100 000 km . That about sorts it for me !!
    2004 Defender TD5
    1992 Defender 3.5V8
  19. The Following User Says Thank You to johannes14 For This Useful Post:
  20. #16
    Melkbosstrand
    Thanked: 427
    Not cold at all. In winter the Atlantic is warm and my house is 200m away so close enough to feel the effect. My garage is insulated and sealed, with tiled floors. I would reckon it never goes below 10 degrees in there. It's not Isuzu loud on the thick stuff, but the difference is very noticable.
    Rob
    Disco 2 ES TD5
    Disco 1 ES 300TDi
    Subaru impreza WRX
    Porsche Boxster S
    Shamrock Cobra 350
    Buell XB12R
  21. The Following User Says Thank You to Hagu13 For This Useful Post:
  22. #17
    Oct 2014
    JHB
    Thanked: 20
    Took your advice and contacted my indie. Did my oil change with the exact oil that has been previously been used.
    Thanks everyone
  23. The Following User Says Thank You to miks. For This Useful Post:
