Does Tyre Diameter make a Difference?
Results 1 to 11 of 11
    JBay
    Thanked: 238
    Default Does Tyre Diameter make a Difference?
    The below findings were from a test done by Australian 4WD Action.
    Test vehicles: TD HiLux DC 2" lift and decked out for touring.
    1st Test to compare; 29" standard tyres against 31" tyres :
    Driven distance, 29" / 31" Tyres
    SAND: 13.7m / 25.4m
    MUD: 4.5m / 5.8m
    Rutted Hillclimb: 11.2m / 14.6m
    ROCKS: 1m / 4m
    Test 2, 31" vs 33" Tyres
    Driven distance, 31" / 33" Tyres
    SAND: 25.2m / 48.3m
    MUD: 5.8m / 7m
    Rutter Hillclimb: 14.6 / 15.3
    ROCKS: 4m / 4.5m
    Patrol TB48
    Patrol TD42T
    Ex-4x4-partners:
    105 Cruiser
    80 Cruiser
    60 Cruiser
    Tdi Defender
    2.8D Hilux
    http://4x4africa.co.za/
    Apr 2018
    Fraserburg
    Thanked: 589
    Default Re: Does Tyre Diameter make a Difference?
    I'm not sure what the figures mean? Can you give an explanation?
    For example; -
    SAND: 13.7m / 25.4m
    MUD: 4.5m / 5.8m
    ROCKS: 1m / 4m
    The figures appear completely meaningless unless the context is provided?
    Jul 2013
    cape town
    Thanked: 624
    http://www.4wdaction.com.au/ultimate...size-shootout/
    here is a very good test they did on tyre size.
    Bigger tyres have there pro's and cons
  4. The Following User Says Thank You to Ocin For This Useful Post:
    Mar 2013
    Thanked: 346
    Thanks for that article, was a very interesting read....
    Pieter Greyling
    ONE LIFE, LIVE IT!
    ORRA: Z85
    -Land Rover Defender 110 Td5
    -BMW G650 xChallenge
    Thanked: 339
    Very interesting read, thanks for posting! I think the old analogy holds true, a vehicle is always a compromise and the more you mod it to suit on purpose the worse it performs on the rest of the purposes. Big tires are good for off roading but not so good for fuel consumption, handling and braking.
    JBay
    Thanked: 238
    For example; -
    SAND: 13.7m / 25.4m
    MUD: 4.5m / 5.8m
    ROCKS: 1m / 4m
    Distance traveled in Sand with 29" tyres was 13.7 meter before it got stuck.
    Same stretch of sand driven with 31" tyres, took 25.4 meter before it got stuck.
    Therefore larger diameter wheels/tyres was an improvement of 11.7 meter in sand
    And so it goes for the rest of the comparison and also for the 31" tyres vs the 33" tyres.
    With some obstacles there is a lesser gain with larger diameter than other...
    Patrol TB48
    Patrol TD42T
    Ex-4x4-partners:
    105 Cruiser
    80 Cruiser
    60 Cruiser
    Tdi Defender
    2.8D Hilux
    JBay
    Thanked: 238
    Sometimes the problem with many of these tests are more variable are added than just say diameter. The tests I quoted did not specify the increase or decrease of width, it only says the diameter size.
    The link posted by Ocin; the 3 tyre sizes used were higher and wider, making for a lot of change form one size to another.
    The other variable is inflation pressures. When you use the same pressure between all the sizes, it might not be the better pressure for that tyre/vehicle combination...
    Since tests like these cost money and lots of time, you very seldom see them done in SA. Maybe if everyone on the 4x4 Community throws in R10 we can do our own tests.....
    Patrol TB48
    Patrol TD42T
    Ex-4x4-partners:
    105 Cruiser
    80 Cruiser
    60 Cruiser
    Tdi Defender
    2.8D Hilux
    Feb 2015
    Noordhoek, Cape Town
    Thanked: 2450
    I don't know why they do these tests when everyone knows what the results will be. The 4x4 fraternity is not stupid.
    JBay
    Thanked: 238
    Chris, I agree with you up to a point. There are many myths out there, and many people follow them blindly, even by some more seasoned 4x4'ers. Some are true, others not so true.
    I find tests interesting, but only when done "correctly", otherwise it might add to an existing myth.
    I was part of a group that did a test to see what loads are involved during a snatch recovery. It was interesting to see the mixed reactions; some thought it was as expected, others thought it would have been higher, giving the circumstances, including the seasoned 4x4 fraternity....
    Patrol TB48
    Patrol TD42T
    Ex-4x4-partners:
    105 Cruiser
    80 Cruiser
    60 Cruiser
    Tdi Defender
    2.8D Hilux
    Feb 2015
    Thanked: 2450
    Kiri, that snatch recovery loads will me be most interesting! It is also of the utmost importance to have an idea what those figures are. We do snatch recoveries without realizing what happens really.
    JBay
    Thanked: 238
    Quote Originally Posted by Chris Stoffel View Post
    Chris, I'll start a new thread under Recovery....
    Patrol TB48
    Patrol TD42T
    Ex-4x4-partners:
    105 Cruiser
    80 Cruiser
    60 Cruiser
    Tdi Defender
    2.8D Hilux
  13. The Following User Says Thank You to Kiri For This Useful Post:
