Flashlube Diesel Filter
Results 1 to 5 of 5
    Jul 2017
    Default Re: Flashlube Diesel Filter
    Price compared to RACOR?
    Sounds good if used as a pre-filter. Looks very similar to Racor. Will thus depend what type of vehicle it will be fitted to. On Puma Defender almost impossible to fit a pre-filter - as the OEM filter just about fills the whole area below the filler tube - especially if you have the additional Frontrunner fuel tank fitted. I fitted the Racor with 2 micron filter cartridge as a secondary filter in the left side engine bay - very convenient place to replace cartridge and check for water contamination - but sofar never had to clean out any water. Right rear primary OEM filter is replaced every 20 000 km service interval - “prevention better than cure”. Suppose you could fine something similar in ZA?
    Centurion, Pretoria, SA
    Certainly seems impressive. The big question would be the price.
    SOMETIMES I WAKE UP GRUMPY,
    Jul 2013
    Thumbs up Re: Flashlube Diesel Filter
    Google icermax, they are locally manufactured units that do exactly the same thing. there are two types for vehicles, one with a priming pump, at about R1900, and one without a pump at about R1200.
    09 Kyron, the Korean Snail.
    NO Meeow!
    Blanked EGR.
    Thermo Electric Cooling fan.
