Discovery 4 5.0L V8 problem
Page 1 of 8 1 2 3 4 5 6 7 8 LastLast
Results 1 to 20 of 147
Thread: 5.0L V8 problem
    Thanked: 327
    Default 5.0L V8 problem
    May 2010
    Greenstone
    Thanked: 344
    Default Re: 5.0L V8 problem
    Nope but I was warned that abused ones tend to "stretch"
    their timing chains, more than likely it was the guides as this guy says.
    Discovery Sport 2.0i D
    Defender 90 LE Puma 2.2TDCI
    Defender 110 DC Td5 (life partners)
    Discovery 1 200 Tdi Auto
    Oct 2006
    Thanked: 152
    Never had it on my V8, also never heard of it on the forum.
    Looking at the forum I would have thought the water pump is the most common problem on the V8, not the timing chain guides as these guys claim.
    Current: Touareg V6 TDi
    Ex: Discovery 4 V8 - Sold at 149 000 km. Awesome vehicle, but a bottomless pit.
    Ex: Fortuner D4D - Best vehicle I've owned Sold at 267 000 km.
    Ex: Hilux 2.7i - sold at 241 000 km.
    Ex: Hilux D4D - sold at 330 000 km.
    Thanked: 327
    Quote Originally Posted by 4xhilux View Post
    Exactly my thoughts.
    Just replaced the water pump again at 120k km as a precaution.
    May 2010
    Greenstone
    Thanked: 344
    There alot more V8s in the States so will be more common there if it is a problem.
    Apr 2011
    Thanked: 1055
    Searched the interwebs and found basically nothing about this in the V8 D4/ LR4 as the Yanks call it.
    Thanked: 196
    It does happen. But more common among the Supercharged versions.
    Last year alone the workshop saw about 23 Supercharged versions vs 1 Naturally aspirated V8 with stretched chains and/or worn guides
    2005 Land Rover Discovery 3 V8 (Will allways end up with an V8)
    1967 Land Rover Series 2A 3.5 V8 (The Green Machine)
    196? Land Rover Series 2 V8 100" (The Coiler)
    2007 Subaru Forester XT 2.5T (The Daily)
    Ex.
    Discovery 1:TDI and a V8. Discovery 2 V8. Discovery 3 TDV6.
    Freelander 2 TD4
  8. The Following User Says Thank You to JeandreDiedericks For This Useful Post:
    Mar 2016
    Durbanville, Cape Town
    Thanked: 27
    Quote Originally Posted by JeandreDiedericks View Post
    Thanks Jeandre, what would be the ballpark figure to do a job like that.
    Thanked: 451
    Hi oradba69
    this phenomenon is well known among other manufacturers (MB etc) especially on very powerful engines. the M120 V12 is known to snap (simplex) timing chain once past 100'000km and some of the V6 motors too suffer from timing chain and/or sprocket wear.
    I would suggest as a matter of preventative maintenance to change the timing chain around 100'000km. Yes this is not cheap, but much much cheaper than to repair an engine, once the chain has snapped or jumped some teeth. If done in time one might get away without changing the guides.
    On my MB 500SL's the timing chain (duplex) has to be changed every 200'000km.
    The guy in the video, Storey Wilson is the creator of the RSW Solutions (TM) Diagnostic Software, which I use on the FFRR Td6.
    George Bosch
    Distributor for:
    Thanked: 451
    Quote Originally Posted by Byron View Post
    Hi Byron
    guide damage is normally as a result of "slapping" chains, i.e. a consequential damage.
    George Bosch
    Distributor for:
    Dowerglen
    Thanked: 721
    Quote Originally Posted by BuckRogers View Post
    Also keen to know, if I remember well its a +10hr labour job if not more.. I think I might have the same issue on mine, pretty noisy on idle, not sure if its normal, the supercharger coupling or the timing chain guides.., all I know is my 4.2 ran a lot quieter..
    Don't have the energy to do this job myself, and camshaft locking tools are needed as well...
    Every dog has its day, and those with broken tails have their weak-ends...
    1976 CJ-7, 400CI + Holley EFI, Tera-Low 3,15:1 twin stick, ARB's front & rear, oil leaks & plenty more....
    All my other petrol burners are boring....
    Thanked: 451
    Quote Originally Posted by Marcochezzi View Post
    Hi Marcochezzi
    on the Mercs we split the chain, splice the new one in and feed it through, that way the front covers don't have to be removed. I have done 4 such jobs already over the years on V8 500 and 560 motors (M117).
    Would be interesting to find out, if this is possible with the 5.0 V8. Walter (LRXtreme) might be able to advise on that.
    George Bosch
    Distributor for:
    Jul 2010
    Modders
    Thanked: 251
    on the 5.0SC it is the guides that wear normally, this was apparently resolved late MY10. there are however instances of the actual chain stretching with exsessivly hard use.
    Range Rover Sport 5.0 SC
    Lotus 7 replica racecar.
  15. #14
    Thanked: 196
    R60k+ at Dealership prices and labour.
    Hi Marcochezzi
    I think it might be a bit difficuilt with these. Probably not impossible but swear words will be used. And if the chains are stretched all 4 pulleys on the cams need to be replaced as well.
    Labour intensive, yes. Fastest Ive seen it done was 2 days. Drive in early in the morning, drive out the next day at 5.
    Ex.
    Freelander 2 TD4
  16. #15
    Jul 2010
    Modders
    Thanked: 251
    So around 15-20k at a good Indy?
  17. #16
    Apr 2011
    Thanked: 1055
    Whish I could find a video on the net of how this sounds on a NA 5LV8.
    Can only find vids of SC’s.
    I do not think the NA V8’s seems seriously affected.
  18. #17
    Forest Hills, KZN
    Thanked: 793
    Quote Originally Posted by Regard View Post
    Very curious to know more about this also.
    2003 LR Discovery 2 Td5 ES - mods list to be updated [Husky]
  19. #18
    Thanked: 451
    the reason why mainly SC version of 5L V8 are affected has to do with the much more abrupt increase in revs which puts extra strain on the valve train components.
    Higher stress loads result in higher wear and tear, actually quite simple.
    George Bosch
    Distributor for:
  20. #19
    Forest Hills, KZN
    Thanked: 793
    Looks like I have this issue. Drove the car to indy this morning to get viscous fan replaced as it was making a heck of a noise and it was fine when driving there.
    While car was at indy, started and got 'restricted performance'. Error message being thrown is P0016. Haven't diagnosed the main ticking noise as the engine is naturally quite loud but there is a rough idle every now and then.
    Not sure what the outcome is as it only happened this afternoon, but will feedback here. I'm hoping it's just a sensor but I guess we'll see.
  21. #20
    Apr 2011
    Thanked: 1055
    Nee man Douglas
    Probably just sensor.....esp considering all your mud bathing.
    I had a P0018 code a few months ago. Reset the code and never came back.
