How does one change a front wheel on a raised Fortuner/Hilux
Results 1 to 20 of 35
    Morgan Bay
    Thanked: 45
    Default How does one change a front wheel on a raised Fortuner/Hilux
    I dont know if I am just stupid or not,
    but some time back while camping at Etosha Pan.
    I woke up one morning to find I had a flat front tyre on my 2007 Fortuner, (it is raised by 50mm)
    No problem I thought, this wont take long to sort it out. Well to cut a long story short, about two hours later after trying my jack, my friends jack, another guys jack, a Jack from a truck, The owner of the camping grounds eventually fetched a trolley jack, and I was able to swap the wheel,
    Now my friend who drives a Hilux also raised by 50mm has just had the same problem,
    I know one could used a Hi lift jack, but I don't like them, and also don't want to drive around with one permanently attached to the roof rack of my car.
    I see plenty Fortuner's and Hilux's driving around with a raised suspension and not carrying a hi lift jack.
    How do change there front wheel?
    Can anyone please help.
    swakopmund
    Thanked: 1310
    Default Re: How does one change a front wheel on a raised Fortuner/Hilux
    Lift to max. Put stones or sparewheel under lowest point. Put stones or wood under jack. Start lifting again. Repeat if necc
    Thanked: 182
    You get bottle jacks in various sizes and bottle jacks are fairly priced.
    Just remember, the bottle jack must be SMALL enough to still fit when the tyre is flat.
    I would look into getting a foldable axle stand as well. Hydraulic jacks have a habit of failing catastrophically!
    Make yourself a baseplate as well. Most jacks do not work well on soft ground.
    PS My Isuzu came with a mechanical bottle as standard.
    Isuzu Frontier 280LX 4x4 2001
    Feb 2015
    Noordhoek, Cape Town
    Thanked: 2450
    Scissor jack with a 50mm thick piece of plank bolted to it. ??
  5. The Following User Says Thank You to Chris Stoffel For This Useful Post:
    Klipriver
    Thanked: 239
    Quote Originally Posted by RogueFrontier View Post
    Not wanting to pick an argument/ fight, but I have never had a bottle jack fail on me. And we have used them extensively on trucks, cranes, and cars. Every vehicle that I have owned has had the original jack replaced with a bottle jack
    Alan
    _________________
    Range Rover P38
    Series 3 109 SW (Tortoise)
  7. The Following User Says Thank You to Alan Eveleigh For This Useful Post:
    Oct 2012
    Thanked: 219
    That Mighty Amarok
    Swart Tires wat ek self gekoop het
    Pull over wat my ouma gebrei het
    Vensters waar deur ek kan sien
    Engine voor
    Exhaust agter
    Thanked: 10618
    One assumes one was jacking up the FRONT LOWER CONTROL ARM and not the BODY.................
  10. The Following 8 Users Say Thank You to jelo For This Useful Post:
  11. #8
    Nigel
    Thanked: 2105
    With a trestle, a hilift and a wheel buddy.
    When you are done, just drive off the trestle.
    Uniglide
    +27 zero eight 2 four 95 9252
  12. #9
    Oct 2017
    Rustenburg
    Thanked: 1288
    Quote Originally Posted by All -in -one View Post
    Me too.. wonderful tool a bottle jack. And a block of wood
    _______________________________________Dum vivimus, vivamus!With a mild case of "Camping Personality Disorder" or CPD I drive a five cylinder bakkie and tow an army inspired van.
  13. #10
    Oct 2017
    Rustenburg
    Thanked: 1288
    So you un-jack it after trestle?
  14. #11
    Thanked: 182
    Neither have I, but it does happen that a seal pops. Personally, I would rather spend a few bucks more than risk life and limb.
  15. #12
    Morgan Bay
    Thanked: 45
    Thanks guy's for all your ideas,
    It has given me lots of food for thought
  16. #13
    Thanked: 987
    That's how I always did it on the D3 with it's ?intelligent? suspension...
    Stay Safe
    Disco-Deon
    This morning I woke up,
    Making today a great day.
    Nerdy, 2011 Honda Jazz, 1500 Exc
  17. #14
    Wartburg.
    Thanked: 495
    Also not picking an argument, but you say spend a few bucks more.
    What jack is better than a bottle jack?
    I'm asking because it's the most common jack used on the farm, bottle jacks and trolley jacks, basically the same thing, hydraulic jacks
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
  18. #15
    Cape Town, Plumstead/The Sea/Franskraal
    Thanked: 457
    Did you try to pump the tyre up?
    Have now covered 270 000Km on veg oil.
    Oh, and an Isuzu 280DT, 40 000Km on Bio Diesel
    Rand for Rand gets 33Km/L
  19. The Following User Says Thank You to ZuluCowboy For This Useful Post:
  20. #16
    Thanked: 114
    Quote Originally Posted by Skallywag View Post
    You basically get two types of bottle jacks. Mechanical bottle jack (like in Hilux and Isuzu) and hydrolic bottle jack.
    I do not like the hydrolic bottle jacks as they have failed me in the past.
    I carry a spade and 20 empty sandbags in my Hilux at all times and one use for this simple but very useful recovery equipment is to put it under the bottle jack if it tend to be a little to short for a lifted suspension.
    Sandbags are cheap, weighs next to nothing and take up very little space in the vehicle. And don't worry, there will be sand gravel or mud when you need to fill the bag. And it will not easaly sink into sand or mud. A life saver if you do not have rocks or bushes at hand like in the middle of a dune field or a pan.
    It is a very versatile peace of equipment in any 4x4 and can be used for many many purposes. And you can re-use them.
  21. The Following 9 Users Say Thank You to Viertrek For This Useful Post:
  22. #17
    Morgan Bay
    Thanked: 45
    The problem is that the lower control arm is at a angle, so the jack slides off,
    My friend made each of us a cap that goes over the top of the jack with a pin that goes through a hole in the arm(see photo) this works perfectly on his Hilux,
    But the Fortuner is a 2007 and has 16 inch rims and bigger side walls on the tire, so the jack cant fit under it.
    As you can see in the photo the tire is deflated but the rim is still well off the ground
    I know I can lug a piece of plank around and drive the wheel onto it, But if possible I would prefer not to do that
  23. #18
    May 2016
    Thanked: 2797
    Lay the spare in front of the flat wheel.
    Drive carefully onto it with the flat wheel.
    The flat wheel's suspension will now probably be a bit higher than that of a inflated wheel.
    That's how you get a jack under a caravan's axle as well.
    2006 VW Touareg V10 TDi
  24. The Following 2 Users Say Thank You to 4eTouareg For This Useful Post:
  25. #19
    Wartburg
    Thanked: 1148
    My situation has an overlap with this topic: My 255/100R x 16 tyres are high profile. A puncture basically drops the vehicle/axle by 255mm. So a low profile 2 stage hydraulic jack is supplied with the truck. This works fine on normal surfaces, but can force you to make a plan by jacking in stages using rocks etc.
    I bought a second 2 stage jack from Midas. This makes jacking up easy using both in stages to get the required height for fitting the replacement
  26. #20
    Thanked: 2329
    Have a cup welded onto lower control arm. Long reach bottle jacks. Midas sells them. Simple.
