Nissan navara 2.5d lost the power
Results 1 to 16 of 16
    Apr 2018
    Default Nissan navara 2.5d lost the power
    I recently changed the clutch plate kit on my nissan navara, then after that it's started to lost the power and the engine light is on, I also checked 2 sensors, and they are fine .I went to the diognosis machine and it's says FUEL PUMP. Anyone with more information please help me before I but buy another
    Diesel pump
  2. The Following User Says Thank You to Mbonambi For This Useful Post:
    Feb 2015
    Noordhoek, Cape Town
    Thanked: 2450
    Default Re: Nissan navara 2.5d lost the power
    Hi Mbonambi. Post in the Nissan section. The guys will see it and help you.
    Welcome!
    The Windy City
    Thanked: 3010
    Moved to NISSAN
    Feb 2018
    Durbanville,
    Thanked: 28
    Please post some more info. Did the diagnostic unit say anything other than fuel pump?
    Apr 2018
    The diognosis machine, only shows the FUEL PUMP
    Apr 2018
    The car is moving but it does not have power, the engine is running smoothly, start nicely but on the rev count it only end @30 not more than that.on the hills it's forced you to use gear 1 or 2.
    Jul 2014
    Boksburg
    when was the last time the diesel filter was replaced?
    Manie
    Feb 2018
    Durbanville,
    Thanked: 28
    It may be a silly suggestion but have you tried the ECU and fuel pump reset procedure?
    To carry out the reset carry out the following
    Turn ingnition on so all dash lights come on.
    Wait 3 seconds
    PUMP accelerator pedel 5 times within 5 seconds....
    with foot now OFF accelerator wait 7 seconds...
    After 7 seconds press and hold down accelerator pedel for 10 seconds...
    Atfer 10 seconds the Engine Managment Light will start to flash, at this point remove foot from accelerator.
    the Nav is now in diag mode, so let the EML flash for a bit. the press and hold the acclerator pedel down for more than 10 seconds..this will then reset ECU and fuel pump etc......and put them into learning mode.
    NOTE: When the EML light is flashing, this is listing possible fault codes... so if you know how to read the fault codes or know the sequences then you can figure out any possible faults with your Nav with out getting the dealer to do it!!
    Apr 2018
    A diesel filter I replace it recently and it was very dirty.
    Apr 2018
    The main thing is this engine light is on since it started to lost power
    Thanked: 10261
    Quote Originally Posted by Mbonambi View Post
    you obviously have a fuel pressure issue: but the ECU can't tell if that is a clogged filter, an air leak, or a bad pump
    I strongly suggest a decent mechanic otherwise you will replace stuff you don't need to.
    A Bosch Diesel workshop will understand how to work on the Navara.
  13. The Following User Says Thank You to jelo For This Useful Post:
  14. #12
    Thanked: 10261
    but you don't see the very obvious cause and effect here?
    you have an engine light on AFTER you replaced a filter?
  15. #13
    Apr 2018
    Engine light on after replacing clutch plate
  16. #14
    Thanked: 1026
    Have you checked to make sure everything was plugged back in after the clutch job?
  17. #15
    Apr 2018
    I did check the 2 sensors, top and bottom, but they are fine
  18. #16
    Apr 2018
    Where can I get a Bosch Diesel workshop? Because I'm around Johannesburg
