Removal of aftermarket plastics
Results 1 to 20 of 23
    Brackendowns
    Default Removal of aftermarket plastics
    Please can someone advise on the best way to remove glued on aftermarket plastics.
    Jul 2013
    cape town
    Thanked: 626
    Default Re: Removal of aftermarket plastics
    I would think with a piece of fishing line.
    then sand down and respray bonnet.
  3. The Following User Says Thank You to Ocin For This Useful Post:
    May 2015
    I would also use a fishing line to remove the plastic and the clue i used degreaser with water and cloth to rub the glue of
    Worked for me and Touch wood no damage to paint
  5. The Following User Says Thank You to Wit_buffel For This Useful Post:
    Jul 2007
    Putfontein, Benoni
    Thanked: 1978
    Pledge does a decent job of the left after sticky glue as well and does not scratch your car or damage the paint. Spray on - let it sit for a bundle of minutes and then lot of elbow grease with a soft rag.
    VW Touareg - 2005 - V10 TDI
    VW Touareg - 2009 - V6 TDI
  7. The Following User Says Thank You to Stephan van Tonder For This Useful Post:
  8. #5
    Mar 2016
    Thanked: 2029
    But, it adds 5kw per plastic add-on.
    and it looks cool and it makes it go fast.
  9. The Following 2 Users Say Thank You to Oppies3800 For This Useful Post:
  10. #6
    Mar 2018
    Randfontein
    Thanked: 142
    I assume its similar to removing stickers.
    Heat it up slightly with a hairdryer and then when the glue becomes soft, pull the part off.
    Take some furniture polish, spray on, let it sit for a bit and then get the excess off
  11. The Following 2 Users Say Thank You to MartinBravo For This Useful Post:
  12. #7
    Klipriver
    Thanked: 247
    Do you perhaps know what type of glue was used?
    Alan
    _________________
    Range Rover P38
    Series 3 109 SW (Tortoise)
  13. #8
    Brackendowns
    Quote Originally Posted by All -in -one View Post
    No idea?
  14. #9
    Brackendowns
    Quote Originally Posted by Wit_buffel View Post
    I am hoping I can get away with the same
  15. #10
    Brackendowns
    Quote Originally Posted by Oppies3800 View Post
    Clearly thatís what the previous owner had in mind too.
  16. #11
    May 2016
    Thanked: 2899
    Penetrating oil works well (Q20, WD40 etc).
    It breaks the bond between the glue and the paint, softens the glue, and most importantly, does not damage the paint.
    Work in a cool shady place, and be patient.
    Do not try any solvent (many degreasers contain solvents).
    2006 VW Touareg V10 TDi
  17. The Following User Says Thank You to 4eTouareg For This Useful Post:
  18. #12
    Mar 2016
    Thanked: 2029
    Double sided tape
  19. #13
    Thanked: 147
    Hopefully double sided tape was used.
    Try heating it first with a hairdryer. I use Holts tar remover to remove glue residue from stickers.
    "The whole problem with the world is that fools and fanatics are always so certain of themselves, but wiser people so full of doubts" : Bertrand Russell
    2014 Nissan Navara 2.5 4x2
    1995 Nissan Sani 3.0 V6 4x4
  20. The Following User Says Thank You to staalwol For This Useful Post:
  21. #14
    Thanked: 871
    As a proud Ranger owner this thread embarrass me - because its always a Ranger owner losing the plot.
    When you do that to a car you have issues.
    Hope you get sorted!!
  22. #15
    Brackendowns
    Quote Originally Posted by Rustie View Post
    Agreed, hopefully I can get it cleaned up soon.
  23. #16
    Brackendowns
    Double sided tape
    Seems like DS tape AND silicone sealant
  24. #17
    May 2016
    Thanked: 2899
    Quote Originally Posted by Alex_ZA View Post
    Silicon is resistant to just about anything, so you have to break the bond between it and the paint.
    Try penetrating fluid / oil.
  25. The Following User Says Thank You to 4eTouareg For This Useful Post:
  26. #18
    Mar 2016
    Thanked: 2029
    So previous owner had the embarrassment of the plastic gone missing before. Good.
    Lol, hope you get it off without damage
  27. #19
    Jul 2010
    Pinetown
    Thanked: 1312
    Silicon is the worst !!
    If anyone has the solution to removing silicon gel from paintwork without hurting the paintwork I suggest patenting it and marketing - there must be many potential customers out here !
    Otherwise I agree with the comments re hair driers etc. if used with care.
    ISUZU KB 280 DT LE NOW POWERED BY THIS AMAZING COMMUNITY
    Platkar = Chevy Spark 1.2
  28. The Following User Says Thank You to Peter1949 For This Useful Post:
  29. #20
    Brackendowns
    Thanks everyone for the good advice. Thanks to you and significant elbow grease the bonnet is back to the way it was intended.
