Echo Chobe ordered - Page 4
Page 4 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 61 to 80 of 146
  1. #61
    Nov 2017
    Alberton / Marloth Park
    Default Re: Echo Chobe ordered
    Contact Echo 4x4 directly - they are available as a modification or you can purchase them and do the fitment yourself........expensive though. The problem is that you are left with the old step's bracket on the rear door.
  2. #62
    Okahandja, Windhoek
    Theo yes , just a bolt on. That step hanging on the door is a 'no go' anyway off road.
    Will check whats possible with the remaining brackets on the door.
    I see the Chobe tec with that fancy stove took a lot of storage space away at the opposite door, due to the longer fridge slide. Just something to consider when buying.
    Johan Kriel
    LC's and Echo Chobe
  3. #63
    Okahandja, Windhoek
    Another thing, still that same storage compartment, the shelve for the upper space is made of a thin metal sheet and cant take much weight on it. It started to shear in the corners. Bottles, tins etc must rather be put in the bottom area. I strengthening it a bit.
    Johan Kriel
    LC's and Echo Chobe
  4. #64
    Apr 2008
    Irene, Pretoria
    Johan, which storage area are you referring to? The one behind the fridge?
    '15 Prado 4.0 VX
    '18 Echo Chobe
  5. #65
    Okahandja, Windhoek
    Quote Originally Posted by HennieC View Post
    Correct!
    Johan Kriel
    LC's and Echo Chobe
  6. #66
    Boksburg
    Is hierdie deel van die water sisteem op die Chobe's.
  7. #67
    Okahandja, Windhoek
    Dis reg, dink dit gaan na die krane wat by die geyser koppel.
    Johan Kriel
    LC's and Echo Chobe
  8. #68
    Boksburg
    Dankie Johan
    As als goed gaan behoort ek dalk die week ook een te he.
    Is jy nog "happy" met joune
    Groete,
    Drikus
  9. #69
    Okahandja, Windhoek
    Ja, baie happy. Laas jaar n trip na Khwai en Moremi gedoen, Sleep baie lekker en geen issue oor daai slegte paaie nie, behalwe die rak soos hierbo genoem wat bietjie gekraak het met al die bier en koeldranke op dit. Ek het dit versterk, maar hou maar hou maar die swaar goed op die onderste rak.
    Al ander issue is natuurlik die hoogte in die battery spasie. Nie alle 100ah battery pas daar in nie, weens die beperkte hoogte van ongeveer 220mm, en niks groter as 100 ah ook nie. Jy kan ook nie die vloer van die battery box laat sak nie wat dit sit regop die chassis, maar 100/105Ah is eintlik genoeg. Maak net seker jyt genoeg laai vermoe vir wat jy gebruik. Hy kom met n 80ah battery.
    Johan Kriel
    LC's and Echo Chobe
  10. #70
    Boksburg
    Dankie Johan
    Die een wat ek wil koop het darem 2 x 75aH klaar in so ek dink vir nou sal dit genoeg wees. Sien baie uit na dit
    Groete
    Drikus
  11. #71
    Okahandja, Windhoek
    Quote Originally Posted by Dp123 View Post
    Dankie Johan
    Groete
    Drikus
    Kan jy my n foto stuur asb van dit, ek wil myne verander. 2 x 75 sal goed werk.
    Johan Kriel
    LC's and Echo Chobe
  12. #72
    Boksburg
    Hi Johan
    Ek maak so vir jou as ek hom wel het, ek weet die ander battery sit aan die linkerkant as jy by die deur inklim
  13. #73
    Boksburg
    Nog n vraag vir die Chobe eienaars as dit hard reŽn veral skuins,reŽn/lek dit in by die slaap gedeeltes en is hoe is die kondensasie binne die wa.
  14. #74
    Apr 2008
    Do you not find the door entrance and exit difficult in the Chobe?
    Looked at one and very nice,but getting out from the inside seems uncomfortable.
  15. #75
    Okahandja, Windhoek
    Hi Johan
    Ok , wou net sÍ om beide regs te sit gaan maar lol. Dankie
    Johan Kriel
    LC's and Echo Chobe
  16. #76
    Okahandja, Windhoek
    Ons het reent gehad Sept in Moremi, maar geen issue nie, maak net seker al die flappe is reg gevou. Ek het daai flysheets? by gevat vir die binnekant, dink dit sal baie help.
    Quote Originally Posted by schoemie View Post
    If the roof is raised than its not so bad to enter or exist. Is not bothering me, being 5' 7"
    Johan Kriel
    LC's and Echo Chobe
  17. #77
    Boksburg
    Default Re: Echo Chobe ordered (and some mods)
    Toe volg iets my huis toe gister.
    Prentjie aangeheg vanndie extra battery Click image for larger version.
ID:	519071Click image for larger version.
ID:	519072Click image for larger version.
ID:	519073Click image for larger version.
  18. #78
    Nov 2017
    Baie geluk, ek is baie gelukkig met my Chobe
    Geniet en hou ons op hoogte na jou eerste kamp
  19. #79
    Boksburg
    Dankie baie. Alles is reg vir ons eerste kamp die naweek besluit nog tussen drie plekke.
  20. #80
    Boksburg
    Hoeveel palle moet die awning he?
