Amarok heavy duty leaf springs
Results 1 to 20 of 34
    Thanked: 47
    Default Amarok heavy duty leaf springs
    Hi
    If I recall you can choose between a 3-leaf comfort and a 5-leaf heavy duty spring option for the rear of the Amarok. If I recall, there is no cost difference if specified in time.
    Does anyone on the forum have the 5-leaf setup on a double cab? I am interested to know if the ride is much harder or close to not noticeable. Any input?
    Thanked: 97
    Default Re: Amarok heavy duty leaf springs
    I have the 5 pack heavy duty blades on my Amarok. The ride quality is more firm than with the 3 blades especially when you don't have any permanent accessories on the rok. I always have the RSi canopy, long range fuel tank and bakkie slide in/on which makes the heavy duty blades worth it.
    Just have a look at the optional extras on the new Amaroks, I think you now have to pay for the upgraded GVM (5 pack).
    4x4 Groete
    Albert de Villiers
    Amarok BiTDi 4Motion
    Youtube Channel
    www.andre4x4.co.za
  3. The Following User Says Thank You to Trebla For This Useful Post:
    Aug 2014
    Oppi plaas
    Thanked: 868
    VW quoted R1053.00 excl. Vat a few months ago. I decided to go with the standard 3 blade spring pack and have no regrets. Ride quality is very good and the vehicle doesn't sag when loaded and with my camp trailer hitched.
    I know a guy who decided to take the 5 blade option and had VW remove it and replaced with the standard springs at a huge cost. He doesn't really load heavily and said the ride was really harsh.
    2017 Amarok Extreme V6
    2014 Jeep Wrangler Rubicon
    2012 LR Puma 2.2
    2012 LR Puma 2.2 D/c
    2011 LR Puma 2.4
    1976 LR Series 3
    1971 LR Series 2A
  5. The Following User Says Thank You to Bosvark Kzn For This Useful Post:
    Feb 2007
    melkbosstrand
    Thanked: 137
    I have the 5 blade setup.
    The standard 3 blade cant handle 500kg, for my use it is too soft. Bloody comfy, but too soft. I've seen a couple of guys with a 1000l bowser on the rear on their rocks and they are riding on the bump stops.
    If you were to load your bakkie with luggage and a few goodies + hitch your camping trailer you'd be quite low on the rear. (3blade )
    I'm quite used to the 5 blade and will definitely opt for it again.
    Current: Toyota FJ Sport Cruiser
    Previous: VW Amarok ULTIMATE 4motion (auto)
    Previous: Amarok 4motion (MT) with a few goodies
    Previous: Isuzu KB300 Dteq 4x4 not that many goodies
    Prevous: Isuzu KB360 4x4 with a few goodies
  7. The Following User Says Thank You to jonoB For This Useful Post:
  8. #5
    Melkbosstrand
    Thanked: 173
    Can you retro fit?
    I've got the 3-blade, and noticed there was quite a bit of sag when I connected my Companion... or should I rather get a load helper or sorts?
    2015 VW Amarok 4motion Auto
    2011 Conqueror Companion
  9. #6
    Feb 2007
    melkbosstrand
    Thanked: 137
    Quote Originally Posted by BobMabena View Post
    Can you retro fit?
    You also gain ride height with the 5 blade. Its a super easy job to retro fit
  10. The Following User Says Thank You to jonoB For This Useful Post:
  11. #7
    Mar 2012
    Thanked: 123
    I have 5 blade. Yes more harder riding than 3 blade on my previous Amarok. Then again I need 5 blade for off roading and towing. Depends what you need - but 3 blade a lot more comfortable.
    "To look is one thing, to understand what what you see, is something else"
    Amarok AUTO 4X4
    Out fitted Offroad Trailer
  12. The Following User Says Thank You to XisBo For This Useful Post:
  13. #8
    Jun 2015
    Hi there. I also have the 3 blades and was wondering, is it at all possible to just get another 2 blades added to the existing setup, or must one replace the 3 blade with a 5 blade...?
    2011 VW Amarok BiTDi DC 4Motion
  14. #9
    Jan 2007
    Thanked: 325
    Keeping this tread alive. I'm tired of my Amarok's comfort springs. Either the springs are completely pap, or they are simply not up to the task. Even with new Bilsteins, I find that a mild load (200-300kg) leads to frequent bottoming out.
    So, does anyone have a part number for the 5-leaf springs? Barons just looked at me blankly.
    Alternatively, how can I test my springs to make sure that they are up to scratch? Even the Disco Sport we had for a couple of months carried load better than this bakkie!
  15. #10
    Thanked: 54
    From what I can see it is 2H0 511 151 BF
    Current:
    2019 Tiguan Allspace 2.0TDI 4Motion DSG R-Line
    2017 Toyota Hilux 2.8 GD6 4x4 Auto
    2016 Metalian Maxi
  16. #11
    Melkbosstrand
    Thanked: 173
    Just to add to the discussion....
    Has anyone installed "Load Helpers" instead of adding extra leaves?
    Something like this...
  17. #12
    Pretoorsdorp (Centurion)
    Thanked: 151
    Ive gone the airbag route, deflate the air bags when not loaded and inflate up to 7 bar to handle almost any load when loaded... Nice part it levels the Amarok 100% when loaded or when towing
    WWW.AMADAXTREME.CO.ZA
    203 Edison Crescent, Weca 4x4, Hennopspark, Centurion, GPS: 25°52’19.0”S 28°09’59.3”
    Cobus Böhmer CEL: 071 641 7947 Email: cobus@amadaxtreme.co.za
  18. The Following User Says Thank You to Navigator For This Useful Post:
  19. #13
    Oct 2012
    Thanked: 240
    Quote Originally Posted by dph View Post
    Take your car to Saaymans...they will add the additional blades and at a fraction of VWs price
    That Mighty Amarok
    Swart Tires wat ek self gekoop het
    Pull over wat my ouma gebrei het
    Vensters waar deur ek kan sien
    Engine voor
    Exhaust agter
  20. The Following User Says Thank You to Snyks For This Useful Post:
  21. #14
    Thanked: 104
    I have not really seen any issues when I had the entire back loaded with stuff and a trailer in tow with my 3 blade setup. Maybe all that load was not that much then considering
    Darryn Van Rooyen
    2014 D/C Amarok 4Motion H/L Auto - 76mm Decat Downpipe and Revo Stage 1 Tune
    Current: 1987 Citi Sport 1.6
  22. #15
    Jun 2015
    I was told that you can’t just add blades...?
    Apparently the only way is to replace the 3 blade leaf springs with a 5 blade leaf spring?
  23. #16
    Thanked: 421
    You can - BUT make sure the blade angles and thickness are the same and obviously that the assembly is done properly.
    Gavin
  24. #17
    Thanked: 36
    Quote Originally Posted by GeckoCampers View Post
    Cost of buying the 5 blade pack?
    Jacques
    2013 Amarok BiTDi DC 4Motion
    2018 Bushlapa Ratel 4 Military Edition - BL1402
    Sold - 2011 Conqueror Comfort
    Sold - 2004 Isuzu KB300 DC (was only 4x2 but a happy 240000km and 9 years)
  25. #18
    Thanked: 46
    When I had my Amarok I had the same problem with the 3 leaf pack on the rear of the Rok, the 5 pack was not an option as a result of the cost thus I elected to approach Saayman spring works and they fitted an extra leaf spring thus turning it into a 4 pack. The ride was substantially better and loading capability increased as well and the cost was a fraction of the price of a VW 5 pack.
    2017 3.2 Ford Ranger Wildtrak D/C
    Old Man Emu lift kit
    Stofpad Box rocksliders
    Aline Dagger
    BFG KO2 285-75-16
    Stanium aluminium canopy with some goodies and stuff inside
    and loads of attitude
  26. #19
    Melkbosstrand
    Thanked: 173
    Quote Originally Posted by ChrisBlatherwick View Post
    Phoned Saayman this morning... extra leaf is R3250 ex VAT... fitted.
    LoadHog is R1995 ex Joburg... and it's adjustable. (R2700(?) fitted in Montague Gardens)
    Is the extra leaf that much better?
  27. #20
    Thanked: 46
    I wish I still had my Rok so that you could feel how it drives, I have looked at the load hog option before I went for the Saayman setup but elected to rather go for the additional spring as it gave me the best of both worlds (comfort and load capacity) and I gained a couple of cm lift on the rear as well. I have heard some pro and con stories regarding the load hog setup but elected to go for the safer "add a leaf option".
    Aline Dagger
    BFG KO2 285-75-16
  28. The Following User Says Thank You to ChrisBlatherwick For This Useful Post:
