Engel fridge/freezer probe placement
Results 1 to 3 of 3
    May 2012
    Thanked: 113
    Default Engel fridge/freezer probe placement
    I have a 32lit Engel (the older version with out a temp readout), with the knob from 1-5.
    It looks identical to the old 40 lit ones.
    So I purchased a thermometer with a probe - but where should I mount the probe??
    On the lid - on the bottom - on the cooling vanes - or below them on the side. Advice please.
    Feb 2016
    Thanked: 653
    I hacked the fridge side of my dual compartment engel fridge like that. The probe is hanging halfway down in the one corner, works perfectly. I covered it with a piece of big silicone tubing so that it doesn’t get confused when a warmer or cooler object touches it directly. Test it indifferent locations, use a wattmeter to see if there’s any difference in power used over a few days
  3. The Following User Says Thank You to MrTolbos For This Useful Post:
    May 2012
    Thanked: 113
    Default Re: Engel fridge/freezer probe placement
    Just some pics of where I placed the probe and display.
    Paid R80 bucks for the thermometer, and testing now.
ID:	483129   Click image for larger version.
