Load bearing capacity vs ride quality
Results 1 to 18 of 18
    Jan 2017
    Secunda
    Thanked: 19
    Default Load bearing capacity vs ride quality
    Hi All
    Its time for shock replacement and I am taking the opportunity to fit an aftermarket lift kit.
    EFS offers two options for the rear.
    A 150kg constant load bearing and 250kg constant load bearing capacity rear spring set.
    My first question is this kg rating over and above the standard spring rating.
    Second question will the ride quality be very harsh with the 250kg rear setup. Who is running heavy duty rear springs unladen? Will my passenger's complain.
    The vehicle (07 Pathfinder) is stock.
    But my intention is kit for overlanding and the odd trail. Got to start somewhere. Thanks in advance for any advice.
    Feb 2015
    Noordhoek, Cape Town
    Thanked: 2450
    Default Re: Load bearing capacity vs ride quality
    Any opinions on this matter? I would also like to know about this matter.
    Feb 2015
    Thanked: 2450
    Why do you want to replace the shocks, are they worn out? Maybe keep them stock unless you aim to lift the vehicle as well.
    Feb 2015
    Thanked: 2450
    Best Tasting Rooi Dooswyn - 65 replies.
    This thread 0 replies.
  5. The Following User Says Thank You to Chris Stoffel For This Useful Post:
    Jul 2007
    Putfontein, Benoni
    Thanked: 1977
    I think nobody replies because there are a huge amount of variables in his question with none of them supplied with any detail.
    It depends on how the extra carrying capacity is achieved IE is is simply a harder spring pack or more leafs added or did they make it progressive etc etc.
    is his passengers super prone to complaining or are they the hardy type farm boy etc.etc.
    Many questions but basically impossible to answer given the data supplied.
    'Generally' speaking any spring that can carry more will be less comfortable when not loaded.
    VW Touareg - 2005 - V10 TDI
    VW Touareg - 2009 - V6 TDI
  7. The Following User Says Thank You to Stephan van Tonder For This Useful Post:
    Jan 2017
    Secunda
    Thanked: 19
    Here is a screenshot of options for my vehicle.
    Can't vouch for how they are fabricated.
    Pathfinder has independent suspension front and rear so no leaf springs.
    And vehicle is bone stock.
    I am sure there are plenty of suppliers offerings similar options for "wagon" ladder chassis SUV with coil suspension.
    My question is to persons who have opted for heavy duty versions of suppliers' raised suspension kits what their ride quality experience is when the vehicle is not laden with overland gear.
    Jan 2017
    Secunda
    Thanked: 19
    Thanked: 158
    based on my experience, On my 03 Hilux SC , I had the OME 200kg constant rear springs when unloaded and no canopy it was sitting at 100mm lift drove really bad, loaded the bakkie drove really soft and comfortable. Before selling the bakkie I removed the suspension (buyer wanted the std setup) and put back the original one, bakkie drove quite nice again unloaded.
    So from what I went through if you not going to add any weight it may drive abit harder with the 250kg setup, unless you go for the comfort type setup (ironman do those)
    Hilux 2700i s/c 4X4 with a few extras ...............
    Jun 2013
    Thanked: 2493
    Sorry for taking so long to reply, I was struggling to get that little tap out of the box lined up just right.
    What are you hoping to achieve ? Over landing and the odd trail don't sit well together as to get both right you need two differing set ups.
    Over landing should have the objective of having a reasonable ride on tar, as you will be travelling a good % on this stuff, plus you then want some reliability for load carrying when you get into the rough stuff. What rough stuff ? Deep sand, rocks, gravel, steep inclines or declines, mud. You may encounter most of these but probably not as much or as extreme as on a trail.
    Going on a trail, you want to be as light as possible with as much articulation as possible, totally different requirement to over landing. This is where the air suspensions beat us or of course solid axles.
    To my mind you need to decide which is your strongest preference. For over landing I would go with the lighter load rating and if you do get a lift, that would be a bonus.
    If you are loading the kitchen sink and towing, then the larger load rating would be more suitable but unladen your passengers need kidney belts.
    BMW R1200R
    Thanked: 10617
    Whenever you increase the load rating you compromise the ride quality.
    There is no free lunch on this.
  13. #11
    Thanked: 2329
    Best compromise is to keep standard springs.
    Fit air helpers inside the coils to help when loaded.
    Use adjustable shocks like Ranchos.
    Hard shocks unladen are dangerous as they car will bounce around.
  14. #12
    Jan 2017
    Secunda
    Thanked: 19
    Hi Thanks all for the replies.
  15. #13
    Jan 2017
    Secunda
    Thanked: 19
    I've bought the kit and fitted myself. Here are some pics of the install. Hope it helps anyone wanting to do a DIY job. Click image for larger version.
ID:	484331Click image for larger version.
ID:	484333Click image for larger version.
ID:	484334Click image for larger version.
ID:	484335Click image for larger version.
ID:	484336Click image for larger version.
ID:	484337Click image for larger version.
ID:	484338Click image for larger version.
ID:	484339Click image for larger version.
ID:	484340Click image for larger version.
ID:	484341Click image for larger version.
ID:	484342Click image for larger version.
ID:	484343Click image for larger version.
ID:	484344Click image for larger version.
ID:	484345Click image for larger version.
ID:	484346Click image for larger version.
ID:	484347Click image for larger version.
  16. The Following User Says Thank You to NismoNissan For This Useful Post:
  17. #14
    Jan 2017
    Secunda
    Thanked: 19
    Some quick pointers
    - check you can still get out the garage with a lift kit installed. Deflating tyre is an option
    - air impact tool is a gem
    - you need spring clamps if the front is not assembled. Take your time with the spring clamps. Clamping evenly. Big energy involved
    - keep a trolley jack at hand for lifting swing arms
    - definitely need to take the vehicle for wheel alignment afterwards
    Z
    - for front strut ensure when you assemble the top plate it alings with the shock bottom mount. Id you don't the strut won't fit and you will have to disassemble the strut
  18. #15
    Feb 2015
    Thanked: 2450
    I must say, your Pathfinder do not look lifted very much, even though you gained 75mm. Maybe enough to fit slightly bigger tyres?
  19. #16
    Jan 2017
    Secunda
    Thanked: 19
    Ride quality is great. Its slightly firmer which i enjoy. Note i did go with 45kg springs up front and 250kg rears. Its less inclined to roll and wallow. Tried it out on a gravel rutted road and it soaks it up well.
    Overall quite pleased. Now to plan a road trip and trail.
  20. #17
    Jan 2017
    Secunda
    Thanked: 19
    @ Chris Stoffel
    Tyres are still new. Need a another 80000km to justify tyres.
    Currently running 265\65\17. Would like to try 285\70\17 for another inch of lift
  21. The Following User Says Thank You to NismoNissan For This Useful Post:
  22. #18
    Jun 2013
    Thanked: 2493
    Glad it all worked out well for you, sometimes these things can be hit and miss. If the firmer rides suits you then you have gotten it right.
    Great job
    BMW R1200R
