Results 1 to 20 of 21
Thread: DIY window tint
    Mar 2013
    Thanked: 482
    Default DIY window tint
    I would like to give this a go but cant seem to find a supplier for the film. Dont trust the stuff at midas.
    Any ideas in centurion/pta for a supplier?
    Pieter Greyling
    Of all the paths you take in life make sure a few of them are dirt-John Muir
    ORRA: Z85
    -Pajero SWB 3.8 V6
    -BMW F800GS
    Gaborone, Botswana
    Thanked: 1594
    Default Re: DIY window tint
    Kobus
    Mar 2013
    Thanked: 482
    Thanks!
    Pieter Greyling
    ORRA: Z85
    -Pajero SWB 3.8 V6
    -BMW F800GS
    Randpark Ridge
    Thanked: 302
    Personally I would not do a DIY tint.
    When I had a car done years ago they took it into a controlled dust free room, took the doors apart to cover the whole window, and trimmings off for the back window.
    Discovery 3 TDV6 S G4 No 29 - Mine
    Discovery 4 TDV6 SE - SWAMBO's
    Mar 2013
    Thanked: 482
    Its an old defender with its fair share of scratches, if it looks bad ill remove and have it done by professionals
    Pieter Greyling
    ORRA: Z85
    -Pajero SWB 3.8 V6
    -BMW F800GS
    Thanked: 16
    Ive done ir myself. Take all the windows out. Wash carefully and be extra carefull with edges. It can be done DIY
    Charles
    Defender TDI 110 CSW
    Lift, Long Range Tanks, Dual Battery's, A few Dents and loads of FUN!
    Don't Regret Enjoying Life!!
    Mar 2013
    Thanked: 482
    Thanks charlie, good to hear someone has done it diy
    Pieter Greyling
    ORRA: Z85
    -Pajero SWB 3.8 V6
    -BMW F800GS
    Sep 2014
    Thanked: 184
    Problem usually with the diy tint is how quick the color fades in the sun
    It becomes purple...
    With the real macoy done by the pros the colour last for years
    Wolverine : 93' Range Rover Classic 3.9L EFI
    Gqeberha
    Thanked: 5134
    Quote Originally Posted by whosthejman View Post
    Poor quality film, thats all.
    Gqeberha
    Thanked: 5134
    Quote Originally Posted by rabbiddog View Post
    My JK was tinted under a tree at the office
  11. The Following User Says Thank You to Dirk For This Useful Post:
    Mar 2013
    Thanked: 482
    I will be buying smash and grab from what appears to be a large supplier. Will post results when Im finished....
    Pieter Greyling
    ORRA: Z85
    -Pajero SWB 3.8 V6
    -BMW F800GS
  13. The Following User Says Thank You to pjf110 For This Useful Post:
  14. #12
    Mar 2018
    Sasolburg
    Quote Originally Posted by pjf110 View Post
    Hi pjf110
    That will be really nice please post it and also the details of where you bought it.
    Keep well
  15. #13
    Mar 2014
    Joburg
    Thanked: 75
    I have seen guys doing it at the parking lot of East Rand Flea Market, no idea how much they ask or what film they use.
  16. #14
    Cape Town Southern Suburbs
    Thanked: 1502
    How do you take a few small bubbles out after the fact, my vehicle came with tint and there are some bubbles, not many but the perfectionist in me wants what it wants.
    Can I use a heat gun and felt squeegee to get them out and must I prick the bubble with a needle first?
  17. #15
    Jun 2012
    Thanked: 15
    Whatever you do I would do it sooner rather than later. Try heatgun first, my experience with pricking the bubbles is that the holes are visible. Using a bit more soapy liquid helps to eliminate bubbles-wet the whole sheet throughly.
    '99 TD5 Hardtop
    '99 TD Discovery 2 Auto
    It's a Land Rover thing... and I get it now 8)
  18. #16
    Thanked: 1502
    Quote Originally Posted by louw78 View Post
    The tint is probably a few yrs old already.
  19. #17
    Mar 2013
    Thanked: 482
    Ok so im almost finished. First windows not perfect because of wrong tool used to remove water but for the most part I am happy. Myself and a mate did our two defender 110ís. Excluding cargo windows as we plan on building gullwing doors.
    What we used:
    35% smash and grab window tint from Lamin8 in jhb.
    Squeegee water removal tool and card from Llumar( they refuse to sell film if you are not an accredited installer).
    Blade for removing dirt from windows.
    Tape measure.
    Box cutter.
    Soapy application mixture (750ml water to 5ml johnson bany shampoo) in spray bottle.
    As with most things measure twice and cut once. Prep is crucial.
ID:	484065Click image for larger version.
ID:	484066Click image for larger version.
    We only removed rear small windows as the film cannot be tucked into sides with them.
    Pieter Greyling
    ORRA: Z85
    -Pajero SWB 3.8 V6
    -BMW F800GS
  20. #18
    Sep 2014
    Thanked: 184
    What we used:
    Tape measure.
    Box cutter.
    Cost per meter for the film?
  21. #19
    Gaborone, Botswana
    Thanked: 1594
    Looks good. Well done.
    How is the quality of the Lamin8 vs Llumar ?
    Kobus
  22. #20
    Sep 2014
    Thanked: 184
    I was comparing the specs on the websites Lumin8 vs llumar on 150 microns 35%
    Same thickness of film being sold
    Lumin 8 claims 45% blockage of solar energy
    llumar 34% of heat
    Both block 99% of uv rays
    Depending on the cost seems like a viable option
