OptiMATE 5 VoltMatic 8 step 6V 4A/12V 2.8A Battery saving charger-tester-maintainer
R1190
Name:	OptiMate 5 VoltMatic TM222&3-1 copy 2.png
ID:	481304Click image for larger version.
Name:	OptiMate 5 VoltMatic TM222&3-UP1 copy.png
ID:	481305Click image for larger version.
https://batteriesonline.co.za/produc...er-maintainer/
Advanced 6V & 12V battery care for power sport / auto / marine size batteries.
  • CHARGING AMPS : 4A (6V) / 2.8A (12V) (Ampmatic)
  • USE : Indoor / Outdoor (lowest temperature: -4F / -20C).
  • SAVE : Low Volt Start of 1V + 2-step desulphation recovery.
  • IDEAL FOR : STD, AGM & GEL 6 & 12V batteries from 8 120Ah (up to 192Ah for 6V).
  • INPUT : Global (100-240V 50-60Hz), high efficiency (CEC listed), fully sealed.
  • STYLE : Weatherproof case with wall mounts, with 6ft / 180cm AC supply lead and 6ft / 180cm charge lead ending in SAE connector.
Included
  • Weatherproof battery lead & standard battery clip set
Safe
  • No risk of overcharging.
  • Totally safe for vehicle electronics.
  • Sparks suppressed. Safe for long-term battery maintenance.
  • Automatic shut-down if short-circuited or battery disconnected.
