There is a road and its open to the public but if you don't have a 4x4 you will probably not get through.
There is one little section where you climb or descend the dune which is a bit tricky.
If you going from Britannia to Paternoster you will descend the dune which is not so bad but the other direction will be much more difficult.
Other than that there is some soft sand but nothing to but worried about.
There is a gate on the Britannia side but its unlocked.
