Alternator failure & signs
Results 1 to 20 of 30
    Aug 2015
    Howick
    Thanked: 66
    Default Alternator failure & signs
    Our 2.8LTZ 4x4 manual had it's alternator pack up at 119,000km.
    First signs was a dead battery, this was replaced by battery manufacturer as a "faulty" battery as it was 18 months old.
    3 weeks later, with the new battery, car goes dead and needs a jump start.
    2 days later same thing but let the jumpers stay connected for 30 minutes. Then wife drives home and the headlights switch off, service ESP warning comes up, Battery Saver comes up and Service airbags comes on display and a minute later the windscreen wipers turn on by themselves and car loses power and cuts out. Jumper cables again and manage to get car home.
    Today had the battery charging for 2 hours and then drove vehicle 30km to Key PMB. As we got into the queue the car died again with same as above warnings.
    Turned out the alternator was faulty and was replaced with a new unit under warranty within an hour. We were really impressed with their quick service.
    If you ever suspect an alternator issue the service advisor gave us a good tip to go into the menu and scroll to battery voltage. We never even thought of that. A healthy charge Voltage is 14.3V
    Car is back on the road and a happy wife!
    Barberton
    Thanked: 3916
    Default Re: Alternator failure & signs
    Gav,
    As I was reading your post I kept on thinking: volt readout, volt readout
    Glad to hear the Chev warranty kicked in seamlessly.
  3. The Following User Says Thank You to RoelfleRoux For This Useful Post:
    Aug 2010
    Boksburg
    Thanked: 32
    Good to hear you were sorted quickly
    just checking - warranty expires at 120 000km?
    usually your issue would have surfaced at 121 000km
    Ballito
    Thanked: 3366
    Gav,
    My alternator on 2.8 TB replaced at exactly same km's - done under warranty as well.
    Mooi bly.
  6. The Following User Says Thank You to jaconell For This Useful Post:
    Aug 2015
    Melkbosstrand
    Thanked: 106
    Quote Originally Posted by Gav.S View Post
    Checked mine and spot on 14.3V. I will keep a close look at this as I’m closing in on 100,000km
    2020 Ford Everest 3.2 XLT 4x4
    2014 Chevrolet Trailblazer 4x4 Auto (sold)
    Aug 2015
    Howick
    Thanked: 66
    Quote Originally Posted by Festi1 View Post
    Yip. 120,000km or 5 years whichever comes soonest.
    Thanked: 2534
    Sounds dumb, but where on the menu is battery voltage? Or is it on the newer models? (I have a 2013)
    Stephan G
    4x4: 2018 Isuzu KB250 D-Teq 4x4 DC
    Platkar: 2019 Suzuki Baleno GLX
    "All of us get lost in the darkness. Dreamers learn to steer by the stars"
    Aug 2015
    Melkbosstrand
    Thanked: 106
    Hi Groenman
    As jy ‘Menu’ druk en na die skerm beweeg waar jy die Trans temp, engine hours, remaining oil life ens kry. Dir is onder daardie selfde afdeling. Draai net die ronde gedeelte van die flikkerlig skakelaar waarop die twee pyltjies (op en af) wys nadat jy ‘menu’ gedruk het.
  11. The Following User Says Thank You to globaljaco For This Useful Post:
  12. #9
    Thanked: 2534
    Quote Originally Posted by globaljaco View Post
    Hi Groenman
    Leer ek wragtig iets nuuts vandag. Nog nooit eers daai Menu gedruk nie.
    Myne laai op 14.7 (direk na ek hom aangeskakel het)
    Stephan G
  13. The Following User Says Thank You to Groenman For This Useful Post:
  14. #10
    Ballito
    Thanked: 3366
    Hi Groenman,
    My TB also a 2013. Flicking the menu button will only give you charging volts, language choice, total hours and speed limit exceed warning setting (no use setting it at 185 km/h because the TB has a speed limiter at 184 km/h - all theoretical of course, I would NEVER try this.) The later models all blessed with much more fingertip info in this setting.
    I was given early warning of the alternator letting go by a bearing getting louder and louder. Just do not get caught out by the poor design battery clamps which may in some cases "duplicate" a dying battery or failing alternator.
    When driving steady open road my readout sits between 14.3 and 14.7
    Mooi bly.
  15. The Following User Says Thank You to jaconell For This Useful Post:
  16. #11
    Brackenfell
    Thanked: 282
    My 2013 TB alternator was also replaced under warranty at 60k service.
    Charge also running between 14.4 and 14.7. This is normal operation.
    Uys Snyders
    Toyota Fortuner 2.4 4x4
    Bushlapa Vlooi B237
  17. #12
    Ballito
    Thanked: 3366
    To the OP - my sincere apology for a bit of thread hi-jacking here, but still relevant.
    Failures on the TB's seems confined to alternators expiring, right front bearing seals worn out pre-mature, some suspension issues and problematic LED taillights. Now if you drive a certain vehicle you tend to notice other of the same make & model a lot more - and there are certainly enough TB's on the road to regard this section of the forum as a fair sample size. Look at how little we are posting about problems - the TB's really are well sorted vehicles. I really hope the new Isuzu MUX does it for me when the time comes to replace my TB - although I suspect the tech will be a generation old by then. (and the Isuzu 3.0 D-TEQ motor will not quite compare to the 2.8 DuraMax.). But all said and done the Chevy has been a good choice for me.
    Mooi bly.
  18. #13
    Feb 2016
    Thanked: 203
    Hi guys
    Where can I get a 2.8 Trailblazer alternator except at the agents who wants R12,000 for it?
    Or can it be fixed?
    The car shows "Battery saver activated" warning light, and the agents wanted to replace the alternator.
  19. #14
    Garsfontein
    Thanked: 3984
    Quote Originally Posted by Kaboef View Post
    Hi guys
    Or can it be fixed?
    I'm pretty sure you can probably get an aftermarket one from a place like Bosch auto-electrical etc. The thing is, most of the time it is just the regulator that goes, which is relatively easy to fix - unless the alternator is like the Patrol alternator where the regulator is internal. Perhaps take the vehicle to an auto electrician and ask them to check this first.
    Ian de Villiers
    Nissan Patrol GRX 4.5
    Rainier Vermaak: And in Ian we have a resident cacafuego...
  20. #15
    Oct 2017
    Rustenburg
    Thanked: 10240
    I would firs remove the terminals, clean them and then retighten them..
    Just incase one of them have worked a bit loose.. A couple of guys I know have had loose battery terminals on the TB
    Andrew van Staden
    2021 FJ Cruiser and a trailer
    Ex:
    Ranger 3.2, LC 76 V8, Navara 2.5, NP300, Patrol 4.8, Everest 3.0, Jimny 1.3, Defender 110 SW Puma
  21. The Following 3 Users Say Thank You to Hedgehog For This Useful Post:
  22. #16
    krugersdorp
    Thanked: 725
    alternator is serviceable.
    do not let them convince you otherwise.
  23. #17
    Robertson/ Larissa, Greece
    Thanked: 6106
    If it is of the new generation alternators, you might have a problem. Nowadays, alternators are controlled via the ECU, not so simple anymore. Hope for your sake it's not the case yet.
  24. #18
    krugersdorp
    Thanked: 725
    did not know that.thanks.
    note to my self:
    buy older,simple,cars.
  25. #19
    Feb 2016
    Thanked: 203
    Thanks for the replies.
  26. #20
    Oct 2017
    Rustenburg
    Thanked: 10240
    And, they are not cheap..
    I heard that the Jeep Wrangler one goes for even more, and it also is not serviceable
    Andrew van Staden
    Ex:
