2018 Suzuki Jimny noise..
Results 1 to 17 of 17
    Dec 2010
    Durbanville, Cape Town
    Default 2018 Suzuki Jimny noise..
    I recently bought a 2018 Suzuki Jimny, now has +-2500 km on the clock and the other day it either started or I only noticed that it makes a noise when taking off in first gear from standstill. Only seems to be in first gear from standstill and it doesn't always do it.
    Hard to describe the noise but basically you are at a robot/stop street completely stopped. Let the clutch out and accelerate and just as you've got to the end of letting the clutch out it makes a noise which can be felt in the chassis. Any other gear after that is silent.
    Popped in to Suzuki Tygervalley this morning to ask and one of the guys jumped in the car with me and claimed it was completely normal and they all do it?
    Only changes on the car are from H/T's to A/T tyres (stock size) and the rear seats are out, but they were out from about 5km on the clock.
    Any ideas
    Thanked: 1211
    Default Re: 2018 Suzuki Jimny noise..
    Quote Originally Posted by nickza View Post
    Any ideas
    I think I know what you are talking about. It sounds like a plane boosting for take off (over exaggerated and for 1 second only)
    Mine doing it from day one and I test drove one a few months later as it was bothering me, it did the same. Another way to explain is that it sounds like the handbrake is up while you want to move.
    Anyway, try to test drive another Jimny.
    Sent from my iPhone
    Dec 2010
    Yeh sounds like a brake disk is dragging, vibrating then letting go all in a second or so. If yours and another does it they must be correct and it is normal.
    Very weird
    Thanked: 1211
    Very weird
    I think your explanation is the better way of explaining.
    It is definitely that, that I am experiencing. I’m so used to it, that I can’t recall experiencing the noise until I saw this thread.
    After 5 years owning it and only use it for 4x4, it is really an enjoyable vehicle!
    Sent from my iPhone
    Oct 2015
    JHB
    You're not alone:
    http://www.4x4community.co.za/forum/...-My-Jimny-Poep
    Mine does it too.
    Brits
    Thanked: 447
    Reading the thing without watching the video. Thoughts popped into my mind....
    I do not know Jimnies. But guess they have the same drive setup as other SFA vehicles (albeit on a tiny scale <- smily to soften up the ruffled feathers). Ie: rear prop shaft with slip yoke as opposed to rear prop shaft with centre bearing.
    If that is the case, probably just cavitation of the prop shaft.
    Nissan Patrol GRX 4.5
    Thanked: 148
    Could be ABS pump coming to life...
    Mine is also doing that, and has been doing since 2009.
    Previous owner also mentioned it to me when I bought the Jimny in 2013.
    Thys de Wet
    Jimny 2009
    Ek het nou klaar gewerk, maar ek weet nie of die bank daarvan gaan hou nie...
    Stilfontein
    Thanked: 618
    My Jimny do not have this noise thing you guys are describing
    krugersdorp
    Thanked: 317
    mine use to do
    SSSSSSSS than CLICK
    if that makes any sense.
    Jul 2015
    Thanked: 57
    Mine also does it. Especially on hard pull away or uphill pull away. This makes me think its slip in the transfer box or diff. But I don't think its a big issue as I heard most Jimny owners experience this with no issues yet....
    Andreas Naudé
    Current Vehicle
    Good Year Wrangler Adventurers 205/75 R15
    Neotrek Little Swift roof rack
    Thanked: 1211
    It's very intermittent, not always there. But it is seriously nothing to be concerned about.
    Sent from my iPhone
    Jul 2015
    Thanked: 57
    Agreed
    Andreas Naudé
    Current Vehicle
    May 2007
    Uitenhage
    Thanked: 48
    Mine also does it.
    Suzuki Jimny
    Underbody Protection
    40mm Lift with Gabriel HDP's
    Some form of sound.
    Oct 2015
    Waverley
    Thanked: 14
    That noise has been coming and going on mine
    2010 Suzuki Jimny _Charcoal _Led interior lights _DIY Parcel shelf _DIY Plywood loading board
    _Campmaster loading bars _DIY Awning_DIY Spotlight brackets with LED Lights _Rocksliders_ 50 mm suspension lift with Gabriel Safari HDP Shocks
    _Lots of fun
    On the list:
    _Xenon kit
    _Aux Battery + Dual charging system
    _Undies
    _Replacement bumper
    Jan 2015
    Thanked: 22
    There are so many noises on mine lol,
    Jun 2015
    Mine too, specially when pulling away quickly in 1st gear, also 2018 model.
    Benoni, Gauteng
    Thanked: 44
    Hi,
    Mine also has the "brake binding" noise on pull away, for a second or two. It is totally normal, I agree with the other posts. Mine has been doing it for 200 000km and all good. :-)
    As for the other noise of a motor running for a few seconds, or a ssssh, followed by a click, correct this is the ABS system waking up and doing a self test. This will happen every time you start up and pull away, no matter if it is forward, or reverse.
    No stress required.
    Eric L
    ME_______ - '09 SUZUKI JIMNY - Pipe Bumper / Under body Protection / Winch / Snorkel / Roof Rack / VHF+UHF Comms
    SWAMBO__ - MAHINDRA BOLERO - Feels like an SJ / loads like a truck / tows like a tank!
    RETIRED___ - '99 Gen 1 Grand Vitara / 1.6 Vitara JLX ...x2 / SJ413 SWB ...x3 / SJ413LWB ...x1 / SJ410 ...x2.
