Stain pine ?
Results 1 to 20 of 24
Thread: Stain pine ?
    Rangeview Krugersdorp
    Thanked: 1289
    Default Stain pine ?
    Hi all, need suggestions as to what to use to stain/ colour raw pine to an antique cream light brown colour ? Not varnish or anything sticky but top of table must be reasnably waterproof as it's a coffee pouring spot.
    Thsnks
    Ford Figo 2016
    Thanked: 14158
    Default Re: Stain pine ?
    post pics of what you mean
    Nov 2011
    Thanked: 979
    -Sand the pine with 80, then 100, then 150 paper-remove dust with blower/soft brush in all directions
    -brew strong cup of favourite coffee
    -spill said coffee on wood, spread evenly, add further/stronger coffee if required to adjust shade of colour-allow to dry thoroughly
    -apply clear warmed beeswax to warmed wood-work well into surface, buff as required8)
    PS: Nova make a good range of conventional stains!8)
    - Charles Bukowski
  4. The Following 2 Users Say Thank You to Patrick L For This Useful Post:
    Thanked: 1289
    This table.
    Ford Figo 2016
    Thanked: 1289
    To blend in here between fridge and cupboard ?Click image for larger version.
    Ford Figo 2016
    Apr 2014
    Krugersdorp
    Thanked: 889
    You can use an acrylic varnish it comes out in a natural colour with a matt finish and its doesnt yellow like normal varnish does
    Duster 4wd (Jeep lite)
    Everest 2.2 XLS (Swambo’s mommy taxi)
    Sep 2017
    Richardsbay
    Thanked: 122
    This table.
    You can play around with a lot of different natural stains until you get the colour you want. I prefer waterbased stains that you paint on instead of ''stained varnish'' which looks crap. I've had great success using
    coffee and redwine(sacrilege I know) and various mixtures of waterbased stains from hardware stores.
    Thanked: 14158
    cream light brown = beige?
    You can try a waterbased PVA that you have thinned down extensively (obviously testing on the underneath of the table top) until you get the finish you want, then seal with a matt sealer?
    Thanked: 1289
    'spose using Ricoffy will make my table look like a chicory bird seed feeder 😁,
    Thanks guys, off to Builders tomorrow.
    Ford Figo 2016
    Thanked: 1289
    Quote Originally Posted by Hooly View Post
    Brand name possibly?
    Ford Figo 2016
    Nov 2011
    Thanked: 979
    I'm guessing a 'light oak' stain would work on the pine to approximate the 'oak' worktop colour.8)
    -you can always add extra coats of a lighter colour to deepen the shade if needed, but not vice-versa!
    I prefer to apply stain with a sponge rather than a brush-it seems to allow more control of spread/flow/coverage-which is important in staining, since overlap of strokes always shows. Working at top speed while the surface is still wet is crucial to get an even finish ( unless you are spraying it).
    Enjoy!
    PS-some of the brands on the shelves have good colour display sampleboards done specifically on pine and meranti/other, so you can get a very good idea of the expected finished colour.
    - Charles Bukowski
  13. The Following User Says Thank You to Patrick L For This Useful Post:
  14. #12
    Tshwanetoria
    Thanked: 786
    The gel type stains by Woodock is easy to apply. Make your pick from the colour samples in the store. Then seal with an appropriate polyurethane varnish - satin or high gloss to your liking.
  15. The Following User Says Thank You to hatjohan For This Useful Post:
  16. #13
    Thanked: 1289
    Patrick would extra coats of sponged on stain help waterproof the top against coffee/milk stains?
    Ford Figo 2016
  17. #14
    Thanked: 304
    Stain with woodoc wood stain, test on scrap piece of pine, then use woodoc 10 as per application instructions to seal against heat and water etc. Let it dry and harden properly between each coat - two days each, wipe down 3rd coat with kitchen towel as per instruction for a matt finish, let dry and harden a few days before use. Make sure you use steelwool that does not have large shavings in it when 'sanding' after each coat. Remember the woodoc 10 will make the colour slightly darker so keep that in mind when selecting the stain colour. Do it right first time and it will last a long time. Clean with furniture polish such as mr min or pledge regularly.
    Neil
  18. The Following User Says Thank You to neoT For This Useful Post:
  19. #15
    Thanked: 49
    I've used Gripseal ( a water-based wood sealant ) with great ease of application. It's available in a variety of tints, natural wood and standard colours. Hardware stores generally have samples of pine to which it has been applied. I know Chamberlains does.
    Land Rover Discovery 2 TD5
    Echo 4 Off-Road Trailer
    Gemini 505 S/Rigid
    Ford Ranger T6 S/C 4x2
  20. The Following User Says Thank You to Jack B For This Useful Post:
  21. #16
    Thanked: 250
    I wanted what I imagine is the same colour for our pine bathroom "bench".
    I used Gripseal Antique White. Semi-transparent, water based, waterproof and rapid drying. It is the cabinet/bench that the basin is mounted on. Almost 18 months later and it is still perfect.
    You can buy a 500ml bottle from pretty much any paint supplier at under R100.
    2013 Tata Xenon 3.0 Dicor D/C
    2006 Honda Civic EXi FN2
  22. The Following 2 Users Say Thank You to Rolf For This Useful Post:
  23. #17
    Thanked: 250
    Quote Originally Posted by Jack B View Post
    Ah beat me to it.
  24. The Following User Says Thank You to Rolf For This Useful Post:
  25. #18
    Hillcrest, Malaysia
    Thanked: 6512
    1000% - I have a whole cupboard full of stains. From water to sprays etc.
    I love working with the Woodoc Gel Stain. Somehow it just seems to be foolproof.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
    A V6 and an inline 4
  26. #19
    Richardsbay, KZN
    Thanked: 14140
    Duncan, if you want realy smooth finish to the top before applying anything you can use the "whiskering" technique. Wet kitchen towel ( vatdoek) on the surface and iron it tilll it steams. The steam lifts the uncompressed grain which you sand down. Repeat twice and the surface will be like glass.
    I can check the data sheets tomorrow for the Woodoc and Rystix products we sell to maybe help with your choice of top coat.
  27. The Following 2 Users Say Thank You to Riaan van Wyk For This Useful Post:
  28. #20
    Thanked: 250
    This is what our cabinet looked like before the bathroom was complete. What is not clear on the photo is that the wood grain is still visible.
