Ctek 250 upgrade to smartpass - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 45 of 45
    Hillcrest, Malaysia
    Default Re: Ctek 250 upgrade to smartpass
    Quote Originally Posted by Hendrik du Toit View Post
    It is critical that you isolate the aux batt - to force any current to go through the shunt as any device, eg fridge, can get its earth through the body, bypassing the shunt and therefore it will not give a reading. As I said, easy test will be to disconnect the fridge - and solar -, ensure you have the main batt - to 250 - cable connected, and Im sure you will see results.
    The shunt has to be on the aux battery neg terminal, it’s the only way the BMV 602 will work.
    I have made a new correct wiring diagram that I will post tomorrow when I get access to a scanner.
    ZS5KAD
    3 V8's
    NA TwinTurbo SuperCharger
  2. #42
    Feb 2012
    Agree, and no devices (-) should be connected directly to the aux (-) besides the shunt. All devices (-) connections should be connected to the “other side” of the shunt.
    LC200 V8 4.7 P
    LC200 V8 4.5 D
    LC105 4500EFI
    Bush Lapa (B867)
    Jurgens Exclusive
    GS1200R Adv
  3. #43
    Feb 2012
    LC200 V8 4.7 P
    LC200 V8 4.5 D
    LC105 4500EFI
    Bush Lapa (B867)
    Jurgens Exclusive
    GS1200R Adv
  4. #44
    Oct 2012
    jhb
    It's working!!!
    Thank you so much for the help guys.
    I can confirm that the smartpass is working and does indeed increase charge current.
    Without smartpass = 20A
    With smartpass = +- 40A (saw 60 for a split second but slowly falls)
    Thanks again
  5. #45
    Feb 2012
    Glad its sorted.
    LC200 V8 4.7 P
    LC200 V8 4.5 D
    LC105 4500EFI
    Bush Lapa (B867)
    Jurgens Exclusive
    GS1200R Adv
