Self Build 4x4 Caravan
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 52
    Jan 2017
    Thanked: 40
    Default Self Build 4x4 Caravan
    Im looking at building my own 4x4 Caravan as a project.
    What are the regulations and process to get it registered?
    Jan 2017
    Thanked: 40
    Default Re: Self Build 4x4 Caravan
    Chassis planning underway.
ID:	477860Click image for larger version.
  3. The Following User Says Thank You to sfdt For This Useful Post:
    Jan 2017
    Thanked: 40
    Recieved tyres and rims this afternoon. Waiting for diff and suspension.
    Then frame and floor to follow
    Thanked: 89
    Sfdt
    Hi. Im interested to know what you are going to clad the frame with. Consider Dibond if you haven't decided yet. Google it and if you want i can send you some more info.
    Gavin
    2015 Discovery 4 30 SDV6 SE
    2007 Defender 90 Puma 2.4
    Metalian Off Road Trailer
    Previous
    2010 Discovery 4 30 TDV6 SE
    Discovery 3 V6 S
    Discovery 2 TD5
    Defender 90 TDI
    Defender 110 V8 Hard Top
    Jurgens Xplorer
    Jan 2017
    Thanked: 40
    Quote Originally Posted by Wedwo View Post
    Sfdt
    Gavin
    Hi Gavin
    Thanks. Im still investigating.
    Please email info to [email protected]
    Jan 2017
    Thanked: 40
    Working out the frame and layout Click image for larger version.
ID:	478718Click image for larger version.
ID:	478719Click image for larger version.
ID:	478720Click image for larger version.
ID:	478721Click image for larger version.
ID:	478722Click image for larger version.
ID:	478723Click image for larger version.
  8. The Following User Says Thank You to sfdt For This Useful Post:
    Jan 2017
    Thanked: 40
    Anyone with ideas on how to build the pop-up roof?
    Jan 2017
    Thanked: 40
    Jan 2017
    Thanked: 40
    Started the cladding today
  12. The Following User Says Thank You to sfdt For This Useful Post:
  13. #10
    Virginia
    Thanked: 936
    Looking good!!!
    Any idea what it will weigh once finished?
  14. #11
    Jan 2017
    Thanked: 40
    Quote Originally Posted by Baasvark View Post
    Looking good!!!
    No Idea. I aim for total weight of 1200 - 1400kg
  15. #12
    Jan 2014
    Muldersdrift
    Thanked: 45
    Quote Originally Posted by sfdt View Post
    You got several options, depending on how you want to have function, eg only one side flipping up or both sides.
    The roof you can either make out of 3mm aluminum and have the edges bend at 45 degrees, reinforce with a frame inside. Or to make it lighter and even stronger, use a sandwich panel, weld a frame using aluminium profiles with a 45degree angle and there you will have it.
    I will use most likely sandwich panels for my popup roof as I have difficulties finding aluminium sheets in the size I want...
    So many resources around on the internet in regards to pop up roofs.
    2002 - Defender 110, TD5
    2016 - Duster
  16. #13
    Jan 2017
    Thanked: 40
    Quote Originally Posted by LR110 View Post
    How would you make the lifting mechanism or hinges? Want whole roof to lift
  17. #14
    Jan 2014
    Muldersdrift
    Thanked: 45
    Quite easy, two rather large hinge mechanism front and rear and a few gas struts which support the weight. To secure the roof when down, you can use hooks, straps, lots of possibilities.
ID:	479656Click image for larger version.
    2016 - Duster
  18. #15
    Jan 2017
    Thanked: 40
  19. #16
    Jan 2017
    Thanked: 40
  20. #17
    Jan 2017
    Thanked: 40
  21. #18
    Jan 2017
    Thanked: 40
  22. The Following User Says Thank You to sfdt For This Useful Post:
  23. #19
    Pretoria Oos - Garsfontein
    Thanked: 147
    That looks so awesome!!!
    2015 Isuzu KB250 D/C 4x4 LE - Mine / 2009 Suzuki Grand Vitara 3.2l V6 Auto - Hers
  24. #20
    JBay
    Thanked: 248
    Looking good.
    What material and thicknesses are you using for the frame and cladding?
    Patrol TB48
    Patrol TD42T
    Ex-4x4-partners:
    105 Cruiser
    80 Cruiser
    60 Cruiser
    Tdi Defender
    2.8D Hilux
    http://4x4africa.co.za/
