Hilux REVO - Key in Ignition Buzzer
Results 1 to 7 of 7
    Bethlehem
    Thanked: 135
    Default Hilux REVO - Key in Ignition Buzzer
    OK, so the Hilux REVO has a buzzer that starts up as soon as you put the Key in the ignitioon and the door is open - very irritating...
    I did some goolging and found a solution... See pics attached, just unplug this connector and the buzzer is disabled...
    Buzzer still comes on for headlignts left on, etc, and I have found no other side effects...
    To unplug you have to remove the screw beneath the stearing column, as well as LHS and RHS beneath stearing wheel - takes all but 2 minutes to do...
ID:	477566   Click image for larger version.
    Christo Davids
    Land Cruiser 105 4500 EFI
    Hilux 2.8GD6 Extracab 4x4
  2. The Following 6 Users Say Thank You to Christo Davids For This Useful Post:
    Thanked: 1184
    Default Re: Hilux REVO - Key in Ignition Buzzer
    Thanks Christo... Very helpful!
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
    Dec 2016
    Christo, did you come across any side effects yet?
  5. The Following User Says Thank You to Jakes5021 For This Useful Post:
    Wartburg.
    Thanked: 611
    Doen jou clutch switch en die seat belt buzzer ook terwyl jy besig is.
    Baie makliker om 4x4 en low rang te select sonder om die clutch deur die vloer te trap
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
    Apr 2019
    This works like a charm, got no idea why Toyota would have a door open key in the ignition buzzer on a bakkie, you are in and out of it all day long. I was concerned it would affect any auto box setting, but this work around works. Just a word of advice, the clips on the covers are flimsy so take care splitting the top from the bottom.
    Thanked: 1184
    Quote Originally Posted by Chris8d View Post
    Het jy net die switch "ge-jump"?
    Wartburg.
    Thanked: 611
    Ja, ek het net die draade voor die plug skoon gemaak, gestrip, en hom somer op mekaar op gedraai en hom toe terug in geplug, soos n koeksuster.
    Ek wou nie n los plug he wat rond hang nie en was bang die "jumper" val uit en dan kry ek hom nie.
