Puma 130 leaking oil between gearbox and transfer case .
Results 1 to 3 of 3
    Maun
    Thanked: 143
    Default Puma 130 leaking oil between gearbox and transfer case .
    Please help here experts ; I have been driving some of the worst roads in and around Mababe for a few years now , going through lots of deep water and mud .Had this problem fixed twice last year and now it is leaking again .Why would this keep reacurring if the job was done correctly in the first place .
    FOURWAYS GARDENS
    Thanked: 395
    Default Re: Puma 130 leaking oil between gearbox and transfer case .
    Quote Originally Posted by Puma 130 ADJ View Post
    Andre,
    Hi and how are you.
    This is common on high mileage Defenders and particularly in heavy worked vehicles as in your case.
    what has happened is the intermediate shaft between the gearbox and transfer case one or both housings have been worn. No matter how many times you replace those seals even the yellow Caterpillar ones the leak will always come back. because the housings are worn there is movement of the intermediate shaft which damages the seals.
    Resolution is to remove bother the box and transfer case strip them down and have the empty carcass machined out and have brass inserts fitted or aluminium weld up the orifices and have them machined back to spec.
    Alternatively replace the box or transfer case or both.
    http://www.overlandworx.com
    Take Care
    Stay frosty (Be alert at all times: We Live in a war zone)
    Peter Street
    0834535374
    2013 Disco 4 SDV6 HSE 8sp AKA " Gr8 White Induna"
    2019 Disco 5 TD6 HSE AKA Disco V
    Maun
    Thanked: 143
    Hello there Peter .Thank you for your prompt reply .Million dollar question now is what would this cost just to repair the two housings , never mind replacing the box and transfer case .😂
