You can remove it with the required hardware but you need someone who can code the EGR out in the ECU so you do not get a warning light
More mense ( ja Oupa kuier in Adelaide by sy nuwe kleinkind )
Mnr Fourie en die slim manne hier - help asb. Voorheen het die geel liggie aangegaan en VW het die EGR se " valve " vervang onder waarborg ( extended waarborg deur Ford )
Duisend km daarna - selfde storie.
Nou is dit die cooler. Extended gaurantee manne gooi handjies in die lug.
Ek wag in spanning vir die rekening maar nou lees ek wat julle manne se : Dis net op die environment te red?
Ek dink ek het genoeg gedoen vir volk en vaderland ... kan iemand hierdie &^%$# ding verwyder en sy naelstring afsny dat die motor kan vry vloei of soek ek vir moeilikheid ?
Iemand in George wat my kan help? Nie so seker VW sal my wil help nie?
Ek waardeer opreg !
Groete
Cassie
4 x 4 Vehicle Stable includes:
1990 Nissan Patrol 2 door LH Drive still strong in Freetown, Sierra Leone
1997 Prado 3.0 Tdi Sold - steering box change and 74k later ..
2001 Prado 3.0 Tdi Sold it after R86k damage on engine at 101k
2006 VW Touareg V6Tdi. - Still regret the sale
2006 VW Touareg V10 Wow .. Miss the V6 though..
2009 Audi Q5 - 3.0 Tdi - It could not take the Toureg's position and was sold quickly
Volvo XC60 followed by 2 x Kia Sorento's ( great 2nd hand value for money )
NOW - 2011 Tourag V6 Tdi Blue Motion, 8 Speed with Terrain Tech and Air - I am a HAPPY CHAPPY !
Darryn Van Rooyen
Current:2017 V6 D/C Amarok 4Motion H/L Auto
1987 Citi Sport 1.6
2024 KTM 250 XC-W
Sold:2014 BITDI D/C Amarok 4Motion H/L Auto - 76mm Decat Downpipe and Revo Stage 1 Tune
2011 BITDI D/C Amarok 4Motion Manual
2005 Kawasaki 200KDX
2016 KTM 300EXC
removing the actual cooler in the v6 is hard. Just leave it in place - bypass the water hoses - there are two - on into the cooler - one out of the cooler - you literally just join them to each other. Then at the front of the intake manifold you will see the 'throttle body' and just upstream from there the cooler pipe comes into the intake manifold. Undo it there and install a block plate there. Then get the coding done.
Audi Q7 - 3l TDi - 2013 - touring car
VW Touareg - 2005 - V10 TDI ( tow car)
VW Touareg - 2006 - V6 TDI - play car/ wife daily
VW Touareg - 2013 - V8 TDI - my daily beast.
Afternoon / morning all
Ja its now conformed "exhaust recirculating cooler" will not be replaced by SA Warranties as it is a "wear and tear item". !
I am awaiting the quote - and shock
Groete
Cassie
2012 Touareg 4.2 V8 TDI (Air)
Try Dr Quincy in George. They are in Unit 8, Pioneer Rd, near the Mercedes dealership. They are mainly into chipping and dyno tuning and should have the needed equipment to do the coding for you. Nice bunch of guys.
For a VW in George, Tuinroete Motors is the place to go. York Street. 044 874 7719
Tyrannosaurus R5 (sold) and now on my second second hand D4 British Tata.
I would honestly not bother. bypass - code out and be done for life.
Thank you Francois Theron and JanB ! You are very helpful.
Its good to hear that we have excellent service centres in George other than the OME's.
I know the Land Rover ouks are very happy with the local Landy boffin.
Baie dankie !
Cassie
coding EGR things out it does not (have to) touch the normal engine mapping. You can literally just remove those sections of the coding in the management without making it feel any different from normal or changing power outputs.
Hi V10, any feedback,? I have the same problem on my v6 tdi. It smokes, sometimes, only on idle.
Find the solutions, not the problems.
Lo sir
Boarding for South Africa now - will drive it Monday morning. My son says she is perfect. These guys sends the " program" to Italy and they delete / bypass 67 modules / modes ( sorry I am not very technical).
They invited me to drive it for the week and then bring her back for a dyno check on Friday.
I will keep you updated.
Greetings
Cassie
Had the same issue with my own v6 (audi A6) when I bought it. Swopped injectors and it still smoked.
I noticed the EGR was blocked by previous owner but not coded out. Had the coding done - no more smoke.
Speak to trevor greene - he is in pretoria - tell him I referred you - he can do the coding for you.
