Venter trailer with offroad chassis modification
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 55
    Thanked: 140
    Default Venter trailer with offroad chassis modification
    I have a 6 foot Venter, with a nose cone and extention box on top.
    i have upgrades the leaf springs from 4 to 5
    i have upgraded the axle from 750 to 1000kg
    i have changed the bearings and hubs to sealed bearings
    i hade to replace tyres and fitted 8ply tyres.
    The A frame off a venter is close to useless did i realise December.
    Because we camp in tents when we go to Moz, or when we take gravel and scenic roads throughout SA I decided to upgrade the venters chassis.
    I stripped the AFrame and nose cone box as well as the axel off etc
    built a 50x50x2mm chassis, and a 100x50 lip channel Aframe. I upgraded The jocky wheel and made the A Frame 300 mm longer. i am moving the nosecone fw and it will create a 300 mm gap between the nose cone and trailer box. This will become a basket made deom angle irion and mesh. This will carry wood and dirty braai grids
    i will try and post pics from my phone. The trailer obviously lifted 50 mm in my nise cone is a battery thats connected to the BH plug next to the towbar. In the pajero is a hella okug connected to the cable so that the fridge can stand in the pajero boot, but when the car is switched off it draws power from the battery in the nose cone
ID:	476349   Click image for larger version.
ID:	476350   Click image for larger version.
ID:	476351   Click image for larger version.
ID:	476352   Click image for larger version.
ID:	476353   Click image for larger version.
ID:	476354   Click image for larger version.
  2. The Following 2 Users Say Thank You to Bostokkelos For This Useful Post:
    Thanked: 140
    Default Re: Venter trailer with offroad chassis modification
    did it at my FIL house he has Co2 welder. Not yet finished, still have to fit the nose cone and jocky wheel and build the wood basket. Towed it back to centurion and tows beautifully. I will ise the arc welder at home to build the basket and finish. Thouth i would share it here. The stell was around R1000
  4. The Following User Says Thank You to Bostokkelos For This Useful Post:
  5. #3
    Thanked: 140
    View from the side, i parked it in the garage and will finish the chassis with chassis paint. It is however painted on both the trailer side and chassis side where the two meet
    Thanked: 140
    Simple scetch to show the location of the basket
    Thanked: 140
    The purchase of the trailer including all mods the last two years is standing at a total cost of R9800
    Thanked: 140
    Before and after, see the lift in ground clearance
ID:	476359   Click image for larger version.
    Thanked: 31
    With the extra weight added, how much loading capacity is left according to the registered capacity?
    My understanding is for total (gross) weight to be limited to 750 kg.
    I wanted to do similar with my 7 footer, but weight calculations showed it not to be worth it
    Thanked: 140
    I recon 30-35 kg was added. I will use an online steel calculator to check and reply again.
    Thanked: 140
    Seems like around 37 kg
ID:	476377   Click image for larger version.
    Thanked: 140
    dubble post
  13. #11
    Thanked: 31
    Thanks. Still looks tempting.
    Well done
  14. #12
    Florida
    Thanked: 639
    Nice job. Do the changes mean that you must redo a roadworthy test and recertificate?
  15. #13
    Bethlehem
    Thanked: 3257
    Nice job!!
    If interested - Makro sells a Pioneer Plastics nose cone, universal fit. Very spacious en tough but light.
    Of COURSE I have a Bad Habit. I take Tea at Three (Mick Jagger)
  16. #14
    Carletonville
    Thanked: 615
    I did a 80mm lift on my little venter many years ago to get it more in line with my Sani. Just a straight box frame on the outside with no additional crossmembers like yours. I used the oppertunity to patch some rust weaknesses at the same time on the rear end with some additional supports.
    Nice work you have done.
  17. #15
    Thanked: 140
    Nice job!!
    I have the original nose cone its just not fitted back on yet. I will use its own nosecone
  18. #16
    Thanked: 140
    No I am not going to, if i according to legislation have to I suppose then I well...have to lol.
    the minute everything is painted only a trained eye would see the mods
  19. #17
    Thanked: 140
    Thanks to al for the compliments
  20. #18
    Thanked: 267
    Nice Job Bostokelos
    I did a similar job on my Venter a few years back. It hasbeen everywhere you can imagine. I did put it on a previous thread. I addedside pods as well as fit the spare tyre between the nosecone and body. Seethread: http://www.4x4community.co.za/forum/...Venter+Trailer
    See attached story.
    I could add quite a lot of trips since I wrote thestory. I have added a roof rack with aslide for a full length table to fit under the slide. Having a full lengthtable for camping is great. I sold the Terrecan in Pictures. I now tow with aNissan Navara Supercab. Will attach some pictures.
Name:	Lid Rack with camping table.jpg
ID:	476727   Click image for larger version.
Name:	New Lid Rack 1.jpg
ID:	476728   Click image for larger version.
Name:	Trailer in tow.jpg
ID:	476729   Click image for larger version.
Name:	Trailer Lid Rack - table support.jpg
    [SIGPIC]MikevR Be determined to live the unlived life within you.
  21. #19
    Florida
    Thanked: 639
    Quote Originally Posted by Bostokkelos View Post
    Just watch out 👓 for the insurance small print. Just hope the paint job is not being done to hide substandard workmanship😎
  22. #20
    Fish Hoek
    Thanked: 9
    Hi Bostokkelos,
    I upgraded my Venter as well, but added a braked axle to help with going down steep gravel passes.
    Atleast the trailer now stays behind me.
    Nice job.
    Cheers,
    Bill.
