Venter trailer with offroad chassis modification - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 55 of 55
  1. #41
    /\_/\_/\
    Thanked: 182
    Default Re: Venter trailer with offroad chassis modification
    Making sure the jocky wheel doesnt bend the Lip channel. Welded a flat bar in underneath, and used 5mm flatbar to make (washers) inserted them on the outside and 5mm flat bar vertically on the inside of the channel to give it enough support and to make sure the jocky wheel stays upright under weight. The actual bracket of the jockey wheel tends to bend so hopefully the flat bar on the outside spreads the force over a larger surface
ID:	477885   Click image for larger version.
ID:	477886   Click image for larger version.
  2. #42
    /\_/\_/\
    Thanked: 182
    I tightened it with an air tool that the tyre fitment centres use.
  3. #43
    Jul 2017
    Louis Trichardt
    Thanked: 198
    I see that you are putting some thought into what you are doing. I like what you have done so far. That is goung to be a decent trailer when you are finished
  4. The Following User Says Thank You to Chris G For This Useful Post:
  5. #44
    /\_/\_/\
    Thanked: 182
    Ruberised it. Cant even see the changes unless you look closely
ID:	478112   Click image for larger version.
ID:	478113   Click image for larger version.
  6. The Following User Says Thank You to Bostokkelos For This Useful Post:
  7. #45
    Jul 2015
    Richards Bay
    Thanked: 43
    Looking good. That trailer will be a lot stronger now. On my Campmaster trailer the A-frame is bolted to the loadbody, as well as the leaf springs. I am not very happy with this setup either. And the A-frame is already rusted after only a few years at the coast, so I have to strip it off sometime to galvanise it. Might beef it up when I do.
    Have you found any mesh? The local steel supplier sells stainless mesh in 900*600mm sizes for braai grids, was R180 last time I bought some. Maybe ask around for something similar?
    2004 Pajero LWB 3.8 - My toy
    1998 Pajero SWB 3.0 - SWAMBO's toy
    FJ45 with fibreglass body and 3CT motor - being built
  8. #46
    /\_/\_/\
    Thanked: 182
    I havent done anymore shopping for it, I will however keep it in mind when I do thanks. Good luck with yours, I see you live near the coast, Galvanising is the answer. You do get Cold Galv paint as well. It eill be al lot cheaper. It might work well enough for you but use rustconverter paint first, it kills the rust quite well. I made an extention for my rubberducks trailer a few years back so that you can pull it out so that the car is as far away from the sea water as possible when launching in the Harbour. Its like an extension arm. I painted it with cold galv paint and it holds up very well.
  9. #47
    /\_/\_/\
    Thanked: 182
    Ok so I havent built the basket thats suppose to fit between the trailer and nosecone yet. I did however finishd the paint, and decided to fit the nosecone in its original place for now, so I can use it in the mean time.
ID:	478698   Click image for larger version.
ID:	478699   Click image for larger version.
  10. #48
    Dec 2012
    Secunda
    Thanked: 98
    Bostokkelos daai trailer lyk awsome ek glo hy nou reg virrie bos
  11. #49
    /\_/\_/\
    Thanked: 182
    Dankie. Ja hy is verseker reg. Drie saterdae gespandeer en die Moeite werd. Nou kan ek hom sleep net waar ek wil, hy sal daamkom sonder issues. Die bou en werk was die lekkerste, lanklaas iets aangepak met die welder en grinder. Baie geleer ook, maar wat ek wel geleer het is dat die goed vandag gebou word om deur n Jetta op die N1 te sleep. Met dit gese is die offroad weergawes van Venter en Campmaster etc useless gebou. die Venters en Campmasters ens van die mark moet of die goed oordentlik bou, of dit los. Die wat die goed bou skimp baie. As ek hom vergelyk met n paar offroad treilers, is die een verseker sterker. Ek hoop dit inspirer n paar manne om sulke goed self aan te pak, teen n fraksie van die prys
  12. #50
    Thanked: 1383
    Really nice thread. Do you have a picture of the final product with the basket in?
    Sent from my iPhone
  13. #51
    Aug 2015
    Thanked: 82
    If you have not found the mesh yet, steel and pipes for Africa behind oriental plaza in Centurion sells the stainless braai mesh pre-cut. Also double check that you jockey wheel handle can rotate once the cone is moved forward.
    Current: 2018 Ford Ranger 2.2 XLT AT DC 4x2 with 1985 Jurgens Fleetline L
    Sold: 2015 Ford Ranger 2.2 XL MT DC 4x2, Sold: 2013 Ford Focus 1.6 5DR Trend, Sold: 2010 Ford Ranger 2.5TD Supercab, Sold: 2007 Ford Bantam 1.6 XLE, Sold: 2006 Ford Focus 1.6 5DR Sport
  14. The Following User Says Thank You to Bluefin06 For This Useful Post:
  15. #52
    /\_/\_/\
    Thanked: 182
    Kept that in mind thanks
  16. #53
    /\_/\_/\
    Thanked: 182
    Just some feedback (Update), towed this Venter over very rough terrain, gravel roads and a mountain pass last week. The chassis holds up perfectly, its strong, and does the Job I was hoping for.
    For some reason the lights doesn't work anymore, I suppose its probably as a result of the gravel roads. Will check that out soon.
  17. #54
    /\_/\_/\
    Thanked: 182
    Looks like a normal Venter when hooked
  18. #55
    Dec 2012
    Secunda
    Thanked: 98
    Puik daai Venter lyk baie goed welgedaan
  19. The Following User Says Thank You to Boslover For This Useful Post:
