Duram Bakkie Liner
Results 1 to 5 of 5
    Dec 2016
    ALLENS NEK EXT 9
    Thanked: 18
    Default Duram Bakkie Liner
    Dagse aan almal
    Het iemand al van Duram Durakak se Bakkie Line (DIY Kit) gebruik gemaak. Ek wil dit aan die vaaorant van die sleepwa sit waar ek baie skade kry van klippies wat opskiet
    Jul 2007
    Putfontein, Benoni
    Thanked: 1980
    Default Re: Duram Bakkie Liner
    Yup used if a number of times for excatly that. People will tell you it is less robust than rhino lining for instance and I agree but for the same amount of money as rhino you can probably redo those little fenders 20 times. They do ebetually take a pounding and then you just spray it again. Make sure you rough up the surface intitally and remove all signs of rust and loose material up front. Then if they do get a nick or two with time just patch it with a little brush so it does not rust where the nick is.
    VW Touareg - 2005 - V10 TDI
    VW Touareg - 2009 - V6 TDI
    Thanked: 250
    I'd use Duram 88 Premium Stone Chip instead. MUCH cheaper, water based and very easy to use. I did the "rubberising" for the back of my bakkie with it using a course foam roller. Looks great and very easy to apply.
    I can take a picture of the end result and post it on here if you are interested.
    2013 Tata Xenon 3.0 Dicor D/C
    2006 Honda Civic EXi FN2
  4. The Following User Says Thank You to Rolf For This Useful Post:
    Oct 2015
    Thanked: 115
    Quote Originally Posted by Rolf View Post
    Hi Rolf
    I am interested in seeing the result. Please post some pictures.
    Would you advise spraying n stead of rolling or brushing. How coarse is the layer of rubber? Is it a rubber lining?
    How much preparation did you do to your bakkie before painting?
    Where did you buy the Duram 88?
    Thanx
    Okahandja, Windhoek
    Thanked: 904
    Rhino linings are also useless if you ask me. Best option is proper rubber lining.
    Johan Kriel
