My Fortuner Journey - Page 17
Page 17 of 18 FirstFirst ... 7 8 9 10 11 12 13 14 15 16 17 18 LastLast
Results 321 to 340 of 345
  1. #321
    Dec 2011
    Thanked: 2449
    Default Re: My Fortuner Journey
    Quote Originally Posted by Wim77 View Post
    Yes, I drilled 2 small holes - one for each cable. The BH connector is attached with 2 small screws with nuts (2 more holes)
    Attachment 526016
    Same as mine. I like the neat minimal look.
  2. The Following User Says Thank You to MariusFourie For This Useful Post:
  3. #322
    Krugersdorp
    Thanked: 379
    One does not always have to do a technical trail to have a outing and to stretch the legs of your vehicle. Also don't have to drive very far...
    Recently drove Breedtsnek Pass. Basically a bad public road that makes for a interesting outing. Have a look at the video on Youtube:
    https://youtu.be/-s0TJ_IJg7w
    Bush Lapa Miskruier 586
    Youtube Channel: https://www.youtube.com/channel/UCFS..._as=subscriber
  4. #323
    May 2012
    Smile Re: My Fortuner Journey
    Morning Bogaards,
    Nice thread you have and I see your SA4Wheeling on you-tube is also getting quite a lot of views.
    I note you have Goodyear Wrangler Adventure Tyres fitted to your vehicle. I have the same fitted. On my previous vehicle I had BF Goodridge and Coopers ST Max.
    Not sure if it is my imagination but it seems as if the GYR's don't like tyre pressures below two bar. Would you mind sharing your experience with the GYR's and what tyre pressures you use when driving off road and trails. Gravel, Rocks and Sand.
    Thank You and Regards,
    Eric
  5. #324
    Krugersdorp
    Thanked: 379
    Quote Originally Posted by Eric&Sonja View Post
    Morning Bogaards,
    Eric
    Hi Eric
    Yes, I have the GY Adventure tyres fitted (265/60/R18)
    Usually I am running them at 2.2 - 2.4 bar. On the road grip and experience is very good.
    Offroad I also cannot complain. Usually I use a pressure of 1.5 bar (rock and gravel). So far I have not any problems with them and offroad I am also very happy with them. They are softer than BFG, but looking at the mileage I know some of the BFG get out of them don't think I will be worse off. I should get around 80,000 from my set (I do use 5 tyre rotation).
    The lowest pressure I have used was 0.7 bar at Paradise 4x4 (sand). I did not have any problems at this pressure. As the side wall is not as thick as BFG etc the tyre flexes more.
    So, to answer in short I don't have any problems with pressure below 2 bar.
    I have also chose this tyre as I am doing tar road travel with them as well and used to do my daily driving with the Fortuner as well.
    Will I replace them with the same? I don't know - at this stage I don't have any reason why not to. The only place where I have found that BFG (KO2) did better was Mud as the thread did not get filled with that much mud. Have a look at my Kungwini video at the cross axles, you will see the vehicle slides sideways before it hits a bump and move forward. Guys with BFG did not have that slippage.
    Other thing with it being a lighter tyre I will get better fuel consumption vs BFG.
    Hope this answers your question?
  6. #325
    May 2012
    Thumbs up Re: My Fortuner Journey
    Hi Bogaards,
    Thanks for your reply, appreciate.
    We did Tankwa Karoo and some other passes in March and not going below 1.8 bar. In the evening it looked as if the side walls had like bumps on them (separations) whilst the tyre was hot. once the tyres has cooled down these bumps disappeared. On the Explorer we had the previous Wrangler AT/SA and they coped very well with a pressure of 1.2. Just concerned they will let us down somewhere on a trail. Will try and do as many trails not too far from Gauteng as we can before our next long trip that in case they want to pack up they can do it close to home and not somewhere between nothing and nowhere.
    Regards,
    Eric
  7. #326
    Krugersdorp
    Thanked: 379
    Hi Bogaards,
    Regards,
    Eric
    No problem.
    I have not yet encountered anything like that. Have you taken pictures?
    I also tow a caravan with the AT/SA tyres on and they are also still good.
  8. #327
    Krugersdorp
    Thanked: 379
    Recently did the De Wildt 4x4 Trail. Nothing serious and no problems for the Fortuner.
    Was amazed how easy it was going down Gert se Klip mostly on Engine braking. Never did it feel as if the engine will stall, even with heavy braking and not touching the clutch.
    Link to the video:
    https://www.youtube.com/watch?v=117V...ature=youtu.be
  9. The Following 3 Users Say Thank You to Bogaards For This Useful Post:
  10. #328
    Krugersdorp
    Thanked: 379
    The Fortuner keeps on impressing me.
    Recently did the Berakah 4x4 trail
    https://youtu.be/gRy1yfB0440
  11. The Following 2 Users Say Thank You to Bogaards For This Useful Post:
  12. #329
    Oct 2012
    Thanked: 323
    Quote Originally Posted by Haggy4x4Bedinges View Post
    25 Mei 2016 gekoop sy loop nog soos n droom het n paar mods op maar niks te ernstig
    Nice looking vehicle - can I ask; what nudge bar is that? The "wings" add a little bit of protection without too much weight.
  13. #330
    Thanked: 2846
    Quote Originally Posted by Bogaards View Post
    The 2.8 engine is a gem. Did a trip a few weeks ago with my sons 2.8GD6 Hilux. Were quite surprised with the fuel consumption. It turned out 11km/l .
  14. The Following User Says Thank You to grips For This Useful Post:
  15. #331
    Krugersdorp
    Thanked: 379
    Agree, I really like this engine. Can press the brake hard without the vehicle stalling. I am also getting around 11km/l
  16. #332
    Dec 2011
    Live : Bethal , Work : Saudi
    Thanked: 255
    Quote Originally Posted by mudgrubber View Post
    Mudgrubber its the wrap around nudge bar from errols tires
    I didnt want the normal one that toyota offer
    One life Live it
    Take The Roads less traveled
    Alles in die lewe gebeur met n doel
  17. #333
    Krugersdorp
    Thanked: 379
    Did the Hennops 4x4 Trail recently.
    The Hennops 4x4 Trail Video is now available on Youtube.
    https://www.youtube.com/watch?v=Ln2Tm1tGtfs
    The Fortuner is still going strong - now on 40,000 km. Not a single problem.
  18. #334
    Jan 2019
    Otjiwarongo
    Thanked: 134
    Toyota also offers Wrap Around Nudge bars for the Fortuner and Hilux!
  19. #335
    Krugersdorp
    Thanked: 379
    Last trail complete - Spookspruit
    https://www.youtube.com/watch?v=_Og3MiEAQI0&t=8s
  20. #336
    durbanville
    Bogaards , ek het dieselfde as jy gedoen kom ook vanaf amarok 4motion auto na fortuner, ook maar oor die 7 seater en warranty etc etc, niks fout met Rok gewees.
    Wil se ek hou baie van die tuna , het die auto gekies.
    Hoe is jou ondervinding nog as jy die rok en tuna moet vergelyk?
    Fortuner 2.8 GD 6 4x4 auto
    Daily Driver
    Jeep Wrangler JK 2dr
    Cooper STT Pro 33's
    Maniac Bumper
    Poisen spider rock slider
    1 No Petrol card
  21. #337
    Krugersdorp
    Thanked: 379
    Dis moeilik, want in n mate is dit 2 verskillende voertuie, maar die volgende het ek al opgelet.
    Die 2.8 engine is beter as die van die Amarok, krag is beter en die Manual vrek nie so maklik nie, jy kan die briek maar hard trap, hy sal nie sommer doodruk nie.
    Die Manual se ratkas is ook beter - dis vir my 'n makliker ratkas om van dag tot dag mee saam te leef.
    Omdat die Toyota smaller is help dit in 4x4 omstandighede.
    Dis baie makliker om aftermarket goed vir die toyota te kry. Rocksliders is ook beter op Toyota, met die Amarok kan jy omtrent net Seikel oorweeg sonder om hoogte te verloor.
    Ek dink hier en daar is die boukwaliteit van die Amarok beter, maar dan moet ek ook se dat die Fortuner stiller binne is as die Amarok.
    Dis my mening/persepsie...
  22. The Following User Says Thank You to Bogaards For This Useful Post:
  23. #338
    Melkbosstrand
    Thanked: 468
    Quote Originally Posted by 4x4 freak View Post
    Hallo Frikkie
    Long time no see.....
    Everybody needs to believe in something.... I believe I will have another Beer!
    Travel Blog: https://since1652.wordpress.com/
    https://www.instagram.com/since1652travel/
  24. #339
    durbanville
    Quote Originally Posted by Papsak View Post
    Hallo Frikkie
    yebo tjomma!! hallo daar, sien jy ook nou n toy?
    Daily Driver
    Cooper STT Pro 33's
    Maniac Bumper
    1 No Petrol card
  25. #340
    Robertson/ Larissa, Greece
    Thanked: 3329
    Haggy, your FT looks "different". Apart from the fender spats and rims, what else was done? Are the rim off set different to standard. Tyre size?
    Did you change anything on the suspension? Is there a way to improve the ride quality? More Prado like?
