The OptiMate charge controller is separate to the panel and can be placed close to the vehicle or battery so that charge and maintenance progress can be easily followed.
Solar Pulse Charger, Tester & Maintainer for 12V batteries, with 80W solar panel
R3155
The world’s most efficient solar pulse charge system that can save your ‘dead’ battery and provide safe long term maintenance.
OptiMate Solar employs an innovative charging technology to charge and effectively maintain your 12V battery from a standard solar panel.
OptiMate Solar converts the low power from the solar panel to high current pulses more effective for charging and maintenance of a 12V battery.
Name:  Optmate solar 80wat panel.jpg
Solar panel :
POWER : 80 Watts (max.)
VOLTS : 12V nominal, 22V maximum.
USE : Outdoor.
STYLE : Weatherproof case with 4 x mounting holes.
OptiMate Charge controller:
CHARGING AMPS : 7A (max. average current)
USE : Indoor / Outdoor (lowest temperature: -4°F / -20°C).
SAVE : Low Volt Start of 1V
IDEAL FOR : STD, AGM & GEL 12V batteries from 2 – 240Ah.
INPUT : 15 – 22V
STYLE : Weatherproof charge controller case. Weatherproof battery lead, standard battery clip set & 80W solar panel included.
