Results 1 to 20 of 22
Hybrid View
    Jul 2014
    Thanked: 77
    Default Help Identifying front suspension part on Jeep TJ
    Tried looking on line and doesnít seem like a standard part. Jeep does have a 3 inch lift on it
    Thanked: 18087
    Default Re: Help Identifying front suspension part on Jeep TJ
    Can you get us a shot from the side of the pitman / steering drop-arm?
    Thanked: 18087
    I need to see where the two left hand side ends mount.
    Is it on the axle mount or onto the pitman arm? It's not clear from the pic.
    Jul 2014
    Thanked: 77
    I think itís a trackbar relocation mount:
    Worcester
    Thanked: 1340
    Not sure, and cannot see clearly from the pic... but a number of us XJ'ers have a cross brace on the front chassis rails. It stops the steering pump side from cracking when we do serious off-road work.
    Google it. Maybe something similar?
    Work. It's a wealthy man's privilege, and a poor man' fate....
    Andrť Opperman
    "Boerbok" - 98 Jeep XJ 4lit auto
    "Gloria" - 04 Ranger D/C 4lit auto
    Jul 2008
    Joburg
    Thanked: 25
    I saw this recently on another RHD TJ post from OZ I think.
    It's a brace that is used with a dropped bracket for the track bar. The drop bracket might not be strong enough so they brace it to the opposite chassis arm. Pretty sketchy solution I reckon.
    I think that's what it is anyway.
    Stu.
    Current:
    06 Wrangler Sahara. 3.5inch Rubicon Express and Bilstein lift, Metalcloak control arms, 1.25" RC Body Lift, 1" JKS MotorMount Lift, Zone Disconnects, BFG KM2 33's
    NO LOCKER NEEDED!!!
    KTM 1190 Adventure
    KEMPTON PARK
    Thanked: 421
    Pro comp track bar brace , for the lowering bracket on the track bar when the jeep is lifted , Have the same on mine . The two bars have rose joints at the end to adjust ,broken them in extreme articulation . Part of my plans is to remove them and weld on a drop track bar bracket that is a lot stronger , as this still has a bit of movement in the set up . But it does the job .
    05 TJ SAHARA
    08 3.8 JK ULTD RUBICON
    Thanked: 18087
    Cool, that's sorted then. Well done guys.
    Jul 2014
    Thanked: 77
    Quote Originally Posted by NEON DEON View Post
    Had the jeep in for wheel alignment after new set of muds, seems to be some play from the bottom bar. Also jeep makes a strange sound when turning the wheels.
    Where did you purchase new ones when replacing?
    Jul 2014
    Thanked: 77
    Red circles are the 2 bars coming in on the other picture.
    Green bar is the trackbar.
    Sorry if the picture isnít very clear, will try take some when I get back home later
    Jul 2014
    Thanked: 77
    I got the number from someone that manufactures them here locally. His name is Guy
    If only I knew about this when I bought the standard track bar last year. R3800 for this adjustable one
    Jul 2008
    Joburg
    Thanked: 25
    Nice one. Yeh I also got one from Guy.
    Stu.
    Current:
    NO LOCKER NEEDED!!!
    KTM 1190 Adventure
    Jul 2014
    Thanked: 77
    Quote Originally Posted by roadhawg View Post
    You happy with it? Any issues?
    Jul 2008
    Joburg
    Thanked: 25
    Quote Originally Posted by rog163 View Post
    Nope.
    I was an idiot and torqued the ever living Fudge out of the ball joint at first because of a dodgy torque value I found on the internet. It is NOT 110ft-lbs Loosened it and torqued it properly and it's been fine.
    Stu.
    Current:
    NO LOCKER NEEDED!!!
    KTM 1190 Adventure
    Jul 2014
    Thanked: 77
    Is it fine if I just remove the brace and the poles and fit the adjustable trackbar? Is there anything else that would need to change?
    Jul 2008
    Joburg
    Thanked: 25
    Wait you should have a dropped pitman arm too right?
    The trackbar needs to be parallel with the steering draglink. Usually when people do a drop trackbar bracket like you have, they then also install a drop pitman arm to lower the top of the stering draglink as well so the 2 bars stay parallel.
    So you may have to get a stock pitman arm.
    Stu.
    Current:
    NO LOCKER NEEDED!!!
    KTM 1190 Adventure
    Jul 2014
    Thanked: 77
    Thanks, will need to get hold of one, you know where I can get one?
    Jul 2008
    Joburg
    Thanked: 25
    Besides Jeep I'm not sure.. Maybe AAOnline?
    Stu.
    Current:
    NO LOCKER NEEDED!!!
    KTM 1190 Adventure
