Fridge/Freezer Temp Setting
Results 1 to 3 of 3
    Nov 2012
    JHB
    Thanked: 15
    Default Fridge/Freezer Temp Setting
    So I bought a Snow Master Classic 56lt double door fridge freezer on special from Takealot for R7500. They delivered it this morning and I see the price on Takealot has already gone back up to 10k.
    Anyway...temperature settings !!!...I can set the 2 compartments individually, and would like to know what tempreture everyone else who has the same or similar is setting theirs too ? and does setting one side automatically set the other, as I have read that some fridge freezers do so (think the NL ones do). any advice or tips would be useful...thanks
    It has a soul, its a Land Rover
    2003 Land Rover Discovery 2 TD5 ES auto facelift
    Ham: ZS6GS
    ORRA: Z152
    Jun 2016
    Thanked: 30
    Default Re: Fridge/Freezer Temp Setting
    My FIL has a dual compartment fridge/freezer.
    An just by playing around on the thing, I could change both compartments individually.
    Setting for fridge was 2deg, and freezer at -10deg.
    2014 GWM Steed 2.0 VGT D/C
    2011 Jurgens Camplite
  3. The Following User Says Thank You to JDeere85 For This Useful Post:
    Ellisras
    Thanked: 600
    I use 2 Fridges
    1 old 60 litre Snomaster for drinks - set at 5 deg
    1 new 66 litre Dual Compartment - Freezer(30 litre) set at - 10 / -12 for freezing meat and making ice; Fridge (36 litre) side set at 5 deg for all the dairy/salads/perishables etc SWAMBO is in charge of.
    O, and remember the 66 litre Snomaster is a fully interchangeable dual fridge/freezer. Meaning you can pick which side you want to utilise as what.
    Some other makes have dual compartments, but their settings are dependant on each other - complicated!
