Clutch kit
Results 1 to 8 of 8
Thread: Clutch kit
    May 2016
    Hartbeespoort
    Default Clutch kit
    Good day everyone.
    Can anybody assist me where I can buy a new clutch kit for my Mahindra Scorpio SUV, 2008 model.
    I have tried Mahindra Spares in Pretoria but they don't know when their new stock is arriving.
    Regards,
    Corné
    Constantia Kloof
    Thanked: 575
    Default Re: Clutch kit
    Quote Originally Posted by Scorpio2008 View Post
    Good day everyone.
    Regards,
    Corné
    Same clutch is used in just about every Mahindra pick up going back to the 2.6 Diesel. You can order one through Autozone, Midas etc. Expect to pay around R4.5k.
    Whilst you are busy, have the flywheel skimmed and balanced(Remember to send the pressure plate along with the flywheel for balancing). When you fit the clutch, use a mixture of white lithium grease and Wynns Wynflon to lubricate the spigot shaft for the thrust bearing. Also treat the new thrust bearing with some Wynflon. You will not believe how smooth the clutch can be.
    2007 Mercedes Benz ML500 5.5
    1968 VW Beetle 2276
  3. The Following User Says Thank You to Koebelwagen For This Useful Post:
    Jul 2017
    Louis Trichardt
    Thanked: 173
    I understand the clutch is a R451MK
    sabie
    Hi i was monday at autozone wadeville they have a Valeo clutch kit for R1710 ( 10 splines)
    Jul 2017
    Louis Trichardt
    Thanked: 173
    Quote Originally Posted by zebraas View Post
    What is the model or part number of the kit please
    sabie
    On quote prod code RII .MH01
  8. The Following User Says Thank You to zebraas For This Useful Post:
    May 2016
    Hartbeespoort
    I got a Valeo clutch kit at Autozone in Hartbeespoort for R1900. Now it is as good as new.
    sabie
    Hi your scorpio how many splines on shaft and the valeo clutch kit how many splines
