Disco 3 / Disco 4 - whats in your overland toolkit?
Results 1 to 16 of 16
    Mar 2012
    Fourways
    Thanked: 434
    Default Disco 3 / Disco 4 - whats in your overland toolkit?
    Thought I would start a thread to see what everyone has in the their Overlanding / travel toolkit?
    My kit consists of the following:
    • IIDtool BT
    • Jumper cables
    • Fuses
    • Set of Spanners
    • Flat & Phillips Screwdrivers
    • old Leatherman
    • Cable-ties
    • Insulation Tape
    • Puncture kit
    • Spare CR 2032 battery for Key
    Rob,
    D4 SDV6 HSE ARB Bullbar, Compos, BFG 265/65R18s, Big Country drawers, National Luna 52L, Dometic 50L, Spare Wheel Carrier, Roof Rack, Hardshell RTT, FR 50" LED Bar, Lift Rods, Mantec Snorkel, C-TEK Dual batt system, 270 Ostrichwing, Maxtrax, TXG Rock Sliders, IIDtool, shelf
    Feb 2012
    Chintsa East
    Thanked: 489
    Default Re: Disco 3 / Disco 4 - whats in your overland toolkit?
    Jumper leads.
    Spare fuses
    Axle stand. (I jack with a highlift and a jack buddy)
    Set of spanners and sockets, nice Yoto kit also has all the screw driver bits.
    Leatherman
    small tool box with self tappers, tape, cable ties, washers length of electrical cable.
    Recovery kit.
    Jack plate for soft ground or sand.
    Puncture kit with lots of plugs.
    Sat phone, expensive to load airtime but just in case.
    2013 Disco 4 XS Lifted
    Thanked: 361
    You guys need to add those little airline connectors.
    I did not have them in Botswana and it eventually cost me R11000.
    Got basically the same, including maxtrax, extra spare wheel, air bag jack.
    www.lani4travel.com
    Louis Le Grange
    Thanked: 550
    Quote Originally Posted by DETOUR-GP View Post
    • IIDtool BT
    • Jumper cables
    • Fuses
    • Set of Spanners
    • old Leatherman
    • Cable-ties
    • Insulation Tape
    • Puncture kit
    Added to that is a proper trolley jack, vulcanizing tape, fiberglass reinforced repair wrap tape, double sided tape, and some long and short M8 bolts and nuts, a spare auxiliary belt.
    Oct 2012
    Eversdal, Kaapstad
    Thanked: 474
    If it is something electronic that goes wrong in the bush then tools might not help much.
    Telephone nrs doesn’t take much space. I would certainly take the number of Henris or TuffStuff with me
    MTUNZINI
    Thanked: 577
    There was a whole thread about this a few years ago, its much more specific for D3/4
    Normal tools yes ,
    6 MM AIR LINE PIPE APPROXIMATELY A METER LONG
    IN LINE CONNECTORS
    ALTERNATOR
    3 m TAPE SILICONE TAPE
    Above just some stuff
    Cant find that post , somebody must find and copy and paste
    And remember guys, if you travel with others, make a point that everybody hands over their spare keys to travel in another car
    Koos Best
    Land Rover Discovery3 TDV6 S.
    Aug 2015
    Thanked: 299
    Spare valves and a valve spanner......if you deflate your tyres a lot (by removing the valve) its crazy not to have spares. And one of these https://www.amazon.com/Stop-Go-1075-...26+go+puncture
    2007 Disco 3 TDV6 SE
    2007 Fortuner 3.0 D4D
    Jul 2016
    Thanked: 522
    I also carry fire extinguisher. Torch. Tow rope. Also reflective vest.First Aid Kit. Fan belt. And I've just added a second hand fuel pump belt and tensioner.
  9. The Following User Says Thank You to MikeBob For This Useful Post:
    Randpark Ridge
    Thanked: 292
    The only things I actually carry for the Disco is the iCarsoft and some fuses, never needed anything else.
    I do carry other tools, tape, etc, but that is due to my work, and needing to repair/help repair things in the bush.
    If you don't have a IID tool and you do certain repairs that give major errors you will still be stuck as you cannot clear the errors, and you remain in limp mode.
    Discovery 3 TDV6 S G4 No 29 - Mine
    Discovery 4 TDV6 SE - SWAMBO's
    MTUNZINI
    Thanked: 577
    Suspension rods
    Spare alternator (nice to have, if you cant fit it somebody will have the tools to do so)
    Good tyres and repair kit
    Self valcanising tape (it repairs everything, it even repaired a ruptured air pipe on mine)
    6mm push on fitting
    Hawkeye or similar diagnostic machine
    Spare fuel filter
    To do before hand
    Change the water outlet assembly
    Service compressor
    Great vehicle for touring and doing the rough stuff, refrain from using EPB in areas if you traveled in mud and water for long periods, get it cleaned out and reset thereafter at home
    Koos Best
    Bellville
    Thanked: 9
    Greetings all.
    Due to unforeseen circumstances , I completed a 8500km overlandtrip ,+- 40% on sand and bad gravel, with a totally unprepared D4.
    Main failures were puntures and an alternature failure .. Position of D4 alternator does not like mudpools.
    All above equipment plus decent hydraulic jack with additional baseplate is always recommended
  13. The Following User Says Thank You to gojo For This Useful Post:
  14. #12
    Aug 2015
    Thanked: 299
    I also always carry a spare alternator (and those thin special tools to get the fan off!). Actually, my spare is now fitted, and I'm about to overhaul the old one to carry as a spare
  15. #13
    Mar 2012
    Fourways
    Thanked: 434
    Quote Originally Posted by gojo View Post
    Greetings all.
    Really? I have done over 20,000km offroad in Botswana during the rainy season on both the pans and the delta and haven't once had an alternator/ mud issue.... hmmmm
    Rob,
  16. #14
    Touwsriver
    Thanked: 197
    I carsoft code reader
    Kompressor
    Tyre repair kit
    Sealent
    1 m fuel hose
    Cableties
    Socket set
    Basic tools
    Hi lift
    Bottle jack
    Fuses
    Pratley steal
    Ford Ranger 2.2 XL 4x4
  17. #15
    Forest Hills, KZN
    Thanked: 907
    Great thread.
    I need to stock up..
    2003 LR Discovery 2 Td5 ES - Lots of Mods(check thread) - [Husky]
  18. #16
    Aug 2015
    Thanked: 299
    Important addition for a D3/D4: a hex (not twelve point socket) for the wheel nuts PLUS another 1mm smaller one for the wheel nuts after you have taken off the thin stainless steel sheet cover. And power bar or 3/4" drive bar and reducer if your sockets are 1/2" drive.
    Stores easily under one of the back (middle row) seats, next to the hydraulic jack and blocks of wood.
