The Hilux fred: Starting with a blank canvas - Page 9
Page 9 of 19 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 ... LastLast
Results 161 to 180 of 371
  1. #161
    May 2010
    Ruimsig
    Thanked: 761
    Default Re: The Hilux fred: Starting with a blank canvas
    Ja Uys en ek kan ook nie wag om te sien wat jy doen vir recovery points en 'n prys op daai bash plate nie.
    Die res van jou werk is awesome!
  2. #162
    Bethlehem
    Thanked: 3227
    Hannes Uys is tjoepstil.
    Hy maak ons al hoe lusser en lusser. En hoe lusser ons raak hoe duurder gaan dit wees
    Of COURSE I have a Bad Habit. I take Tea at Three (Mick Jagger)
  3. The Following User Says Thank You to Petri Oosthuizen For This Useful Post:
  4. #163
    Thanked: 954
    I got the correct heat shrink yesterday and was able to finish the harness.
    Installing it was a bit of a mission, which required child labor. The area behind the dash board is completely filled up and it took us the best of 45 minutes to route it properly.
    Terminated on the fuse box. If you look carefully you'll see the negative wire just behind the red one. I am planning on drawing a negative wire to the bolt holding the bracket in position and distributing from there.
    USB plug in and terminated
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
  5. #164
    Kathu
    Thanked: 2375
    Netjies
  6. #165
    Thanked: 954
    Netjies
  7. The Following User Says Thank You to Uys For This Useful Post:
  8. #166
    Clanwilliam
    Thanked: 305
    Kinder arbeid Hoop jy betaal jou handlanger goed!
    2011 FJ Cruiser
    2018 Hilux 2.4 4x4 D/C
    Afrispoor Serval
  9. #167
    Thanked: 954
    Sy mag met die bakkie ry.......
  10. The Following User Says Thank You to Uys For This Useful Post:
  11. #168
    Thanked: 954
    Yesterday's mod/addition.
    I got my tralies back from powder coating yesterday. I bought it RAW so that I can make some small changes to it - i.e lights and power outlets.
Name:	WhatsApp Image 2018-02-08 at 18.44.48-2.jpg
Name:	WhatsApp Image 2018-02-08 at 18.44.48-3.jpg
    And here is the lights - one on each side and one in the middle shining into the loadbin
Name:	WhatsApp Image 2018-02-08 at 18.44.48-1.jpg
Name:	WhatsApp Image 2018-02-08 at 18.44.48.jpg
    The "DB" and switched goes here:
Name:	WhatsApp Image 2018-02-08 at 18.16.06.jpg
  12. The Following 3 Users Say Thank You to Uys For This Useful Post:
  13. #169
    Kathu
    Thanked: 2375
    Waar is die jaloers knoppie
    Darem een thread om na uit te sien.
    Lekker Uys.
  14. The Following 2 Users Say Thank You to grips For This Useful Post:
  15. #170
    Robertson/ Larissa, Greece
    Thanked: 2551
    Uys just out of interest. What are you going to do when going on holiday. Canvas cover or canopy?
  16. #171
    Thanked: 954
    Canvas cover with a trailer.
    I am not sure how to fix the cover though.....
    The tralies are not resting on the load bin - they are supported on six feet inside the load bin, four of which are bolted to the original tie down points. Between the tralies and the load bin there is a 12mm foam strip. So I am thinking of slipping an ali strip in there into which the canvas cover can slide.
  17. #172
    Thanked: 954
    Yes, many men with small feet complain of slip out...
    Regarding the issue of small feet and slipout.... I had to fix this, obviously!
    I did not want to weld on it, because of the electronics. SO I cut the round bar and threaded it. Then used a longnut to extend it. The bottom part is securely screwed into the nut with Locktite and the top part is locked with a locknut. So now the problem is sorted and as an added bonus I can adjust the angle of my dangle.
  18. The Following 2 Users Say Thank You to Uys For This Useful Post:
  19. #173
    Mar 2013
    Thanked: 65
    Uys,
    Do you need to remove the plate for maintenance activities - draining oil? Or is there a cut out for accessing the sump plug.
  20. #174
    Kathu
    Thanked: 2375
    So on Saturday mornign I decided it was time for protection - more of it. I caled the guys at Stofpad4x4 who opened shop just for me! What a nice bunch of people!
    Anyway I got a bash plate with the optional powder coating package and installed it. I was so amazed at the quality and ease of fitment. Took me only 10 minutes to get this type of world class protection fitted.
    Dink jy Stofpad sal op `n Saterdag rocksliders op die Cruiser sit Ek soek rocksliders wat elk so tussen 10 en 15l water kan stoor,
  21. The Following User Says Thank You to grips For This Useful Post:
  22. #175
    Thanked: 954
    Quote Originally Posted by riaande View Post
    Uys,
    No. Just the inspection cover. Two bolts and a small plate.
  23. The Following User Says Thank You to Uys For This Useful Post:
  24. #176
    Thanked: 954
    Oom Chrito - my sliders is juis "oop" sodat hulle kan drein. Ons e-coat hulle aan die binekant ook om roes te voorkom.
  25. #177
    Thanked: 954
    Today I installed the winch plate behind the bumper:
  26. #178
    Sep 2011
    Potch/Brits
    Thanked: 581
    Beste draad wat ek van hoek tot kant gelees het in n lang tyd.
    Uys goeie werk met daai harnas en voltmeter!
  27. #179
    Thanked: 139
    Kry net n mooier nr plaat bracket....verder well done!
  28. #180
    Amorosa
    Thanked: 355
    Het jy jou Hilux in Secunda gekoop?
    Bush Lapa Miskruier 586
