The Hilux fred: Starting with a blank canvas - Page 8
Page 8 of 19 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 ... LastLast
Results 141 to 160 of 371
  1. #141
    livingstone
    Thanked: 157
    Default Re: The Hilux fred: Starting with a blank canvas
    Hi Guys
    sorry to be a POM but I have been following this thread as I have just bought a 2.4 Hilux and am loving what Uys is doing to his car.
    Does anyone know how to use Google translate so I can keep on following? Thanks
  2. #142
    Thanked: 952
    I'll try to stick to POM going forward
    Everything is a hammer.
    Unless it is a screw driver.
    Then it it a chisel.
  3. The Following User Says Thank You to Uys For This Useful Post:
  4. #143
    Thanked: 59
    Quote Originally Posted by mad manny View Post
    yes, many men with small feet complain of slip out...
    hahaha !
  5. #144
    Thanked: 952
    Anybody here with a roofrack on a Revo?
  6. #145
    Thanked: 952
    Today's mods:
    1. Volt meter.
    Toyota is really spoiling us with all the openings on the dash board for accesories. For example the rectangular openings below the heater controls and the round opening on the right of the steering wheel which was clearly intended for a Volt meter on the dual battery - compliments of 4x4 Direct.
    Removing this plug involves breaking your arm in two places and your middel finger in another two with a ball pein hammer. From there is is quite easy to maneuver your arm in from below the dash board to oush it out. I did not want to use a flat screw driver to pry it out as this always causes damage to the dash board.
    Once you have it out, it is important to cut out the gussets on the inside before drilling a hole. The gusset will push the drill bit off centre as it breaks through and then you end up with a die grinder and lots of swaering and blood to get it (almost) concentric again.
    Refering to these:
    The hole needs to be 28mm, but at 27mm (one of the steps on my step drill, you can push it in, eliminating the need for a backnut, which would be very difficult to fit anyway.
    Final result:
    Then on to the USB plug. In this case, even with the broken arm and finger I couldn't reach it from the inside and had to pry it out. Luckily no damage to the dash. Fitting is as easy as pushing the new one in from the front.
    After that I made up the harnass from the fuse box to the Volt meter, halfway tying in the USB plug - so they will be on the same circuit. The USB plug had a fuse inline which I removed, because if this thing blow, you'll never reach it to replace it. I wanted to install the harnass, but I didn't have 10mm heat shrink to finish off the ends - so that will have to wait to tomorrow.
  7. The Following 2 Users Say Thank You to Uys For This Useful Post:
  8. #146
    Robertson/ Larissa, Greece
    Thanked: 2551
    Bliksem Uys, dit lyk netjies. Veral daai voltmeter. Skitterende werk!
  9. The Following 3 Users Say Thank You to Francois Theron For This Useful Post:
  10. #147
    Thanked: 952
    Baie dankie!
  11. #148
    Thanked: 952
    In the mean time this also showed up. SWAMBO had it powder coated specially for me.... no extra charge....
  12. The Following User Says Thank You to Uys For This Useful Post:
  13. #149
    Thanked: 952
  14. #150
    Clanwilliam
    Thanked: 305
ID:	476413Speedcontrol installed
    2011 FJ Cruiser
    2018 Hilux 2.4 4x4 D/C
    Afrispoor Serval
  15. #151
    Thanked: 952
    Quote Originally Posted by Sandveld View Post
    Dankie, daai moet gebeur!
  16. #152
    Sep 2017
    Randburg, Johannesburg
    Thanked: 8
    I need this.
    Where was it installed and what was the cost?
  17. #153
    Bethlehem
    Thanked: 3225
    Uys........jou sleutels krap die plastics by jou ignition kwaai.
    Het jy al die gelees?? Dalk hier en daar iets vir jou
    Of COURSE I have a Bad Habit. I take Tea at Three (Mick Jagger)
  18. #154
    Thanked: 952
  19. #155
    Mar 2016
    Thanked: 1884
    Hy sukkel om die gat te vind
  20. #156
    Thanked: 139
    Dis sy lang naels
  21. #157
    Bethlehem
    Thanked: 3225
    Dis sy lang naels
  22. #158
    Bethlehem
    Thanked: 3225
  23. #159
    Thanked: 952
    Quote Originally Posted by Oppies3800 View Post
    Ja, dis snaaks ek sukkel nie gewoonlik daarmee nie.
  24. #160
    Bethlehem
    Thanked: 3225
    Uys, sal jy meer info gee oor daai front towbar/towball op die Revo asb?? Dis iets wat ek nogal BAIE gaan gebruik.
    En maak jou hartjie sag met prys asb my Grootbaas. Ek het 4 kinners
