Page 2 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 21 to 40 of 153
  1. #21
    Mosselbaai
    Thanked: 731
    Default Re: Prof's Rocky Thread
    Spares & Parts ?
    eBay?
    Saw the Rocky today, very impressed.
    It's got much more space than I thought and solidly build.
    Well looked after as well.
    Jean van Niekerk
    105 Cruiser
    Amarok AWD
  2. #22
    Feb 2015
    Noordhoek, Cape Town
    Thanked: 2457
    1660Kg seams heavy?
    Drive it like a Samurai, point it and floor it. Momentum is your friend.
  3. #23
    Friemersheim, Southern Cape
    Thanked: 4829
    Spares & Parts ?
    Manoel, you know me as a can do guy
    There will always be a plan....
    Robert van den Berg
    '98 Daihatsu Rocky 'The Kitty'
    '02 Daihatsu Rocky 'The Bully'
    "What can be asserted without evidence can also be dismissed without evidence."
  4. #24
    Thanked: 4829
    The trip down did have some problems....
    The owner had the clutch replaced some weeks ago....only used it for driving round Bethlehem after change.
    So after receiving it drove it to Kroonstad to a farm near Bossiespruit. (The army base where I suffered thru training...). Upon stopping smelt the smell of 80W90.
    Promptly rolled underneath and saw the transfer case was covered in oil. Transfer case is bolted onto the back of the gearbox which had to be removed to change the clutch. (Hilux replacement)
    Seemed to me that it was bleeding between the gearbox and transfer case. I could turn all the bolts a quarter turn....added 350ml oil...cleaned and thought problem solved.
    Next day drove to Welkom area to visit some other friends...checked the case....full of oil...again
    Fortunately they had a pit...drove onto and did proper inspection. The buggers never refitted the boot where transfer lever goes into the case...it was stuck up near the body. Also the four bolts holding down the lever housing were sans washers...so they bottomed out...thus not sealing properly. Could get to the two front ones and put in washers. The back ones were more difficult to get to...needs complete strip from inside. Left them. Decided to see how it goes.
    Left in the morning...it leaked....so the procedure was...
    Bloemfontein, Colesberg, Graaff Reinet and home....rolled underneath, took out filler plug, added anything up to 50-100ml, depended on the hardness of driving. (tried to stick to 110km/h, but truck overtaking...)
    Got home safely, no issues.
    Not peeved at owner, he would have never noticed as he never got it hot enough to show. More peeved at company that did replacement of clutch. Some 'ape' working there.
    Robert van den Berg
  5. #25
    Thanked: 4829
    Also the boots on the front CV's were shot. Owner knew and I accepted situation. CV's did not knock on full steering lock, so they seemed ok.
    Covered broken boots with bubble wrap and tied with tape and cable ties to prevent dirt ingress. That shaft doesn't turn in 2H anyway.
    Protection was still fine when I got home.
    Local Midas stocked boots @ R100
    Being fixed as I post
    Robert van den Berg
  6. #26
    Fourways, Jhb
    Thanked: 247
    Well done Prof, very nice machines those
    I'm also new to diesel on new wheels but enjoying the scenery immensely!
    Toyota Hilux 2.5 D4D SRX
    [/B]​
    The greatness of a nation and its moral progress can be judged by the way its animals are treated - Ghandi
  7. #27
    Thanked: 4829
    I picked up a stone on the Welkom Rd (Free State) and that developed into a crack. Right in my face.
    Could be an issue with roadworthy....
    No windscreens available via National Autoglass.
    Contacted WiseCracks....did his thing and crack hardly visible....starbursts repaired as well
    On the way home stopped at GrandMark for something else. Asked if they could source a Rocky windscreen...as luck would have it, they had one they ordered but wasn't collected. Promptly bought it @ R1 200 and it can reside in my store till required.
    CV boots replaced, transfer case oil leaks resolved, some minor items to sort before roadworthy.
    Robert van den Berg
  8. The Following 4 Users Say Thank You to Prof For This Useful Post:
  9. #28
    Mosselbaai
    Thanked: 731
    Now for some pics of it off road
    Jean van Niekerk
    105 Cruiser
    Amarok AWD
  10. #29
    Thanked: 4829
    Fixed a broken taillight.....
    Robert van den Berg
  11. #30
    Thanked: 4829
    Passed the roadworthy and stuck a sticker on
    Robert van den Berg
  12. #31
    Thanked: 4829
    So took it for it's first 4x4 outing, at Paradise near Wilderness.
    The Desert Dog section the cross axles were just too big, but Fugly after couple of tries was conquered.
    This one you have to use 4L in 1st gear running at 4000rpm to not loose steam at the top
    Video of last hill, need to lift vehicle as cross member supporting gearbox a trifle low, I seem to be grading the middle mannetjie.
    Video thanks to Jeanvn
    Robert van den Berg
  13. #32
    Mosselbaai
    Thanked: 731
    Ek dink dit is JP se yes!!! Wat jou daar uit gekry het
    Jean van Niekerk
    105 Cruiser
    Amarok AWD
  14. The Following User Says Thank You to Jeanvn For This Useful Post:
  15. #33
    Jul 2016
    Pringle Bay
    Thanked: 767
    Congrats Prof only just read the thread, nice looking machine, should be a great buy, enjoy
    Audi A6 Avant Quattro V6 tdi ( Sold )
    VW Touareg V6 tdi ( sadly written off )
    2 x Toyota Celica GT4 Gen 6 (Sold) sadly missed
    2 x Toyota Celica Gen. 5 ( Sold ) not missed as much as the above.
  16. #34
    Feb 2015
    Thanked: 2457
    Ek het mos gese point it and floor it!
    Netjies Prof. Ek is baie trots op jou. Baie.
  17. The Following 2 Users Say Thank You to Chris Stoffel For This Useful Post:
  18. #35
    Mosselbaai
    Thanked: 731
    Desert dog se cross axles was bietjie diep.
    Jean van Niekerk
    105 Cruiser
    Amarok AWD
  19. The Following 3 Users Say Thank You to Jeanvn For This Useful Post:
  20. #36
    Thanked: 4829
    Ja nee, as 'n groot ou kan wegraak in die gat, wat van my klein karretjie?
    Robert van den Berg
  21. #37
    Feb 2015
    Thanked: 2457
    Die klein 4x4's sonder al die magic knoppies speel vrek lekker.
  22. #38
    Feb 2015
    Thanked: 2457
    Vat die gat headon dan is dit nie 'n cross axle nie. Ry deur die gat. Ons klein karretjies pas binne in die gat.
  23. #39
    Mosselbaai
    Thanked: 731
    Oi! Noem jy my 'n vet gat
    Jean van Niekerk
    105 Cruiser
    Amarok AWD
  24. #40
    Thanked: 4829
    Quote Originally Posted by Jeanvn View Post
    GROOT does not equal VET
    Robert van den Berg
