Results 1 to 5 of 5
    Jan 2018
    Germiston
    Default Grand Cherokee starting problem
    Have difficulty in starting from cold even in the heatwaves. Once hot no problem. Can't see any diesel leaks. Some advice needed on this please.
    Thanked: 5997
    Default Re: Grand Cherokee starting problem
    Quote Originally Posted by elgrotto View Post
    I propose you to ask in Jeep section. There are quite a few experts. Just give more details about the model/year/engine type.
    Jouko
    2003 Grand Cherokee 4.7l
    2012 Smart
    Never drive a normal car 8)
    Dec 2010
    Pta, Silverton
    Thanked: 74
    Also add what Jeep Grand Cherokee it is.
    Andre
    ______________________________________
    2011 3.6 WKII Overland
    2010 2.8 CRD KK Limited (Heksie transport)
    2007 Alfa 159 jts
    Thanked: 20097
    Quote Originally Posted by Bulli View Post
    Probably one of those nice reliable 3.1TD WJ's.............
    Dec 2013
    Bapsfontein
    Thanked: 163
    If it is a 2.7 crd with the Merc engine then have a careful look at those plastic diesel pipes. They have o-rings that tend to seal less than perfect when they get oldish and this lets in air when the engine isnt running for a while. Easily enough to replace. The other change to make is to get rid of those plastic t-pieces on the injector bypasses. I replaced mine with alu ones that I bought from Bosch Diesel Services. They can supply you with the correct o-rings as well.
    My E270 Merc had similar issues, but after replacing those she ran fine. Had 460k km on the clock when I sold her...
    Defender powered by Isuzu
