Wat is die broodboom werd?
Results 1 to 20 of 29
    Rustenburg
    Thanked: 36
    Default Wat is die broodboom werd?
    So ek het 'n huis gekoop met 'n m.se broodboom waar die jacuzzi moet kom. Hoor by vriende hy kan moontlik baie werd wees. Het blykbaar papiere en als wat saam die huis planne gebere is. Moet dit net opspoor.
  2. The Following User Says Thank You to Netler For This Useful Post:
    Nov 2011
    Langebaanweg
    Thanked: 789
    Default Re: Wat is die broodboom werd?
    There is a site that can help calculate worth. But you are not allowed to remove a planted Cycad without permission from Fauna and flora.
    Personally I would keep it, but I already have 5.
    If you want me to get the website for you I can.
    84' Land Rover Defender 110 V8 4-speed Hardtop (Meisiekind) Sold after 12 years of fun and hard work
    Thanked: 983
    ek sal hom vat as die prys reg is
    [email protected]
    +27824453301
    Jul 2013
    Thanked: 273
    Ek like jou tuinstel, seker by jou pa oorgevat..
  6. The Following 5 Users Say Thank You to janseekat For This Useful Post:
    Jun 2012
    Pretoria East
    Thanked: 257
    As jy regtig cycads soek, ek het 'n erf vol van die goed waarvoor ek 'n paar rand moes betaal. Party is blykbaar skaars goed. Dink ek het fotos van die fancy soort.
    PM gerus.
    May 2010
    Thanked: 202
    Not too knowledgeable about cycads but that looks more like a ‘revolutor’ - Chinese cycad. Not very valuable at all
    Roy
    Beneath every ‘Majestic Oak’ lies a ‘Tuff Nut’ that refused to give up!!
    Daily Drive : 2010 Discovery 4 SE
    Weekends: 2003 BMW K1200GT
    Nov 2011
    Langebaanweg
    Thanked: 789
    No! I promise you that is not a Cycas Revoluta, that is a definitely endemic.
  10. The Following 2 Users Say Thank You to jfh For This Useful Post:
  11. #8
    Thanked: 983
    Quote Originally Posted by locklaw View Post
    PM gerus.
    Maak so
    [email protected]
    +27824453301
  12. #9
    Rustenburg
    Thanked: 36
    Thanks, I would appreciate the website.
  13. #10
    Rustenburg
    Thanked: 36
    Quote Originally Posted by janseekat View Post
    Geweet ek moes tuinstel skuif voor ek d foto neem. 100% reg. Dink die tuinstel is ouer as ek. Het agter gebly toe ek d huis by hulle oorkoop.
  14. #11
    Rustenburg
    Thanked: 36
    Quote Originally Posted by Netler View Post
    Dink nou daaraan. Broodboom en tuinstel hier vandat ek kan onthou. Dit maak die boom mininum van 30 jaar oud.
  15. #12
    Thanked: 9
    Hi... that is a Transvenosus. It looks like the Soutpansberg form. Very nice plant. You need to measure the width and the height of the stem and then take the one that is the highest... these are priced in R/cm.
  16. #13
    Oct 2012
    Thanked: 190
    Quote Originally Posted by vanderw View Post
    Agreed, it is E.Transvenosus, a relatively common species.
    Jy kan die stam meet en dan maal jy met die rand per sentimeter. Die Transvenosus is omtrent R40-R60 per cm, so nie te duur nie. As dit n skaars spesie was soos bv. E.Latifrons kon jy daardie sentimeters maal met enigeiets vanaf R1500-R2500 per cm!
    Pragtige plant, los hom net daar waar hy is.
  17. #14
    May 2010
    Thanked: 202
    Ok thanks for the right info how do you visually distinguish the differance?
    Roy
  18. #15
    Thanked: 303
    Daar is 'n ou Waterberg Eugene Maraisii op my vrou se plot. Ek verstaan hulle is skaars en groei stadig, waarvoor sal hulle verkoop op die bogemelde berekening?
  19. #16
    Thanked: 9
    Hi Pierre,
    EM is going for about R175 to R250 a cm depending om the size and sex.
    Chris
  20. #17
    Nov 2011
    Langebaanweg
    Thanked: 789
    http://cycadfriends.co.za/site/pricing-guide/
    But you first need to determine the species. It might be better to contact them and provide them with photos of the leaves,length of leaves and circumference of trunk.
    They can be rather tricky to id.
  21. The Following User Says Thank You to jfh For This Useful Post:
  22. #18
    Thanked: 39
    At CycadFriends.co.za you will get all the relevant information regarding prices, habitat, how to's, etc.
    As it was pointed out by Mr. jfh, you will need a permit for your garden as that one is indigenous to South Africa and is protected (same principle as the rhinos).
    My calculated price regarding the Encephalartos transvenosus is R 43.66 /cm
    Measure the diameter and height above ground of the caudex (i.e. trunk without any of the leaves)
    Take the maximum measurement between the diameter and height and times it by the above price per cm.
    There is your answer.
    Currently, the Encephalartos eugene-maraisii goes for R 251.96 /cm and the Encephalartos latifrons goes for R 1,049.34 /cm.
    Pricing surrounding these species are always a hot debate on the Cycad forum... so join in the fun!
  23. The Following User Says Thank You to etienne.vd For This Useful Post:
  24. #19
    Mar 2016
    Thanked: 49
    It is a Soutpansberg Transvenosus. Look at the pattern at the back of the leaves. More valuable than ordinary Modjadji Transvenosus. Probably worth R60 per cm if it is female.
    If it is Ettiene from Cycadfriends his prices are accurate
    Measure diameter and height and which ever is more will be used for the calculation.
    The plant also seems to have a sucker/s which can also be added.
    If you know what you are doing it can be transplanted but doing it the wrong way will kill it. Afrikaans:Visgraat vorm Transvenosus.
  25. #20
    Thanked: 39
    Cool Re: Wat is die broodboom werd?
    Quote Originally Posted by JK1 View Post
    Yep, that is me... guilty as charged
  26. The Following User Says Thank You to etienne.vd For This Useful Post:
    JK1
