What drawer system for an Amarok
Results 1 to 20 of 20
    Thanked: 42
    Default What drawer system for an Amarok
    HI all,
    looking for suggestions on a drawer system for an Amarok.
    What works well, what doesn't?
    Thanks,
    G.C.
    Current:
    2016 Amarok 2.0BiTDi 4Motion Highline (ex Safari 4x4 Roetes)
    2019 Cross Up!
    2016 Metalian Maxi
    Oct 2017
    Rustenburg
    Thanked: 1077
    Default Re: What drawer system for an Amarok
    Frontrunner.
    Good quality. And very robust.
    With lots of additional options availible
    Dum vivimus, vivamus!
    LC76V8
    Thanked: 42
    Hedgehog,
    do you have one in an Amarok?
    Current:
    2019 Cross Up!
    2016 Metalian Maxi
    Oct 2017
    Rustenburg
    Thanked: 1077
    No... but why would the loadbed of an Amarok be different to any other bakkie.?
    LC76V8
    Thanked: 42
    Not getting a good feeling from FrontRunner. They say you need to panelbeat the front loadbox panel and then also just drill through the floor. Not very inspiring...
    Current:
    2019 Cross Up!
    2016 Metalian Maxi
  6. The Following User Says Thank You to GeckoCampers For This Useful Post:
    Oct 2017
    Rustenburg
    Thanked: 1077
    Quote Originally Posted by GeckoCampers View Post
    I had no panelbeating issues.. seems strange.
    But you have to drill to secure the drawers.
    I see no other way.
    Unless you know of a different method?
    LC76V8
    Thanked: 42
    I want to make use of the existing tie down mountings...
    The online instructions indicate this method, the FrontRunner folks seem to think: Ons boor altyd...
    Current:
    2019 Cross Up!
    2016 Metalian Maxi
  9. The Following User Says Thank You to GeckoCampers For This Useful Post:
    Apr 2017
    Hillcrest
    My research on the Frontrunner kit did not indicate any drilling required for the drawer system - the 4 anchor points are sufficient (there are 6 in the loadbay)
    Even though their gear is fantastic it didn't give me a configuration I needed so I'm in the process of building my own (there is an early version of the build on the "What did you do with your VW Today?" thread)
    Basically a water tank behind the cab, then (currently) battery followed by a (future) NL90 on the left. RHS is dual drawers with 3x ammobox on top, kitchen drawer below (with a 2nd extension drawer for a 2-burner Cadac cooker)
    Don't have any pics of the current status but I'll happily PM you some pics on the weekend.
    Denzil
    Feb 2013
    Thanked: 57
    I presume you already know what configuration you want? In my mind that's a more important question than which brand since there are loads of options and it all depends on your use.
    For starter drawers or flat slider, drawers or ammo boxes, space for a fridge, space for a battery, permanent camping vehicle or daily driver where the bakkie gets used for other things as well?
    I don't drink water, unless it's been through a brewery first.
    You probably heard people saying Africa is not for sissies. Well, neither is it for wussy equipment.
    Man who dies with most gear wins!
    Thanked: 42
    Thanks for all the suggestions guys. Will update with pics on the work in progress and final product
    Current:
    2019 Cross Up!
    2016 Metalian Maxi
  13. #11
    May 2010
    Quote Originally Posted by DenzilB View Post
    Denzil
    Hi Denzil,
    Did you get around to completing your drawers? It would be great if you could post some pics, I have a similar setup and just got a Rock.
  14. #12
    Jun 2013
    Thanked: 1747
    Try Japie
    local Alberton boy with some good product that will match Front runner.
    http://www.focusdrawersystems.co.za/...w-our-products
    BMW R1200R
  15. #13
    Thanked: 42
    Try Japie
    Busy making mine. Will post pics later in July
    Current:
    2019 Cross Up!
    2016 Metalian Maxi
  16. #14
    May 2016
    Tzaneen
    Thanked: 27
    Outback rak en laaistel, my 2de Amarok, baie tevrede
  17. #15
    Strand
    Quote Originally Posted by janvantzn View Post
    Wie in die Kaap hou Outback aan?
  18. #16
    Apr 2017
    Hillcrest
    Quote Originally Posted by mariuswillemse View Post
    Hi Denzil,
    I'd call it 80% plus complete.
    We did a 3 week trip through Namibia at about 70% complete and realised it needed some mods. Right now we're on a 6 week post retrenchment "rest and reset" trip through western SA. Did some of the changes in a bit of a rush just prior to leaving Durban. Wanted to do some pics of the progressive install but that heavy rain we had complicated things. Will post some general pics shortly
  19. #17
    Thanked: 2142
    I had an Outback. Was very happy. the slider's hook just worked out after three years and 80k km
    VW Touareg V6 Tdi Escape
    Bush Lapa Boskriek 816
  20. #18
    Apr 2017
    Hillcrest
    Base with water tank, median mounting strip (probably change that for a steel L-channel in future) and tie-down straps for battery box
  21. #19
    Apr 2017
    Hillcrest
  22. #20
    Apr 2017
    Hillcrest
    Sorry about the rotated pics
