Defender Heater speed control
Results 1 to 9 of 9
    Napier
    Thanked: 31
    Default Heater speed control
    Has anyone fitted a PWM speed controller in place of the lever speed control on a Defender (1992) 3.5 V8? My resistor has blown on my heater and they dont appear to be readily available.
    Where could I get a PWM controller in western Cape?
    Babushka - 3.5 V8 Defender Highline
    SWAMBO - 1.6 Nissan Livina X-Gear
    Harties
    Thanked: 473
    Default Re: Heater speed control
    Quote Originally Posted by DSouter View Post
    On-line stores - Communica, RS etc.
    If you make a noise or need music in the bush or on the beach, you’re missing the point.
    Friemersheim, Southern Cape
    Thanked: 2144
    Thanked: 2144
    Sjoe...you have been looking around....
    http://www.4x4community.co.za/forum/...eater-Resistor
    Jun 2007
    Thanked: 53
    Is that switch STC3987 ?
    Oct 2015
    Romania/Hungary
    Thanked: 114
    Part number for the resistor is UTP1281 , it's available in many stores but quite expensive
    2000 Discovery Td5 ES manual, tuned
    Hawkeye v.6, Nanocom EVO,
    VDM UCANDAS, oscilloscope
    i DON'T ANSWER TO TECHNICAL QUESTIONS IN PM'S
    ALL MY ADVICES ARE BASED ON MY OWN EXPERIENCE AND MY WAY OF UNDERSTANDING THE DESCRIPTION AND OPERATION OF SYSTEMS... I'M NOT A LAND ROVER SPECIALIST JUST AN ADDICTED ENTHUSIAST
    Napier
    Thanked: 31
    I have purchased a speed controller (PWM) from Communica - great service by the way - next day delivery.
    Hope to fit it today - will let you know how it works.
    Jun 2017
    GERMISTON
    Thanked: 40
    Funny how these things go, I had it both on my BMW318 as well as my X-trail. They called it the - fan speed control resistor. I had to buy both of them at the agents at that time. What a difficult little thing to fit. So far so good with the D4D, touch wood. Good luck for you sir
    Napier
    Thanked: 31
    Hi - Done & Dusted- got the one below eventually because of higher amps and reverse polarity protection.
    Easy to install and works like a dream - can now control motor from slow to full blast.
    Very happy.
    DC Motor Speed Controller 6V~90V 10A
    PWM / DC Motor Speed Controller
    10A 6~90V
    DC Motor Speed Controller 6V~90V 10A allows controlling speed of a DC motor using a Pulse-Width-Modulated (PWM) DC voltage with a Duty Cycle adjustable
    Part No: DGM PWM DC MOTOR CONTR 10A 6-90V
    No code has to be inserted here.
