Tyre wear.
Results 1 to 12 of 12
Thread: Tyre wear.
    May 2017
    Default Tyre wear.
    What could cause tyre wear in the middle of the tyre?
    I have 265/70/16 . if viewed from the front it looks like the tyre is lower in the middle than the sides.
    I think the pressure was too high before I bought the Hilux.
    the information on the inside of the door panel suggests 2 bar unloaded. is this correct?
    Vredenburg
    Thanked: 28
    Default Re: Tyre wear.
    Wear on centre of tire is usually an indication of over inflation.
    Marius Swart
    (Blackie)
    2010 Land Rover Freelander 2 Td4 SE
    1997 Opel Corsa Bakkie 1.3i
  3. The Following 2 Users Say Thank You to Blackie KB 300 For This Useful Post:
    Thanked: 1402
    Quote Originally Posted by fred1234 View Post
    What tyre pressures were you running?
    Sent from my iPhone
    Thanked: 110
    Quote Originally Posted by Blackie KB 300 View Post
    True but I've seen the opposite as well. Under inflated tyre driven daily at high speed for a relative short distance.
    Triton DC, Jimny and K1200GT scooter.
    Jan 2017
    Thanked: 13
    2007 Pajero 3.2DiD GLS (SWB)
    Jan 2007
    Thanked: 324
    Quote Originally Posted by Woestynbrak View Post
    Surely that should lead to worn shoulders on the tread?
    Thanked: 1162
    My understanding is that an underinflated tyre driven at high speed will cause the tyre to warm up too much and behave like an overinflated tyre.
    Defender 2.8i
    Thanked: 1402
    Quote Originally Posted by albertvl View Post
    What will happen to an overinflated tyre then?
    Sent from my iPhone
    Thanked: 1162
    As far as I know it is safer to drive with an overinflated tyre than an underinflated tyre at high speed.
    Defender 2.8i
    May 2015
    Somewhere
    Thanked: 604
    True that. In fact, if you look carefully at some vehicle tyre pressure charts, it officially states a much higher pressure for sustained high speeds, above 160kph, although this doesn't really apply to South African cars as said high speeds are not exactly legal, but still quite often achieved in said country.
    A sure sign that there is in fact intelligent life elsewhere in the universe is that none of it has bothered contacting us.
    Thanked: 1162
    The way that I understand it is that the flat tyre's shape deforms more while rolling than a properly inflated tyre. This causes more friction between the air molecules inside the tyre, causing it to heat up beyond spec.
    Defender 2.8i
    Amanzimtoti
    Thanked: 198
    More heat generated due to rubber flexing at low pressures than air molecule friction.
    For under inflated tyre to wear in centre of tread would be more due to centrifugal forces at sustained high speed. Be amazed to see how much a low pressure tyre grows at high speed, found this out in my motorcycle racing days when running set with rear tyre close to back of swing arm.
